HP 17-BY0132NF Touchpad dead
  • sect-sin
    • May 2022
    • 101
    • Hungary
    I have a problem with a HP 17-BY0132NF Notebook (motherboard marking SNAPE-6050A2982701-MB-A01(A1)). After repair and subsequent Windows 10 install, the system was extremely slow. Nevertheless I managed to download all drivers from the HP support page (which correctly identiefed the notebook as 17-BY0132NF), and I also installed a BIOS update. The original BIOS revision was F9, and I updated it to F64, the most recent available version.
    This fixed the speed issue immediately, but the Touchpad stopped working. I tried every possible software solution (tried different drivers, Windows reinstall, etc.), to no avail. Then I tried to revert to the original BIOS version, only to notice that there is no F9 revision on the HP support page. I tried downgrading to other BIOS versions, but that did not help either. Unfortunately I do not have a backup of the original F9 version.
    As the touchpad is driven by the EC, I might have messed up the EC during the initial BIOS update. As I do not have a programmer for the EC, I hope this is not the case. I have attached the current BIOS dump. Could somebody help me with cleaning/fixing my BIOS?
    I thank you very much in advance for your help.
    Cheers,
    sect-sin
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: HP 17-BY0132NF Touchpad dead
    Cheers,
    sect-sin
    Latest version from HP (F.66) your old file was (F.62) Not (F.64), try it and let me know the results.
    all donations are welcome,
    • sect-sin
      • May 2022
      • 101
      • Hungary
      Hi hardware1,
      That solved the problem, thank you very much. On first boot, BIOS wrote into EC (there was a short dialog window), and now my touchpad is working again. I just need to get out of manufacture unlock mode now, will donwload an avalible version of BCU, and do that.
      Thanks again!
      Cheers,
      sect-sin
      • Loli Popu
        DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 03:28 AM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
        by Vesko356
        08-11-2023, 03:27 AM
      • tranquility
        Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
        by tranquility
        hallo,
        i have an asus X515KA-EJ058W here.
        just both leds white...he battery blinking without battery connected
        consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
        if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
        power on again is possible but again 400mA then and no picture.
        now the really strange
        i flashed bios (some version i found on the internet) and resoldered....sometimes...
        12-11-2024, 06:47 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
