MacBook Pro A1706 820-00239 no power
  • Xenoaeuriix
    • Dec 2022
    • 36
    • Philippines
    #61
    Re: MacBook Pro A1706 820-00239 no power
    I am not sure but could it be that I damaged the SSD in any way while in the process of repairing it? I have not removed any heat sink and fixed the board while all the metals are still connected. If all else fails I will just have the OS installed on an external drive possibly.
    • mon2
      • 14669
      Very good. Review the nand flash voltage rail. The ssd has to be powered to be enumerated. Measure the voltage where you can. The nand flash is also PCI Express interface based. Respectively, you will see DC blocking caps (0.1 uF) in series with each of the PCIe signals. Confirm that each such cap is present and not defective. Even if a single cap is missing, the SSD will not be detected. Do also check if the nand flash chips are too hot. This can mean they are defective.
      • mon2
        • 14669
        Also, watch this video. Could be the same case for you.
        https://youtu.be/WbuRSUitwCw
        • mon2
          • 14669
          And this dude. A fast talker but he shows that the 1v8 power rail for the ssd was shorting due to another quality capacitor. Resulting in the power supply for the ssd shutting down and you will see the ssd as missing.
          https://youtu.be/1e1xNE4DEaM
          Keep us posted. You are making great progress. Hope you continue with this and future repairs in your region.
          • Xenoaeuriix
            • Dec 2022
            • 36
            • Philippines
            #65
            Thank you so much! I really appreciate all the help. I may not be able to do it right now since I am still in my working hours. By tomorrow I might be asked to report to the office since the restriction here in Manila has been lifted long ago. I will try to do it tomorrow before work and I will make sure to keep you posted.
            I will make sure to check all the videos you have sent here.
            • Xenoaeuriix
              • Dec 2022
              • 36
              • Philippines
              #66
              I forgot to mention I am doing this as a hobby but sure if I can repair a laptop in the future it would be really great. But for now, I need a stable income hence office work is my go-to work till I manage to acquire enough experience and knowledge with the repair. Thanks thanks.
              • mon2
                • 14669
                You are off to a great start. Keep at it. For sure there are enough sales to support this as a viable business model in your area. Have been through Manila and there are ample iphone / iwidget and Macbook junkies in your backyard.
                • Xenoaeuriix
                  • Dec 2022
                  • 36
                  • Philippines
                  #68
                  Update: I have been searching the internet for things I need to look for as well as youtube for issues they had about why SSD is not working. So far I was not able to find the same. I am running out of options and starting to wonder if I can still fix this hahaha. One thing I notice is that I have unknowingly shorted C6505 pin#2 to ISNS_SSDNAND_IOUT I am not sure if it is bad or what but I did trace where it goes and it is not connected anywhere at all or at least the components where it was supposed to be connected is none existent.
                  Another thing to mention is that C9403 and all other components connected to it are not shorted when the black probe is connected to the ground but in reverse polarity, it shows dead short I am not sure if that is just okay or if it is normal to act like that.
                  I hope someone can help me move forward.TIA.
                  PS: Just a question those capacitors that I remove are not critical as you have mentioned I would like to confirm when you mentioned not critical it is like critical to powering the unit. As far as I can see the unit is powering okay so I guess those are not indeed critical to powering on the unit but is there a chance that these capacitors are used for the enabling of the SSD?
                  • Xenoaeuriix
                    • Dec 2022
                    • 36
                    • Philippines
                    #69
                    I have found another forum that has lots of the same issues as mine and will try to check each thread to see if I can get anything from the information that I can find. It's rossmanngroup they have a pretty huge collection of issues and solved cases there but free users have limited access. I will update here again if I found something that will for me just in case others found their selves in the same situation.
                    • vkjuju
                      • Aug 2023
                      • 台灣
                      #70
                      Originally posted by mon2
                      Measure & post the voltage values for:
                      1) PP3V3_G3H
                      2) PPVIN_G3H_P3V3G3H
                      3) PPBUS_G3H @ D6902, pin # 1
                      4) PPDCIN_G3H_CHGR @ D6902, pin # 2
                      5) PPBUS_G3H @ F7000, pin # 2
                      6) PPVBAT_G3H_CHGR_REG @ F7000, pin # 1
                      7) PPDCIN_G3H
                      PPBUS_G3H is created by U7000. This component is a common point of failure. Post the above details for the review. Also possible that fuse @ F7000 is blown.
                      Could you tell me where to buy d6902, I can not find it at Taiwan's electronic market, Thanks
                      • mon2
                        • 14669
                        Hi. Very likely that the manufacturer of the diode on the board is from Taiwan
                        The part is not critical but you must source a sc-70 sized dual common cathode diode rated at 30v and recommend 300mA current. It is a common schottky dual diode.
                        Here is one of many that can work here:
                        https://www.digikey.com/en/products/...CWFILM/1207017
                        After some beauty sleep, can find others. I know that we have sourced many ESD diodes from Taiwan for production of our USB designs from Inpaq and others. Will dig a bit later today. The key parameters are sc-70; common cathode, 30v and at least 200mA current but suggest 300mA support.
                        PS: miss the food court in the Taipei 101 building.
                        • vkjuju
                          • Aug 2023
                          • 台灣
                          #72
                          Thanks and welcome to Taiwan again
                          • Cemal Odabasioglu
                            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                            by Cemal Odabasioglu
                            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                            Observations...
                            01-14-2025, 03:54 PM
                          • Danielreinaa
                            HELP need password bios Macbook A1706
                            by Danielreinaa
                            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                            09-07-2024, 03:47 PM
                          • capon5153
                            Macbook A1706 works perfectly but no data on USB C
                            by capon5153
                            hello,
                            so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                            i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                            06-22-2025, 09:42 AM
                          • dbuergi
                            MacBook A2141 one USB port dead and one power cycling
                            by dbuergi
                            I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
                            Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
                            04-25-2025, 11:40 AM
                          • B2L_Repairs
                            Macbook A1706 touchpad and keyboard not working. Please help
                            by B2L_Repairs
                            Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                            10-09-2023, 04:56 AM
