HELP need password bios Macbook A1706
  • Danielreinaa
    • Oct 2020
    • 9
    • Ecuador
    Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
    Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
    Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
    gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
    Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
    I currently have a problem with a macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
    If you could help me I would really appreciate it or some link to learn how to do it and not bother you again.
    Thanks in advance and have a nice afternoon, sorry if I'm breaking any rules.
    in English please..
  • peste
    • 16564
    • ROMANIA
    in English please..
    post EMC
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
    It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • Danielreinaa
      • Oct 2020
      • 9
      • Ecuador
      oh, sorry, emc 3163
      • ibo
        • Oct 2019
        • 124
        • Turkiye
        Here you go.
        You can now see whats removed to unlock.
        • mferna14
          Password removal on MacBook Pro A2159
          by mferna14
          Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
          05-13-2025, 04:16 PM
        • gabrielA7
          Macbook pro A1706 / Backlight flex cable compatibility
          by gabrielA7
          Hey guys!!
          I’ve got a question here!
          I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
          Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
          Here’s what the bot told me:
          I said to him: “I’m going to install the 821-01229-A.”
          ChatGPT replied:
          Understood — but before you solder or install the 821-01229-A,
          11-11-2025, 03:26 PM
        • chriswfrye21
          HP 255R G10 – BIOS Admin Password Locked, Cannot Enter BIOS (Need Guidance / SMC.bin Help)
          by chriswfrye21
          I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
          This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
          I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
          Model: HP 255R 15.6 inch G10 Notebook PC SK...
          08-10-2026, 03:49 AM
        • Tend0
          Macbook Pro A1706 820-00923-05 Stuck At 19,5V 0A
          by Tend0
          Hello everyone, I need your help repairing this motherboard.
          It's a MacBook Pro A1706 820-00923-05. I previously repaired a short circuit on PPBUS_HS_CPU; the component in question was C7960. After replacing it, the MacBook started working again until now, when it no longer works;
          it's only reaching 19V with no current draw, with or without the battery, and even with the board removed from the chassis. Some measurements I've taken:
          When Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L ist not pulsing stable at 3.36V
          PP3V3_SUS =3.36V
          PM_DSW_PWRGD...
          07-19-2026, 06:39 AM
        • Boardview and Schematic Bot
          Apple MacBook Pro 13 M1 820-02020-A 820-02020 Boardview and Schematic
          Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
          Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
          Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
          Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...
          06-20-2026, 10:11 AM
