Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure the voltage by PPVIN_S4_TPAD_FUSE and got 11.2V by the PPVIN_S4_TPAD_FUSE instead of the required 12.6v as required by the trackpad connector (hence I am getting 11.2v by the trackpad(j4501) connector pin 44-50). I checked the ppvin-s4-tpad-fuse , it get its power from ppbus_s4_hs_tpad..and the ppbus_s4_hs_tpad get its power from the ppbus_g3h. I measured the voltage on ppbus_g3h it's inputting also 11.2v instead of the 12.6v hence the MacBook is not getting sufficient voltage for the trackpad. So now I don't know how I can restore the required 12.6v on the ppbus_g3h. I don't know if there is a cap that might be short or maybe an ic. Somebody said its an SMC issue but I am new to Mac repairs so i dont know much on how i can check the smc, your help will be highly appreciated
Macbook A1706 touchpad and keyboard not working. Please help
Tags: None
Re: Macbook A1706 touchpad and keyboard not working. Please help
PPBUS_G3H will vary up and down depending on the voltage of the battery, so I don't believe that is the source of your problem. Measure it without battery connected and it will be 12.6V if everything is normal. Naming changes on these rails due to them going through sensors etc.
Check for presence of PP5V_S4, PP3V3_S4, PP3V3_S0 and SMC_LID at the connector. If the board has been previously worked on, then I would go over the entire board looking for damage (like missing hall sensors on either side of the board and damaged Touchbar connector etc). -
i do have pp5v-s4, pp3v3 s4 and pp3v3-s0...just that i have 11.2 instead of 12.6v on the fuse. The smc lid is readimg 3.4v.Comment
the board was not worked on before, only battery was replaced. As mentioned i do get 5v on PP5V_S4, 3.3V PP3V3_S4 and 3.3V PP3V3_S0. I also meaured the smc lid on the connector and i get 3.4V. Only voltage that is less than normal is the 11.2V instead of 12.6V on the fuse. So i dont konw what else to check. I was thinkink maybe smc line as somebody once said in another group. What voltage should i inject into the mac because when i measure the voltages the mav will be plugged in to a normal type c cable (its my samsung type c cable, not original mac type c cable)PPBUS_G3H will vary up and down depending on the voltage of the battery, so I don't believe that is the source of your problem. Measure it without battery connected and it will be 12.6V if everything is normal. Naming changes on these rails due to them going through sensors etc.
Check for presence of PP5V_S4, PP3V3_S4, PP3V3_S0 and SMC_LID at the connector. If the board has been previously worked on, then I would go over the entire board looking for damage (like missing hall sensors on either side of the board and damaged Touchbar connector etc).Comment
smc lid is reading 1.8 in diode mode but it's supposed to be OL. Might that be problem aswellPPBUS_G3H will vary up and down depending on the voltage of the battery, so I don't believe that is the source of your problem. Measure it without battery connected and it will be 12.6V if everything is normal. Naming changes on these rails due to them going through sensors etc.
by gabrielA7Hey guys!!
I’ve got a question here!
I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
Here’s what the bot told me:
I said to him: “I’m going to install the 821-01229-A.”
ChatGPT replied:Understood — but before you solder or install the 821-01229-A,...11-11-2025, 03:26 PM -
by DanielreinaaHola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
Channel: BIOS Requests ONLY!
by capon5153hello,
so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN -
by obelix24I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
There were some broken pads under CD3215 but i've recreated them.
What should be...05-22-2024, 08:04 AM -
by johnbetonHello,
I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
This is what I measure so far:
Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
PPBUS_G3H = 0,79v
PPBUS_HS_CPU = 0,79v
PPBUS_HS_OTH5V = 0,79v
PPBUS_HS_OTH3V3... - Loading...
