Macbook A1706 works perfectly but no data on USB C
  • capon5153
    • Apr 2019
    • 21
    • Belgium
    hello,
    so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
    i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
  • mon2
    • 14262
    Review the resistance to ground on PPBUS_HS_OTH5V (with no power to the board of course).
    What is the voltage to ground of PPBUS_HS_OTH5V ?
    Next review U7650 which uses the above rail to create PP5V_S4.
    Measure the voltage to ground of PP5V_S4. If this rail is missing, be sure the PPBUS_HS_OTH5V ​is present and also the enable pin for this rail is active = P5VS4_EN.
    Other rails to measure are:
    PP5V_S4_T_USBC
    PP5V_S4_X_USBC
    • capon5153
      • Apr 2019
      • 21
      • Belgium
      hi,
      i measure 15.7V on PPBUS_HS_OTH5V on the C7600
      1.348Mohm on C7601 for PPBUS_HS_OTH5V
      no visible damage on or around U7650
      PP5V_S4 is 5.11V
      PP5V_S4_T_USBC between 0V and 0.13V
      PP5V_S4_X_USBC​ 0V
      • capon5153
        • Apr 2019
        • 21
        • Belgium
        any sugestions.??
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • Danielreinaa
          HELP need password bios Macbook A1706
          by Danielreinaa
          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
          09-07-2024, 03:47 PM
        • B2L_Repairs
          Macbook A1706 touchpad and keyboard not working. Please help
          by B2L_Repairs
          Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
          10-09-2023, 04:56 AM
        • obelix24
          A1706 - Macbook pro - one USB-C port only 20V 0A
          by obelix24
          I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
          I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
          There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
          There were some broken pads under CD3215 but i've recreated them.
          What should be...
          05-22-2024, 08:04 AM
        • johnbeton
          Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
          by johnbeton
          I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
          Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
          This is what I measure so far:
          Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
          PPBUS_G3H = 0,79v
          PPBUS_HS_CPU = 0,79v
          PPBUS_HS_OTH5V = 0,79v
          PPBUS_HS_OTH3V3...
          05-21-2024, 02:06 PM
