MacBook Pro 15" 2017 A1707 Touchbar No power
  • powerblackout
    • Feb 2018
    • 109
    Re: MacBook Pro 15" 2017 A1707 Touchbar No power
    Originally posted by openminded
    I understand from the repair wiki that if LDO 1.1 is not short and no voltage, it is the CD3215.
    The one I read said lack of 1.1 LDO means it's a ROM issue, try replacing the ROM chip? Can you measure the voltage on your MISO and MOSI lines to the chip?
    Here's another thread I found: https://boards.rossmanngroup.com/thr...ldo_bmc.58788/
    If we could get a few dumps of good ROMs It would be interesting if this would fix the 1.1v issue..
    • openminded
      • Apr 2017
      • 73
      • home
      #62
      hi, thanks that is a great find! I have no voltage on both pins.
      Also no short. I found the chip here:
      https://www.ebay.com/itm/312661170913
      but I am not sure if I want to invest that.
      The chip looks good and no power so perhaps problem is power?
      Also interestingly I saw no R4106 is on my board, but it does not look like fallen off.
      Chip looks clean too but I have cleaned it before so may indeed be dead.
      Then I saw R4104 is missing which should power the SPI rom U3906!
      Unfortunately no 1.8V on the incoming track there but I think I should try to fix that first . Some light in the darkness, thanks a lot!
      [update] R4104 contacts do not look like something was there either. may be it should not be there?
      SOC_ROM_SPI_MISO_R read about 0.09V on pin 2 of R4450.
      again no short around there.
      How likely is it to be the chip?
      • openminded
        • Apr 2017
        • 73
        • home
        #63
        I watched https://www.youtube.com/watch?v=alhLFikA3g8 after watching the wiki again. Then I understood the ROM is the TB ROM, U2895 not the EFI ROM (SPI?).
        That actually looks like it could be my problem.
        I do not have a donor board so I will check chip price and post if news. Glad to still be going and learning, even with no reward of a working board, it is rewarding to learn from all of you guys sharing knowledge.
        Thanks a lot!
        • powerblackout
          • Feb 2018
          • 109
          Do you have a programmer? I can send you a ROM file off of a working TBT chip and you could try flashing it onto yours.
          If you purchase a new chip it's not going to have the firmware the CD3215 chips required to get 20v, you'll need to program it unless you get a used one off of a board.
          • openminded
            • Apr 2017
            • 73
            • home
            #65
            Hi, yes I do, just not sure if I have the proper connector, but can order that.
            Do you mean programming the current chip or a new one?
            Do you have a good link for a replacement chip on ebay?
            BIOS image is appreciated, found them on Rossman forums but behind paywal.
            My board is 820-00281-A.
            Thank you!
            • openminded
              • Apr 2017
              • 73
              • home
              #66
              I found : https://www.aliexpress.com/item/1005003614452960.html
              My U2890 shows :
              *-8029B ( star is unclear, B might be 8 or 9)
              300 (or 800 )
              MX25
              U3235F
              If only the last two lines are important I can order that one and try to program.
              • powerblackout
                • Feb 2018
                • 109
                I just found a donor board that was able to get 20V, swapped the TBT ROM but still had the same issue, so your ROM might be fine.
                Do you have an oscilloscope? Push it up against the MISO line going into the CD3215 and plug the board in, if you see a short burst of traffic your ROM is probably fine and your problem elsewhere.
                • openminded
                  • Apr 2017
                  • 73
                  • home
                  #68
                  Originally posted by mon2
                  A1707 is about power delivery.
                  Power delivery (PD) lines are the CCx lines on the USB Type C connectors.
                  Check the diode readings for the:
                  CCx lines
                  D+ / D- lines
                  (Meter in diode mode. Red meter (yes, RED) to ground. Black to point to test).
                  Most of the boardview files offer DIODE reading values of a known good board. Compare your values against the reference values.
                  hi, sorry I somehow missed this @mon2 .
                  here they are :
                  u3100:
                  cc1 : 0.59
                  cc2 : 0.59
                  u3200
                  cc1: 0.58
                  cc2: 0.74
                  ub300:
                  cc1: 0.56
                  cc2: 0.57
                  ub400:
                  cc1: 0.56
                  cc2: 0.57
                  @powerblackout I have 3.3V on UB2890.
                  Have an oscilloscope to borrow but never used so would need more instructions.
                  About missing R41*, those are fine, the do not match the schematics as i saw in the video from Paul Daniels.
                  CB214 I pit back it should be fine.
                  Do te diod readings say anything?
                  Feel free to post that ROM file anyway, can be useful because hard to find.
                  Can you explain what do to with the oscilloscope?
                  The ROM chip had some liquid spill so it might actually be that in my case.
                  Thank you again for the help and support.
                  For convenience, please find the schematics attached that I am using.
                  I ordered some chips, they were cheap, I hope they are the rights ones.
                  I'll try to take this all the way, since I have kind of given up on being able to fix it, so it would be absolutely awesome if we can pull it off anyway
                  • mon2
                    • Dec 2019
                    • 14010
                    u3200
                    cc1: 0.58
                    cc2: 0.74
                    U3200 readings are off. Have you replaced this controller? It should be replaced with the same part #.
                    • openminded
                      • Apr 2017
                      • 73
                      • home
                      #70
                      Thank you, what should the readings be? can“t find it in openboardview.
                      I replaced it with a new one ( replaced it before but it looked bad )and now it reads 0.53 at both cc points.
                      Also, it boots with the plug both sides in now - but again to 5.2 V and no rebooting.
                      More interestingly, UB300 and UB400 side do not go on on any plug orientation now. They used to work both, where one only on one side of USB-c orientation.
                      The USB power meter I use inline does not go on now on either UB300 or UB400, the diode measurments are the same.
                      Ideas are welcome, I spend a $100 on CD3215s now, not even sure if supplier chips were good. This is getting very difficult...
                      I'm kind of done switching CD3215 chips on this board, I get the feeling something may be wrong with it that destroys them, or is that not possible ( or should not)?
                      Thanks for all the help, hope there is a solution.
                      • mon2
                        • Dec 2019
                        • 14010
                        Good on the diode reading. From my google-fu experience, the diode readings should be ~0.55 on a good CCx pin.
                        Earlier, the CC2 reading was much higher so it was a suspect.
                        Remove all power / no battery.
                        Meter in DIODE mode.
                        Red meter probe (yes RED) to GROUND.
                        Black meter probe on each LDO pin on the CD3215. Measure & post the readings for each CD3215 on the logic board.
                        On other comments - yes, this is a very frustrating and expensive hobby. In the end, there may be no solution for a fix. It is a man vs. machine challenge. Just the same, the experience is priceless, once it is working. The next round will be much easier to tackle.
                        • fr.iglesias
                          • Dec 2021
                          • 3
                          • spain
                          #72
                          Hi friends, does anyone have the TBT ROM firmware for A1798 820-00875A motherboard?,
                          I“ll be really gratefull if someone could help me with this.
                          Thanks in advance!!
                          • fr.iglesias
                            • Dec 2021
                            • 3
                            • spain
                            #73
                            Sorry I mean A1708 motherboard Macbook Pro 13 2016 year
                            • openminded
                              • Apr 2017
                              • 73
                              • home
                              #74
                              Thanks for the help and the peptalk !
                              I have to say I love the learning anyway and to interact with the community like this, so I will try to keep it going .
                              The readings for LDOs are:
                              u3100 :
                              pp1v8_upc_xa_ldod : 0.466
                              pp3v3_upc_xa_ldo : 0.482
                              pp1v1_upc_xa_ldo_bmc : 0.498
                              pp1v8_upc_xa_ldoa : 0.503
                              u3200
                              pp1v8_upc_xb_ldod : 0.460
                              pp3v3_upc_xb_ldo : 0.483
                              pp1v1_upc_xb_ldo_bmc : 0.477
                              pp1v8_upc_xb_ldoa : 0.496
                              ub300:
                              pp1v8_upc_ta_ldod : 0.453
                              pp3v3_upc_ta_ldo : 0.450
                              pp1v1_upc_ta_ldo_bmc : 0.475
                              pp1v8_upc_ta_ldoa : 0.000
                              ub400:
                              pp1v8_upc_tb_ldod : 0L ( so nothing? ) groundpin is 0.000
                              pp3v3_upc_tb_ldo : 0L again
                              pp1v1_upc_tb_ldo_bmc : 0.478
                              pp1v8_upc_tb_ldoa : 0L again
                              I got a funny feeling about UB400 .
                              What do you think is up?
                              Thanks again!
                              • mon2
                                • Dec 2019
                                • 14010
                                ub300:
                                ub400:
                                I think that both UB300 & UB400 have issues.
                                Configure your meter in resistance mode.
                                For UB300, measure & post the resistance to ground of the pp1v8_upc_ta_ldoa rail.
                                • openminded
                                  • Apr 2017
                                  • 73
                                  • home
                                  #76
                                  Hi, thank you for the quick reply!
                                  I measure about 0.9 Ohm in the beginning and then it slowly drops to 0 in about 20 seconds.
                                  Measuring the ground pin of that cap shows 0 first and then goes up a bit.
                                  bad cap ? Measuring in bleep mode gives bleep, so looks like a short on it.
                                  • mon2
                                    • Dec 2019
                                    • 14010
                                    Yes, could be a bad cap. What is the history of this CD3215 ? Was it replaced?
                                    If yes, could also be soldering of the replacement part.
                                    There is only 1 cap on this rail - see attached. Remove it and check the resistance to ground again for the same rail.
                                    If there is still a short then the fault is in the soldering.
                                    Proceed to apply flux on the top of this IC and hover over the CD3215 in circles till you cover the top surface with enough heat to melt the balls.
                                    Use tweezers to gently nudge the IC - 'make it dance'. Then the IC will naturally bounce back into position - do this 2-3 times and the chip should settle onto the proper pads. Remove the heat. Allow it to cool and check the resistance of this rail again.
                                    If the rail does return to normal (it should) then place the innocent cap back on, unless the cap is guilty.
                                    • openminded
                                      • Apr 2017
                                      • 73
                                      • home
                                      #78
                                      I was a bit confused, but I think you mean CB306 because it is the LDOA rail?
                                      CB305 resistance was very high.
                                      I moved CB300 - it was replaced before - after that CB306 reading is better : 0.484 with diode mode on ldoa rail .
                                      New diode readings:
                                      ub300:
                                      pp1v8_upc_ta_ldod : 0.443
                                      pp3v3_upc_ta_ldo : 0.466
                                      pp1v1_upc_ta_ldo_bmc : 0.471
                                      pp1v8_upc_ta_ldoa : 0.487
                                      ub400 after same treatment:
                                      pp1v8_upc_tb_ldod : 0 - the cap cb405 is off
                                      pp3v3_upc_tb_ldo : 0.567
                                      pp1v1_upc_tb_ldo_bmc : 0.473
                                      Does this mean the UB400 is bad or anything else?
                                      Not connected properly when measuring 0L ?
                                      I will try to replace it again, or move again, this one needs a lot of heat to move and CB305 came off along the way .
                                      Thanks for the help, seems UB300 is ok now?
                                      • mon2
                                        • Dec 2019
                                        • 14010
                                        Yes, ub300 looks good now.
                                        But ub400 needs some love.
                                        Apply flux and reflow it. We want similar diode readings like ub300.
                                        • openminded
                                          • Apr 2017
                                          • 73
                                          • home
                                          #80
                                          man, what a journey ! Could not get ub400 4th point to work. It came off eventually, but I had no reballing tools. Felt lucky, cleaned and fluxed and got it back on with all LDO readings between 0.45 and 0.49 now!
                                          2 caps came off, took an hour to get back, but made it!
                                          All excited, but this is the situation now:
                                          Upper ubc-c port only went on in one plug direction - then it shows 5.19 volt, but now 0.565 amps ( was much lower before, like 0.015-0.150).
                                          Felt that UB300 became warm, so it seems sometimes goes wrong there.
                                          Unplugged in time and still have same LDO reading on UB300 about, so it seems fine.
                                          The other ports don“t do anything at the moment, neither direction.
                                          I am wondering if I got further or not ?
                                          I feel stuck again, although I am happy with the newly acquired understanding and skills.
                                          Happy to get any tips to proceed. Thank you
                                          • sofles
                                            Macbook a1707 2017 model 820-00928 GPU issue
                                            by sofles
                                            Hello there
                                            I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                            I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                            11-21-2024, 05:25 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • modtool
                                            Macbook Pro A1989 fallen, reboots if touchbar connected
                                            by modtool
                                            Hi to all,
                                            the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
                                            Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
                                            11-10-2023, 07:42 AM
                                          • kurtspirit
                                            Macbook A1706 EMC3071 (2017 Touchbar)
                                            by kurtspirit
                                            I have a Macbook Pro 2017 Touchbar (A1706) that suddenly shut down for no reason.
                                            So I took it apart and started measuring.
                                            The PP3V3_G3H seems problematic. I traced the line to component U6903 and on Pin 10, I measured 1.9V instead of 3.3V.
                                            Unfortunately, my skills stop there and I don't understand where this type of failure can come from.
                                            I saw on videos of repairers that the failure could come from the U7000 component which would be at the origin of the 3.3V but they have absolutely no voltage. I have a 1.9v...
                                            What do you think ?...
                                            08-23-2022, 05:57 AM
                                          • leonemax81
                                            Macbook a1707 820-00281 Battery no Power
                                            by leonemax81
                                            Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                            08-23-2024, 09:24 AM
