X550jx black screen but cpu heating up
  • questore
    • Dec 2015
    • 563
    • csongrád
    Hello everyone thanks for your time reading this.
    I have an asus x550jx laptop. The internal screen has given up so i only have external monitor to test.
    The last two days when the laptop was working it was extremly slow (only like 3fps) when i tested gpu-z but working without a problem. One day i have a BSOD and then windows halted on boot with TRAP 00000030.
    Removed every hdd, dvd drive but windows usb installer still thrown trap 30. Then after some restart the asus logo freezed uppon post and thats all. Black screen since then. 1 min powerbutton without any battery,cmos or ac connector but still the same.
    Symptoms:
    after power removed and 1 min power button holding, it starts with power+ num lock + caps lock lit, no blinks. Can only power off by holding power button for 6 sec. Then 2nd power on. Still blackscreen but onyl power+num lock lit. Cpu is slowly heating up after some time, and cpu fan starts to spin.
    Tried ctrl+home bios flash but not seeing anything so dont know if it worked.
  • questore
    • Dec 2015
    • 563
    • csongrád
    Re: X550jx black screen but cpu heating up
    further info:
    Got an USB pendrive with led indicator, ctrl+home not racting to and bios file naming. X550JX.bin X550JXAS.bin X550JX.rom X550JXAS.rom X550J.bin X550J.rom. When i hit power button the usb led flashing once and thats all.
    • Techtiger
      • Oct 2014
      • 1602
      • france
      Originally posted by questore
      further info:
      You need a Special tool to do this job & a working BIN , dissemble the MOB & find out what voltages are missing on the BIG GRAY Coils , check this out https://www.badcaps.net/forum/showthread.php?t=88758
      • questore
        • Dec 2015
        • 563
        • csongrád
        Thanks I have very few spare time but maybe i learn something. Tools... i have everything i think. I post the results of voltages when i have them. Thank you.
        • questore
          • Dec 2015
          • 563
          • csongrád
          Can anyone link me a schematic diagram? (I have found the Boadview)
          • questore
            • Dec 2015
            • 563
            • csongrád
            Just had to ask for it and found it
            Block diagram for X550JF/X550XJ
            Boardview:X550JF/X550JX
            https://www.badcaps.net/forum/showthread.php?p=995106
            Last edited by SMDFlea; 10-14-2020, 06:35 AM. Reason: no need to post same files again,just post a link
            • questore
              • Dec 2015
              • 563
              • csongrád
              I have measured the following values:
              ALL_SYS_PWRGD 3,35v
              VCCIN 1,745v
              VRM_PWRGD 3,36v
              CORE_PWRGD 3,3v
              PM_PWROK 3,3v
              H_DRAM_PWRGD + - + - + -
              DRAMPWROK 0,877v
              PM_SYSPWROK 3,3v
              BUF_PLT_RST 3,3v
              +NVDD 0,89v
              Seems that the ram power is not high enough as i see it.
              Anyone have an idea where to go next?
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Yep on bord RAM ? Try with a another Ram find out the voltage on RAM slot DRAMRST May be pin 30
                • questore
                  • Dec 2015
                  • 563
                  • csongrád
                  With only onboard RAM yes!
                  DRAMRST 1.35V with another ram in slot.
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    check the voltage on R0338 R0341
                    • questore
                      • Dec 2015
                      • 563
                      • csongrád
                      DRAMRST 1.35V with 1 extra ram in slot. (both R0338 R0341)
                      • questore
                        • Dec 2015
                        • 563
                        • csongrád
                        Should i check DRAMPWRGD shorted?
                        • Techtiger
                          • Oct 2014
                          • 1602
                          • france
                          what is the voltage on R0332 both sides ? what is the value of the resistor R0332 R0338 check with the multimeter with out power
                          • questore
                            • Dec 2015
                            • 563
                            • csongrád
                            Without power:
                            R0332 - 50.3 Ohm
                            R0338 - 1.7 kOhm
                            Voltage i will check tomorrow cause cpu is heating if i remove the heatsink and the R0332 can only be measured if heatsink is off. I figure something out
                            • questore
                              • Dec 2015
                              • 563
                              • csongrád
                              R0332 - 0V
                              both left and right side is 0 voltage.
                              What's next?
                              • questore
                                • Dec 2015
                                • 563
                                • csongrád
                                More information to you:
                                PL8001 and PL8003 both +VCCIN and should be 1,745v but PL8001 is 0v. What the hell?
                                • questore
                                  • Dec 2015
                                  • 563
                                  • csongrád
                                  A short followup about private messages:
                                  - R0322 is a shorted place and measured also 0.8v
                                  - R0342 is an empty place. Both side 0v
                                  The next step would be to measure the followings:
                                  - both side of R0338 R0335 R0337 R0336
                                  - U0303 all pins
                                  durring the measures the laptop condition changed:
                                  Now it starts and Power+Caps lock LED lights up and stays on but after 10 seconds, the laptop shuts off.
                                  • questore
                                    • Dec 2015
                                    • 563
                                    • csongrád
                                    - U0303 all pins
                                    I have made a stupid mistake. CPU fan was not correctly plugged, thats why condition changed.
                                    Update. Only Numlock+power led stays lit.
                                    Measurements:
                                    - U0303 Pins.
                                    1. 3.3v
                                    2. 3.3v
                                    3. 0v (GROUND)
                                    4. 0.8v (also checked its not sorted to ground)
                                    5. 3.3v
                                    R0335
                                    1. 1.35v
                                    2. 0.8v
                                    R0336
                                    1. 0.8v
                                    2. 0v (ground)
                                    R0337
                                    1. 3.3v
                                    2. 3.3v
                                    R0338
                                    1. 0.8v
                                    2. constanly changing (cant measure)
                                    • questore
                                      • Dec 2015
                                      • 563
                                      • csongrád
                                      I'm thinking that accoring to datasheet SOT353 5 pin:
                                      if the
                                      input1=HIGH (3.3v) and
                                      input2=HIGH (3.3v) and
                                      VCC=3.3v
                                      then isn't the output should be 3.3v??
                                      Does U0303 faulty?
                                      • questore
                                        • Dec 2015
                                        • 563
                                        • csongrád
                                        Measured further cause power sequence should point the problem:
                                        PM_SYSPWROK 3.3v
                                        BUF_PLTRST 3.1v
                                        PCH_PLTRST_CPU 1.0v
                                        Ordered a BIOS USB flasher and try to flash chip
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
