X550jx black screen but cpu heating up
  • questore
    • Dec 2015
    • 563
    • csongrád
    Re: X550jx black screen but cpu heating up
    Bios flashed from a same machine, but no change.
    Removed u0303 and its surely faulty (0.8v dram_pwrok still)
    I'm ordering replacement. Get back when replaced
    • questore
      • Dec 2015
      • 563
      • csongrád
      After replacing U0303 with this:
      https://hu.farnell.com/nexperia/74lv...-ddd7-00001003
      - DRAMPWROK is now 2.45V
      - CPUPWROK és still 1v.
      Whats next? DRAMPWROK resistance to ground is 1.17KOhm so its not sorted. Why is it still low?
      • questore
        • Dec 2015
        • 563
        • csongrád
        Ok I have read some intel startup sequence thread and figured out the following, PLEASE let me know if I'm right or wrong:
        - DRAMPWROK should be larger than 1.05 so v2.45V is - GOOD
        - CPUPWRGD 1.05v - GOOD
        - PLTRST and BUF_PLTRST 3.3v - GOOD
        - CPURST 1.05v - GOOD
        So assuming South bridge and CPU is good and communicating. Right?
        Next step would be to know if CPU is reading BIOS. Then Starting RAM How can I know that??? HELP NEED.
        • questore
          • Dec 2015
          • 563
          • csongrád
          PM_RSMRST = 0.045v
          Is my BIOS corrupted? HELP
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            If rsmrst# is not high it means KBC is not communicating with bios chip
            First flash bios chip but If problem not resolved, first check KBC is working properly by checking it's requirements if ok then you have to programme KBC as well if programme able
            For correct me region match
            • questore
              • Dec 2015
              • 563
              • csongrád
              #26
              BIOS FLASHED and PM_RSMRST is now 3.3v
              Problem still the same. Black screen.
              How to proceed?
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                #27
                Every mb has different signal routine but anyhow
                Confirm again ec_on
                Confirm SLP_s5# which is always state
                Slp_s4# Which is sus state for ram
                Slp_s3#. Which is run state for GPU and vccsa etc
                • questore
                  • Dec 2015
                  • 563
                  • csongrád
                  #28
                  - EC_RST 3.27v (I do not know if this is what you mean by EC_ON)
                  - SLP_S3 3.3v
                  - SLP_S4 3.3v
                  - SLP_S5 3.3v
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    #29
                    In some cases it is written as Suson or mainon
                    First check if CPU is giving signal to ram
                    Dramrst# it is same as your ram voltage 1.35
                    Check gfx supply voltage around 0.45voltage and CPU core voltage
                    Then check ram section
                    Ram coil voltage 1.35 v for DDR3L
                    Ram vtt voltage at ram slot pin= half of 1.35
                    Ram SPD voltage 3.3v
                    If you are getting these voltage then check with DSO
                    Rtc clock generated or not
                    If all ok
                    Just remove CMOS cell for 30min and put it back and turn on
                    Btw you have a power sequence diagram which voltage step is missing did you check from 24 to onwards, check step by step do not skip
                    • questore
                      • Dec 2015
                      • 563
                      • csongrád
                      #30
                      POWER SEQUENCE VALUES
                      1 +3VA - 3.3v / +5VA - 5V
                      2 PS_ON - 3.3v
                      3 +3VA_EC - 3.3v
                      4 EC_RST - 3.27v
                      5 3VDSW_ON - 3.3v
                      6 3VA_DSW_PWGD - 3.3v
                      7 DPWROK_EC - 3.3v
                      8 ME_AC_PRESENT - 3.3v
                      9 PCH_SLPSUS# - 3.3v
                      10 5VSUS_ON - 3.3v
                      11 3VSUS_ON - 3.3v
                      12 5VSUS_PWRGD - 3.3v
                      13 +3VSUS_PWRGD - 3.1v
                      14 PM_RSMRST# - 3.3v
                      15 PCH_SUSACK# - 3.3v
                      16 ME_SuspwrDnAck - 16 mv
                      17 PWR_SW# - 3.27v
                      18 PM_PWRBTN# - 3.3v
                      19 PM_SUSC# - 3.3v
                      20 PM_SUSB# - 3.3v
                      21 SLP_A# - 3.3v
                      22 SUSC_EC# - 3.28v
                      23 SUSB_EC# - 3.3v
                      +1.2VS - 16mv
                      24 1.35V_PWRGD - 3.3v
                      25 1.05VS_PWRGD - 3.3v
                      26 P_1.5VS_PWRGD - 3.3v
                      - CMOS battery removed for 1 day but no change
                      - VDD 0.9v (GFX??)
                      - Dramrst# 1.347v
                      - Ram coil voltage 1.35v
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        #31
                        Do power button voltage goes to zero when you press it
                        And what is +1.2vs where you have 16mv, is there spelling mistake?
                        • stingerchamp
                          • Sep 2020
                          • 425
                          • Pakistan
                          #32
                          Is it Up0104ssw ic sO-8
                          • questore
                            • Dec 2015
                            • 563
                            • csongrád
                            #33
                            Power button voltage is constant 3.3V and does NOT goes down when i press it.
                            +1.2VS 16mv is not a spelling mistake. It is measured at R4602 but maybe it because U4601 area is completly missing from this kind of board by default.
                            What do you mean by "is it Up0104ssw ic sO-8" ? Please elaborate.
                            • stingerchamp
                              • Sep 2020
                              • 425
                              • Pakistan
                              #34
                              It is a ldo switch ic which is generating voltage 1.2v etc check your power sequence diagram
                              Power button one side is connected to ground and other side connected to board circuit
                              It is a temp switch which connects 3.3v present at button to ground for 2 second means 0volt and then retains/becomes 3.3v again so it must go down for couple of sec. Check again.
                              If still same then try to turn on by shorting connector pins if y don't know then leave it
                              Reprogramme your KBC if it is reprogrammable and check
                              • emestee
                                • 228
                                #35
                                Does the resistance of the button change when you press it? Maybe it's just a bad button.
                                • questore
                                  • Dec 2015
                                  • 563
                                  • csongrád
                                  #36
                                  Resistance to button does not change.
                                  Its always OL. Could it be that a bad button does this.
                                  If i remove the button and plug the power adapter then the laptop does the same as with button connected.
                                  Laptop now does the following when i plug it in to AC:
                                  Starts for 4 seconds. (Power +numlock+capslock led constant, then turnds off for 3 second and starts again, but this time only power+numlock lit constantly.
                                  Cpu and pch os heating slowly and fan starts spinning.
                                  • questore
                                    • Dec 2015
                                    • 563
                                    • csongrád
                                    #37
                                    It seems that 1.2v generator and all around it the board is missing all components so asuming its for another model.
                                    ME_SuspwrDnAck 0v is still mystery.
                                    • emestee
                                      • 228
                                      #38
                                      If youve already pulled out the button then test it out of circuit and you'll know if it's bad. When the button is out, you should of course short its pads to see if you get a reaction.
                                      • questore
                                        • Dec 2015
                                        • 563
                                        • csongrád
                                        #39
                                        OK I was a fool Rechecked the power button switch circuit:
                                        - when power button not pressed +3VA_BD is 0v
                                        - when power button pressed then +3VA_BD is 3v for 1 second then goes to 0 again. Sorry for the mistake.
                                        Back to square 1.
                                        Why does it starts itself without pressing the power button?
                                        • stingerchamp
                                          • Sep 2020
                                          • 425
                                          • Pakistan
                                          #40
                                          Check crystal oscillator
                                          If you have DSO or oscilloscope check 32khz clock available or not and keep it checking for 10sec
                                          Make sure voltage on rtc cell 3 voltage
                                          If you have xtal clock for PCH check xtalin and out for 14mhz clock available or not
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • smic717394
                                            by smic717394
                                            07-25-2024, 10:16 AM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • spice_disc
                                            Vizio TV M50-C1 reboot cycle and static on screen
                                            by spice_disc
                                            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                            09-08-2024, 02:37 PM
