X550jx black screen but cpu heating up
  • questore
    • Dec 2015
    • 563
    • csongrád
    #81
    Re: X550jx black screen but cpu heating up
    P_+3VSUS_CT2_10 and P_+3VA_EC_CT1_10 are both
    5.5 volts I think this is not correct.
    • questore
      • Dec 2015
      • 563
      • csongrád
      #82
      Partial summary:
      - GOOD NEW IS: Automatic power on when AC pluged in reason was a bad CMOS battery pin. When I have mesured the cmos battery right in the connector plus side it was only 0.3 volts. After bended the pin 3.05v presented and it won't start automaticaly when AC plugged in.
      - BAD NEW IS: durring the last bios chip resoldering I have made something that made the laptop not responding to start button.
      Next step is to find out why I cannot turn on the laptop.
      I hear a high pitched noise when AC plugged in somewhere around the bios chip but can't realy tell where its coming from.
      Inspecting with microscope... to be continued.
      • questore
        • Dec 2015
        • 563
        • csongrád
        #83
        Current Power sequence:
        1 +3VA = 3.31
        / +5VA = 5.06v
        2 PS_ON =3.31v
        3 +3VA_EC =3.30v
        4 EC_RST =3.27v
        5 3VDSW_ON =3.27v
        6 3VA_DSW_PWGD =3.37v
        7 DPWROK_EC =0v
        BIOS pins:
        1 = 0.3v
        2 = 2.84v
        3 = 3.1v
        4 = GRN 0v
        5 = 0.55v
        6 = 1.38v
        7 = 3.1v
        9 =3,09v
        Now Help needed
        • questore
          • Dec 2015
          • 563
          • csongrád
          #84
          - Reflowed PCH since i did not shilded it when replaced BIOS chip.
          - did a clean ME on the Original Bios bin file with "Intel Easy Clean Me"
          Currently the laptop starts and capslock + numlock + power led lights up. (Still black screen)
          Readings:
          1 +3VA - 3.3v
          / +5VA - 5.05v
          2 PS_ON - 3.3v
          3 +3VA_EC - 3.3v
          4 EC_RST - 3.27v
          5 3VDSW_ON - 3.31v
          6 3VA_DSW_PWGD - 3.3v
          7 DPWROK_EC - 3.3v
          8 ME_AC_PRESENT - 3.3v
          9 PCH_SLPSUS# - 3.3v
          10 5VSUS_ON - 3.3v
          11 3VSUS_ON - 3.3v
          12 5VSUS_PWRGD - 3.3v
          13 +3VSUS_PWRGD - 3.1v
          14 PM_RSMRST# - 3.3v
          15 PCH_SUSACK# - 3.3v
          16 ME_SuspwrDnAck - 3.3v
          17 PWR_SW# - 3.3v
          18 PM_PWRBTN# - 3.3v
          19 PM_SUSC# - 3.36v
          20 PM_SUSB# - 3.3v
          21 SLP_A# - 3.3v
          22 SUSC_EC# - 3.4v
          23 SUSB_EC# - 3.3v
          +1.2VS - 0v
          24 1.35V_PWRGD - 3.3v
          25 1.05VS_PWRGD - 3.3v
          26 P_1.5VS_PWRGD - 3.3v
          27 ALL_SYSTEM_PWRGD - 3.3v
          28 +VCCIN - 1.75v
          29 VRM_PWRGD - 3.3v
          30 CORE_PWRGD - 3.35v
          31 PM_PWROK - 3.3v
          32 H_DRAM_PWRGD - 0.5v
          33 DRAMPWROK - 2.45v
          34 H_CPUPWRGD - 1.04v
          35 SVID BUS - did not found any (VR_SVID_ALERT# 1.00v)
          36 PM_SYSPWROK - 3.3v
          37 BUF_PLT_RST# - 3.3v
          After watching closely the integrated ram i noticed a high pitched sound is coming from around U1501 RAM chip.
          So My guess is one of C1316, C1412, C1522, C1424, C1414, C1415 is partialy wrong.
          Im going to remove them one by one and see if the high pitched sound disappears. If you have better idea then tell me please.
          • questore
            • Dec 2015
            • 563
            • csongrád
            #85
            Capacitor changed no result. Nothing changed.
            I have no other idea
            Anyone can help me why H_DRAM_PWRGD is low?
            • questore
              • Dec 2015
              • 563
              • csongrád
              #86
              I Have noticed something. H_DRAM_PWRGD is a signal that supposed to go from PCH to CPU. I'm I right?
              So why does it not going to CPU? Both R0338 and R0341 are not existing Resistors.
              • questore
                • Dec 2015
                • 563
                • csongrád
                #87
                ACZ_SDOUT has a sort to ground.
                I have to replace the PCH
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  #88
                  What's the exact resistance to ground on ACZ_SDOUT?
                  • questore
                    • Dec 2015
                    • 563
                    • csongrád
                    #89
                    ok false alarm multimeters red wire was not plugged in correctly,sorry.
                    • questore
                      • Dec 2015
                      • 563
                      • csongrád
                      #90
                      I managed to get a good board and did some readings on resistors.
                      The main differences are:
                      R0347 - 10kohm ( 90Kohm on good board)
                      R0338 - 3.2Kohm (this was 1.7Kohm when i started the diag and 1.75Kohm on good board)
                      R0336 - 3.1Kohm (1.75 Kohm on good board)
                      Should I replace R0338 and R0336 with 1.8Kohm resistor?
                      What about R0347? Is iteven possible that a resistance is lowered when a resistor fails?
                      • questore
                        • Dec 2015
                        • 563
                        • csongrád
                        #91
                        Changed battery on multimeter and Remeasured everything.
                        R0347 - 89.7Kohm on bad boards so its good.
                        R0338 - 3.75Kohm (1,75 on good board)
                        R0336 - 3.2Kohm (1.2 on good boad)
                        Thinking on what has changed durring the u0303 replacement.
                        It is possible that R0336 resistance is risen because of u0303 replacement heat was too high.
                        Since R0338 is a non existing resistor and it can be that it connected through a 0.5kohm resistor somewhere to R0336 and it raised because R0336 raised.
                        Ordered new 1.2Kohm resistor with sample book (30 days) be back withthe result when replaced R0336.
                        • questore
                          • Dec 2015
                          • 563
                          • csongrád
                          #92
                          Replaced R0336
                          Now Resistances are same as a good board.
                          Only thing that has changed is H_DRAM_PWRGD risen to 0.74v
                          Searched for more clues on the board and found that PU8501 nvidia power management has a short on pin #10
                          P_NVVDD_FBRTN_10 0v and short tu ground.
                          pins readings are:
                          1 P_NVVDD_BST1_30 - 5v for a sec then 4.37v
                          2 P_NVVDD_HG1_30 - 0v
                          3 P_NVVDD_EN_10 - 2.84v
                          4 P_NVVDD_PSI_10 - 3,36v
                          5 P_NVVDD_VID_10 - 1.5v
                          6 P_NVVDD_REFADJ_10 - 1v
                          7 P_NVVDD_REFIN_10 - 0,9v
                          8 P_NVVDD_VREF_10 - 2v
                          9 P_NVVDD_OCS_10 - 1.33v
                          10 P_NVVDD_FBRTN_10 0v (short to ground)
                          11 P_NVVDD_FB_10 - 0v
                          12 P_NVVDD_COMP_10 - 0v
                          13 P_NVVDD_PG_10 - 0v
                          14 P_NVVDD_HG2_30 - 0v
                          15 P_NVVDD_BST2_30 - 5v for a sec then 4.37v
                          16 P_NVVDD_LX2_30 - 0v
                          17 P_NVVDD_LG2_30 - 0vs
                          18 P_NVVDD_PVCC_20 - 5v
                          19 P_NVVDD_LG1_30 - 0v
                          20 P_NVVDD_LX1_30 - 0v
                          Seem like PU8501 is bad. Removing and lets see what happens
                          • questore
                            • Dec 2015
                            • 563
                            • csongrád
                            #93
                            Removed PU8501.
                            Ripped off half of the board with it cause of f*cking cheap heatgun.
                            Board is a Junk!
                            Thanks for the help!
                            Bye
                            • piernov
                              • Jan 2016
                              • 4439
                              • France
                              #94
                              P_NVVDD_FBRTN_10 is connected to ground so "short to ground" is expected.
                              • questore
                                • Dec 2015
                                • 563
                                • csongrád
                                #95
                                Thanks. I decided to make this board a "lab rat" and go on. I can't make it worse
                                • paulo66
                                  • Dec 2020
                                  • 88
                                  • Portugal
                                  #96
                                  Heh if you're like me I think you can! For instance, I've turned a board into a gooey mess just for trying several DIY fluxes.
                                  • questore
                                    • Dec 2015
                                    • 563
                                    • csongrád
                                    #97
                                    After Chip removed:
                                    3 P_NVVDD_EN_10 - 3.05v
                                    5 P_NVVDD_VID_10 - rapidly rising and lowering from 0v-2v fastly
                                    6 P_NVVDD_REFADJ_10 - 0v
                                    7 P_NVVDD_REFIN_10 - 0v
                                    8 P_NVVDD_VREF_10 - 0v
                                    9 P_NVVDD_OCS_10 - 0v
                                    10 P_NVVDD_FBRTN_10 0v (2 Ohm to ground)
                                    15 P_NVVDD_BST2_30 - 0v
                                    16 P_NVVDD_LX2_30 - constantly changing slowly between 0.7v-8v
                                    • István Bornemissza
                                      • Dec 2024
                                      • Hungary
                                      #98
                                      Hello everyone. If possible, I would like to continue this topic because I have the same issue. I have thoroughly measured the power sequence, and everything seems fine, yet it exhibits the same symptoms as the machine in the initial post.
                                      What I have as additional information is that there is no communication on the LPC lines. The PCH reads part of the BIOS from the flash IC. As far as I know, the crystals are working (25MHz crystal vs. 20MHz oscilloscope).
                                      The PCH SUS_CLK# clock signal is present.
                                      What could be worth investigating?
                                      • Ryan.man
                                        by Ryan.man
                                        02-04-2025, 12:23 PM
                                      • reformatt
                                        by reformatt
                                        07-31-2025, 08:37 PM
                                      • smic717394
                                        by smic717394
                                        07-25-2024, 10:16 AM
                                      • Chrissygizmo
                                        by Chrissygizmo
                                        02-10-2025, 12:33 AM
                                      • spice_disc
                                        Vizio TV M50-C1 reboot cycle and static on screen
                                        by spice_disc
                                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                        09-08-2024, 02:37 PM
