Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • rccrasher65
    • Mar 2014
    • 599
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    bump
    • rccrasher65
      • Mar 2014
      • 599
      bump
      • rccrasher65
        • Mar 2014
        • 599
        bump
        • rccrasher65
          • Mar 2014
          • 599
          Originally posted by rccrasher65
          bump
          bump
          • rccrasher65
            • Mar 2014
            • 599
            BlueMidnight, you out there? sorry I haven't been on lately. I had rotator cuff surgery, and couldn't do to much. I think I can get back to it. I'll get those voltages for you. I read in another thread, An HP board doing same thing as mine, ended up being a shorted cap. He was testing the same coils as we are, just wanted to point that out. Hope all is well.
            • rccrasher65
              • Mar 2014
              • 599
              BlueMidnight, you on here, finally able to get back at this board. That surgery and recovery definately suck. I can get those voltages for you. I want to get this board working, and then I think I'm going to sell off my equipment. eyes aren't getting any better either, can't see the small components anymore so I think it's time to move on. Let me know if you're a still interested in helping me get this board up and running. Thanks!
              • rccrasher65
                • Mar 2014
                • 599
                Bump
                • rccrasher65
                  • Mar 2014
                  • 599
                  Bump
                  bump
                  • rccrasher65
                    • Mar 2014
                    • 599
                    Bump
                    Can anyone pick up where BlueMidnight left off. Thanks
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      #250
                      There are 13 pages in this thread, I think nobody wants to go through everything so you should summarize the history of the machine, the symptoms, the troubleshooting process, what has been attempted and what's the blocking point now.
                      • rccrasher65
                        • Mar 2014
                        • 599
                        We can start with page 12 of thread, post 231, I have most voltages present, they are listed. fan will start for a sec, then shut off. I was about to check voltages Blue Midnight suggested.
                        • BlueMidnight
                          • Jan 2015
                          • 489
                          Sorry I've been away for a while. Yes, if you could measure those things you indicated that would be helpful. Read posts 234-237 and continue from there.
                          • rccrasher65
                            • Mar 2014
                            • 599
                            Welcome back, missed ya. I'll get on that. Should have some results in the next day or so , Christmas decorations in my work area. Nice to see you back!
                            • rccrasher65
                              • Mar 2014
                              • 599
                              BlueMidnight, I'm not getting any voltages, just MV readings I don't know what happened from last time. I got all the correct readings on this board. Now nothing. I can't even get anything on the power supply. No 19V, but both work correctly on my laptop. They both charge my laptop as it's supposed too. This is driving me crazy. I'm going to replace my battery in my Voltage meter, and check again. If no voltages show then, I'm done. I'm not buying another power supply or DC jack. That will pretty much end this board. I'll get back to you. Going to purchase new 9V batt. Not going to trust anything laying around. Thanks
                              • BlueMidnight
                                • Jan 2015
                                • 489
                                Well that's not good. Yeah, let me know if anything changes.
                                • rccrasher65
                                  • Mar 2014
                                  • 599
                                  It's my needle probes, I'll try with the one I have, but they are pretty thick. Going to have to order a new set of probes. I'll get what measurements I can get with these fat probes. What pins do you short to turn on board? 1-4 thanks for your patience.
                                  • BlueMidnight
                                    • Jan 2015
                                    • 489
                                    Short together pins 3 and 4 of connector CN5.
                                    • rccrasher65
                                      • Mar 2014
                                      • 599
                                      PL1 = 0.95 V
                                      PL6 = 1.5 V
                                      PL11 = +BATCHG
                                      PL12 = 3.3 V
                                      PL15 = 5 V
                                      PL16 = 1.8 V
                                      PL17 = +VCC_CORE
                                      PL18 = +VDDNB_CORE
                                      PL21 = +APU_VDDGFX
                                      PL25 = 0.95 V
                                      PL28 = 1.35 V
                                      Expect nothing for +BATCHG if no main battery connected. The other named ones are related to the CPU and GPU, and should be somewhere in the general vicinity of ~1-1.4 volts. The exact value varies.
                                      OK PL1-0.941V PL6-1.48V PL11-205.7mv PL12-3.367V PL15- 5.03V PL16-5.03V PL17-1.21V PL18-1.61V PL21- no coil on my board PL25-0.962V
                                      • BlueMidnight
                                        • Jan 2015
                                        • 489
                                        Your measurement for PL16 should hopefully be 1.8V .
                                        It seems this is a different variation of the board than the one you initially took photos of. There were different configuration options and some do have PL21 missing. If you don't have that, then you should have 2 more coils an inch or two away, near the curved edge of the board. The large coil is PL23 and the small coil is PL24.
                                        It seems to be getting far along in the power up sequence. The CPU has voltage and everything. If it were not getting past an earlier step in the sequence, we could try logically narrowing down the problem with measurements. But as it stands, you're probably looking at fun things like buying a chip programmer to attempt flashing a clean BIOS. From what you were saying before, we may want to stop here.
                                        • rccrasher65
                                          • Mar 2014
                                          • 599
                                          Yeah I think I made a mistake with PL16, I'll double check that. Maybe someone on here can flash a new bios, I certainly don't know what I'm doing with that kind of stuff. All 3 boards that I have, have different coils missing, was wondering that myself. but have the same board number. do you think someone on here can flash a bios, or should I just stop here.
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            06-30-2025, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
