Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • rccrasher65
    • Mar 2014
    • 626
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    Originally posted by BlueMidnight
    The next thing is to get it recognized by your PC. After you plug it in, it won't know how to use that device yet. You'll need to install the driver.
    The Colibri software posted above contains the newest driver. You'll need to use 7-zip to extract everything before trying to run the installer. The driver you want is in a file beginning with "CH341PAR". Run the setup program is inside there.
    Once the driver is installed, you can move on to checking out the software.
    Check out both programs if you wish. NeoProgrammer is probably the simpler of the two. You'll have to set the language to English in the menu though.
    After you get to this point, we will need to work on connecting the test clip to the programmer correctly.
    I'm a few days behind, I'm still working on modifying the programmer. I need to lift power pin 28 on programmer.
    It's a pain in the a__
    • BlueMidnight
      • Jan 2015
      • 489
      While heating it with the soldering iron, use something stainless steel that solder won't stick to (e.g. dental pick or screwdriver) to gently lift it. And, of course, never attempt to lift the pin with the iron itself. It may help to add some fresh solder first to aid melting. Once it's lifted up a bit, you can remove any solder bridge by using flux, desoldering braid, and or a solder sucker.
      If you really must, you could even just clip it off. But you'd need to make absolutely sure you leave enough of the pin to solder to. Add some fresh solder before removing as much solder as possible to expose the full length of the pin, clip off the bottom of the pin near the pad, and then use the soldering iron to sweep the cut-off bit away.
      • rccrasher65
        • Mar 2014
        • 626
        I'll give this a try, probably going to need a day or so.
        • rccrasher65
          • Mar 2014
          • 626
          I should be finished up with the mod this evening.Thanks for your patience.
          • rccrasher65
            • Mar 2014
            • 626
            Going to need a week or so to finish the mod of the programmer, I've had out of state relatives here for the last 4 days, so I could not work. If there is anything else I can do in the meantime, let me know. Thanks for your patience.
            • BlueMidnight
              • Jan 2015
              • 489
              There's nothing more to do until then.
              • rccrasher65
                • Mar 2014
                • 626
                Will probably be done on sunday, company leaving for Texas on sat.Thanks!
                • rccrasher65
                  • Mar 2014
                  • 626
                  bump! lifting this pin is being a pain in the A-- need to walk away! I will eventually get this.
                  • rccrasher65
                    • Mar 2014
                    • 626
                    Bump!
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      Did you lift the pin?
                      • rccrasher65
                        • Mar 2014
                        • 626
                        working on it, It's been a mad house at my place for the last few weeks. I'll get back at it in a day or so. Thanks for your patience. Had some long over due remodeling done after relatives left. Had to wait because of the Covid virus.
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 624
                          • Belgium
                          #312
                          Hi recrasher
                          Here you have an tutorial how you must do the modification.
                          Maybe it will help.
                          https://youtu.be/-ln3VIZKKaE
                          Best regards
                          Steve
                          • rccrasher65
                            • Mar 2014
                            • 626
                            Originally posted by Stevedb
                            Hi recrasher
                            Maybe it will help.
                            Best regards
                            Steve
                            thank you very much.
                            • rccrasher65
                              • Mar 2014
                              • 626
                              Modification is a success. 3.3V on data lines. Thank you for your patience.
                              • rccrasher65
                                • Mar 2014
                                • 626
                                What will be the next step?
                                • BlueMidnight
                                  • Jan 2015
                                  • 489
                                  That's great. Your firmware chip's input protection diodes will thank you.
                                  Now, the next step is to test reading some chips.
                                  Have you attempted to install the software for the programmer? Check the previews posts by Stevedb and myself.
                                  After you have the software working...
                                  Try reading the chip on one of those other boards. Try using the clip first.
                                  The dot and/or notch on the firmware chip indicates pin 1, so pin 1 of your clip should face that way. You can tell which wire goes to pin 1 because it is the only red one.
                                  Make sure you line up pin 1 all the way back to the programmer. Plug it the right way around into the little adapter board (pin 1 to pin 1). Then plug the adapter board into the socket on the programmer. Lift the lever, insert the pins, then close the lever.
                                  Use the guide drawn next to the socket. You are reading a "25XX" firmware chip, so place the pins of the adapter into the socket on the side closest to the USB port, and face pin 1 toward the opposite side (i.e. pin 1 will be near the middle of the socket).
                                  Then, try attaching the clip onto a firmware chip. When properly clipped onto the chip, the clip should stand straight up and down without leaning. Just open the jaws, press it down flat against the board, and then release the jaws until they grip the pins of the chip.
                                  Regardless of which software you use, press the button to identify the chip (confirm it matches what you see written on the top of the chip itself). Then, tell it to read the chip and see if information shows up on the screen.
                                  • rccrasher65
                                    • Mar 2014
                                    • 626
                                    Thank you, it will take awhile to sort through all this. Still having trouble opening Rar files, Probably because I don't know how to use program properly.
                                    • rccrasher65
                                      • Mar 2014
                                      • 626
                                      Hey guys I'm going to have to put this programmer a side for a few weeks, having surgery on shoulder this week. I'll get back with you as soon as I can. Thanks so much for all the help!
                                        • 22159
                                        This thread is almost as long as War and Peace
                                        • BlueMidnight
                                          • Jan 2015
                                          • 489
                                          Alright, hope you have a smooth recovery.
                                          Challenge accepted
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            06-30-2025, 01:24 AM
                                          • Jacksoft
                                            HP ProBook 440 G6 infinite orange blinking
                                            by Jacksoft
                                            I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                                            The PC worked but it was very slooow to show HP logo in first place.
                                            A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                                            The laptop doesn't power on anymore, and the blinking led happens...
                                            08-29-2025, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
