HP ProBook 445 G7 no POST only on battery
  • someonenotyou
    • Feb 2021
    • 64
    • LV
    Hi.
    I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
    When I attach DC Jack, the laptop will charge the battery and switch on.
    And now the strange part:
    1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
    2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop off, it will show Shutting Down, and then blank screen and Caps Lock starts blinking 5 times slowly without turning off.
    I have flashed a different BIOS and EC, but still it does not boot on battery.
    Is the EC chip faulty?
    Thank you.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Julian Bailey
    HP ProBook 445 G8 Battery not charging
    by Julian Bailey
    Hi all
    We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
    The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
    I have gone around the board with a MM and cant find anything
    Windows shows the battery fine,...
    10-11-2024, 10:34 AM
  • mkdj
    by mkdj
    Mark and model: ASUS X571
    Tests already made:
    - I have removed...
    07-14-2025, 09:16 AM
  • techfreak9356
    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
    by techfreak9356
    09-14-2023, 11:10 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
