Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • rccrasher65
    replied
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    Originally posted by BlueMidnight
    Okay, take care.
    Thanks BlueMidnight. Will get back to it in oct.
  • BlueMidnight
    replied
    Okay, take care.
  • rccrasher65
    replied
    Originally posted by rccrasher65
    Going to need some time to get this all right, so I'll get back to you when I have a good feel for what I'm doing.
    Gents,going to have to pick this up in late fall, sept or oct. I just have to much going on right now. I think I have enough info to run a practice run on bad boards for now, but will get back to you in fall when I want to flash good board.
  • rccrasher65
    replied
    Thanks BM. I just might de solder chip. I've done 144pin chips with alot of success, this 8 pin is nothing. I'll practice with the clip on the junk boards,and when I do the good board I'll take the chip off.
  • rccrasher65
    replied
    The BIOS chip is labeled U19 and is indeed located in the corner of the board, near the coin cell battery.
    The main thing with the clip is just that it attaches farther down on the chip than most people may expect if they've never used one.
    The clip is attached by spreading the jaws, pushing it right up against the board, and then letting the jaws close around the sides of the chip as you hold it against the board. When properly attached, the nose of the clip should be flat up against the board and the clip will stand straight up and down (not tilting to either side).
    If the nose of the clip is not touching the board then it's not going to stay in place. Push it all the way down and get as much of the chip inside the jaws as you can before closing the jaws.
    Pin 1 on the clip (the one that the red/pink wire goes to) should be towards pin 1 on the BIOS chip (marked by a little white dot next to the pin on the board).
    No time to take a photo right this second, but if you google something like "bios chip clip", I see that you'll get a few photos among the results that show correctly attached clips you can use as a reference.
  • BlueMidnight
    replied
  • mon2
    replied
    Holy moley this is a long thread. Being lazy here as I wish to watch the next episode of Black Summer on Netflix...short version - you wish to reflash the bios chip on your logic board ?
    Assuming yes, look for a 8 pin chip that has the markings of "25" in the part #.
    Post clear pix of the chip if in doubt. Motherboards often use SPI flash ICs which are the 25xx series and available from many suppliers.
    Winbond is popular but there are others out there.
    Either way, each such chip has a manufacturer ID and then a product / density ID that the flash tool will extract using common SPI commands.
    This will also verify that you have the 8 pin clamps on properly.
    PS: Personally concerned about the use of such tools to reflash the target IC while in the system (ie. soldered on the logic board).
    Raised this concern before and do not believe that anyone posted a reply:
    a) the signals on this SPI flash device are push-pull type and are driven by the host motherboard's logic. Specifically, these signals are not guaranteed to be tri-stated.
    b) Now, enter this external programmer which is also push-pull type of interface. How can this external tool assert its logic levels to challenge the motherboard's logic ? You cannot mate multiple push-pull drivers and expect a positive outcome.
    c) Then there is the power rail on the motherboard powering the SPI flash. Likely +3v3 but could be another value. This value should be read with a meter before proceeding. Next, this tool will assert its power rail onto the same Vcc pin. So the voltages will be "OR'd" ?
    I can only see this working if:
    a) the logic board is held in #RESET (LOW) to tristate the motherboard logic
    b) only ONE power source is used to power this target IC - what is the voltage of the target flash IC ?
    yet have seen many talk about just clamping the 8 pin zero force socket to reflash the target IC.
    Better solution is to use hot-air tools to remove the IC and apply onto a small SOIC to DIP board and then use this tool. Cannot see the other methods working properly and likely will lead to damage.
  • rccrasher65
    replied
    In Colibri, click the rightmost menu in the menu bar. It will drop down 4 items. Choose the 3rd item and then choose English.
    I do believe I have the program now. only problem is I can't get that shitty clip to stay on correctly.I only have 3 ic's that have 8 pins, can someone show me the correct one they are close to the battery. That might be my problem. I'll work on it till I get it correctly connected. BM can you show me the bios chip when you have time. Thanks
  • rccrasher65
    replied
    Nothing but error messages, I think I'm done with all this. Anybody I can send this board too, for a flash.
  • rccrasher65
    replied
    Thanks BM!
  • BlueMidnight
    replied
  • rccrasher65
    replied
    Thanks, found one , opened all files, got program running and it's in Russian. have no clue as to change language. I'm just about had it with all this, well beyond my scope of skills. Anyone know how to change language
    replied
    winzip trial expired, any other way to open that rar file. Thanks
    7-zip https://www.7-zip.org/download.html
  • rccrasher65
    replied
  • BlueMidnight
    replied
    Inside the main "Colibri_CH341.rar" archive there is a "Colibri.rar" archive. Extract that and run Colibri.exe (The one with the icon of a bird).
  • rccrasher65
    replied
    From a quick glance through, looks like a very informative set of instructions. Thank you for the link.
    I have everything connected correctly, but file to run program is not listed. driver install was successful as well. stuck don' know what to do from here.
  • rccrasher65
    replied
    Thank you!
  • rccrasher65
    replied
    Originally posted by SMDFlea
    Here`s a good guide for you to read https://winraid.level1techs.com/t/gu...rammer/32948/3
    Click on the +Spoiler to see the pictures
    Thank you!
    replied
    Bump!
  • rccrasher65
    replied
    Bump!
  • ipatch
    troubleshooting microsoft surface pro 4 no power no led charge light
    by ipatch
    hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
    10-05-2023, 11:59 AM
  • YasaCh
    Sony kdl 40p5500 red light keeps blinking 3 times
    by YasaCh
    Hello...
    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
    i opened the back cover no sign of damage on the powery suply or motherboard
    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
    07-07-2025, 11:53 AM
  • someonenotyou
    HP ProBook 445 G7 no POST only on battery
    by someonenotyou
    Hi.
    I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
    When I attach DC Jack, the laptop will charge the battery and switch on.
    And now the strange part:
    1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
    2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
    06-30-2025, 01:24 AM
  • Jacksoft
    HP ProBook 440 G6 infinite orange blinking
    by Jacksoft
    I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
    The PC worked but it was very slooow to show HP logo in first place.
    A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
    The laptop doesn't power on anymore, and the blinking led happens...
    08-29-2025, 01:24 AM
  • stevenallauca
    HP laptop does not charge the battery, the light turns amber and then changes to white.
    by stevenallauca
    Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
    - ACN (BQACN) 19.6v
    - ACP (BQACP) 19.6v
    - CMSRC (BQCMSRC) 19.6v
    - ACDRV...
    09-23-2024, 11:30 AM
