Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
Well that's unfortunate. The hard way it is then. I'd recommend trying to inject voltage onto LIMIT_SIGNAL. Dial it up to 5V max for now and see if a short appears. Doing it this way allows you to increase the current and potentially feel PR70 or PR158 getting hot. (PR158 is the one in pic #12 labeled LIMIT_SIGNAL)Comment
I'll get at it tonight, had a busy few days. Are those the only components we are looking for to get hot, or our we looking for any hot component.Comment
Well, that's the thing. There are only 2 ways "out" of LIMIT_SIGNAL on the schematic. There's the 13k ohm PR70, and there's the 2.1k ohm PR158. It's impossible to get the voltage reading you're getting with 330k above and those below. And there are even more components in series with those on the way to ground too.
So, we will test if there is a short to ground through one of those that just doesn't show up until you apply enough voltage. It's not super likely, but not impossible. If not, then there must be a short on some interior plane of the PCB, or on the surface (e.g. corrosion or conductive material).Comment
Does the actual voltage on LIMIT_SIGNAL rise up to the set voltage?Comment
I set voltage to 5V as you requested, I did then check voltage on limit signal, it had 5v on it. I did not check when ramped up voltage to 8V, just was feeling for hot components at that point.Comment
Okay, the 1-2 mV on LIMIT_SIGNAL you were reading before would require a path to ground of no more than roughly 20-30 ohms if the ID resistor is 330k. It seems that the resistance must not be too too much lower than that. The current draw isn't enough to cause your power supply voltage to sag.
The fact the voltage didn't sag, and nothing got hot, indicates those two resistors are okay at least. So, the last thing I'd like is proof that current is taking an alternate route to ground. Does your power supply show how much current is being drawn?
(I'm trying to avoid more difficult soldering jobs, so I'm going with this voltage-injecting method. But, the alternative way would be to disconnect those two resistors and see if you are still getting low readings on LIMIT_SIGNAL with the AC adapter plugged in.)
Do note that my earlier recommendation of 5V max is to try to keep ADP_A_ID and OCP_A_IN less than 6V in even a worst case scenario. That's an educated guess for the absolute maximum voltage rating of the I/O pins on the EC chip. 10V should not have harmed anything, though, if the part of the circuit involving PQ20 is working. But any higher is not good.Comment
Well, if there is a short somewhere on LIMIT_SIGNAL, then the solution would be to isolate that short by cutting the traces before and after. You could then run a jumper wire to bypass those traces.
The boardview file does not contain information about the routing of the board traces, so you will have to locate them yourself.
Look at the top contact of PR70 and the right contact of PR158 (as they are oriented in the earlier pics). Follow the traces along the surface of the board and through any holes (vias) until they join up with each other. Follow them until they reach CN11. Visually check for anything along that route that looks weird and might explain the short.
You're also looking for good places to cut those traces. A place right near each resistor would be best. Even better if there are no other traces right next to it at that spot. For CN11, it depends on which way the trace goes. If it disappears under the connector, it may be best just to lift pin 6 up to disconnected it from the pad.
Just look it over and get the lay of the land. Then report back.Comment
I'll try and do what you suggest, but I think now all this is well beyond my skill set. I do have the other board I would like to try and get going, or maybe even the board I pulled the two pads off of the charging chip. I don't want to waste your valuable time. I do certainly appreciate all you have done to walk me through this process. If we can I would like to turn to the other board, and give it a try.Comment
Did you attempt to perform the cutting and soldering already? I was going to add some more detail once you'd taken a glance at everything.
Fixing the pad(s) on the other board would be 10x more difficult I'm afraid.
I'll need to glance over the schematic and boardview to describe the next steps on the board that had voltages present. Have you been able to extract the boardview file?Comment
I only attempted to follow the traces with no success. Combination of bad eyes and lack of knowledge. To me this board is a parts board. I have the others, that I would probably have more of a chance of success. I don't give up easy, but I also know my limitations. just like that dang rar file I still can't open, even with 7-zip. I also don't want to waist your valuable time. I would like to attempt the one with the voltages present first, If we can. I'm practicing soldering very fine copper wire, for an attempt at fixing PU20 missing pads. Thanks BlueMidnight for all your help. let me know what we can do next. I'm looking for a better microscope camera, then I can attempt to find those traces. I only have a small hand held one.Last edited by rccrasher65; 08-21-2020, 08:17 PM.Comment
I only attempted to follow the traces with no success. Combination of bad eyes and lack of knowledge. To me this board is a parts board. I have the others, that I would probably have more of a chance of success. I don't give up easy, but I also know my limitations. just like that dang rar file I still can't open, even with 7-zip. I also don't want to waist your valuable time. I would like to attempt the one with the voltages present first, If we can. I'm practicing soldering very fine copper wire, for an attempt at fixing PU20 missing pads. Thanks BlueMidnight for all your help. let me know what we can do next. I'm looking for a better microscope camera, then I can attempt to find those traces. I only have a small hand held one.Comment
The boardview file is in this post. It is the same one I downloaded and am using. After you install 7-Zip, you can right-click on the rar file and choose to extract it. Alternatively, you can run 7-Zip and then use it's built-in file browser to locate the rar file and double-click it. After extracting the boardview file into another folder, you can use one of the recommended programs to view it.
Well if you ever do want to continue, the trace cutting can be done right near each resistor. For each cut you want to make, you actually ideally make 2 shallow cuts (going through the trace and no deeper) right next to each other using a very sharp razor blade or hobby knife. Then the little sliver in between the cuts can be lifted out. That way you know the cut ends can't touch. If the cuts are nice and close together you can still make a solder bridge across the gap to reconnect the trace if needed. If you get that far, then we'll worry about the jumper wire step.
For the board with damaged pads...
PU20:
Pin 1 -> Bottom of PR23
Pin 2 -> Bottom of PR22
Pin 3 -> Right side of PR13
Pin 4 -> Bottom of PR20
See attached pic #15Comment
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
Hi.
I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
When I attach DC Jack, the laptop will charge the battery and switch on.
And now the strange part:
1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...06-30-2025, 01:24 AM -
Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
- ACN (BQACN) 19.6v
- ACP (BQACP) 19.6v
- CMSRC (BQCMSRC) 19.6v
- ACDRV... -
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 06:40 AM
- Loading...
