Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
For the other boards... as a general rule, problems earlier in the power sequence are easier to find and fix. So the lowest hanging fruit is probably the one with no voltage present on the power rails. And for that one, the next step is to measure the voltage on the pins of PU20.
Best to wait for the new parts first, though.Comment
Can I use the DC jack from the laptop, as I'm going to disassemble, to see what causing the flickering, has to be something loose. It flickers now even when I touch the case. I can squeeze it and stop the flickering.Can you also show me PU 20. I hope it's not that component I jacked up on my parts board, trying to remove, lifted the pads. I think it is though.Last edited by rccrasher65; 08-05-2020, 08:42 AM.Comment
Yes, you can use the DC jack from the laptop if you disassemble it.
Flickering problems like that are usually the screen itself or the cable connecting it to the motherboard. If movement leads to flicker, then you can gently press/flex the various parts to search for bad connections or broken wires. It might be necessary to disassemble the top cover (i.e. the part of the case that surrounds the LCD itself) to properly check all areas.
Yes, that component is PU20. Location is in the pic in this post.Comment
I'll disassemble and see what I can find. I'll get those measurement on PU20in a day or so.Comment
I was doing some voltages measurements on board #2 the one with the voltages present, using the dc jack that showed good voltages, and my power supply. I checked CN11 I get the 5.04V on pin 6 that we are looking for on board 1. i'm just not understanding whats going on with board 1 CN11. If DCjack and power supply work on board 2, then why not board 1. Can there actually be a problem with the actual connector(CN11) itself, like a burned trace we can't see.Comment
New DC jack and power supply arrived.Comment
No power on pin 6, with new power supply and DC jack. There has to be something wrong with the connector itself. I checked under microscope to see if I can find any burnt trace or pin, nothing! all looks good very minimal corrosion. I'm just confused at this point. Is there anything that protects that connector that could be bad? On board 2, I managed to get fan to spin for a second or two. the white charge light on the DC jack flashed once and shut off.Comment
I'm good, thank you. Just a busy weekend. Didn't have a chance until now to fully investigate the next steps.
Okay, so that is a very curious result. But, of course, sometimes the less likely thing is what happens.
So we are left in the same position as before. Either the resistance from pin 6 to the positive connection is too high, or the resistance from pin 6 to ground is too low.
First, I'd like to just verify how many ohms the ID resistor is inside the new power supply. With the new power supply and DC jack plugged into each other but not plugged into anything else, what is the resistance between the pins 1 and 6 (red and brown wires)?
It should be ~500k for a 45W power supply, 390k for 60W, or 440k for 90W.
You've already checked the resistance between CN11 pin 6 and ground and it was fine. Let's try testing it a couple additional ways.
First, connect the power supply and DC jack to the motherboard. Do not plug the power supply into the power outlet. Measure the resistance between +VA and LIMIT_SIGNAL as indicated in attached pic #12. This is the same as measuring the red and brown wires, but also will test the connection through CN11. I've marked some other stuff on the pic, but ignore that for now.
Second, try measuring between LIMIT_SIGNAL and ground using diode mode in the meter just to see if the readings are any more interesting. Try both polarities of the probes.Comment
I will try what you suggest this evening and post results. Its just confusing that on the second board all my new parts work, even the other parts, could there be a problem with the traces to the pins on the connector itself. I will get to it, thanks again.Comment
I was just looking over the board with the camera, and discovered that the component next to CN11 nest to pin one, and white dot on board, has lifted not connected to outside pad towards the edge of the board. I'm assuming that is a diode. I'll get those measurements this evening, thanks BlueMidnight!Comment
The component near pin 1 of CN11 is PC164, a 0402 size 0.1uF 25V capacitor. It's used for input power filtering. While it should be there, it shouldn't prevent the board from working.
The +VA to LIMIT_SIGNAL resistance looks interesting. What is the reading without the DC jack connected? Is it the same in both polarities? What do these measurements look like on the second board?Comment
going to clean up those pads today. I think I can get that cap from my donor board.Comment
Okay, doing the math for the multiple paths of significance from +VA to ground and back up to LIMIT_SIGNAL, I get a value of 190k. That seems to check out. And come to think of it, we could explain the 1.749k resistance reading with the power supply connected if it has a discharge resistor on the output of perhaps 1.8k-2k.
But the near zero voltage reading on LIMIT_SIGNAL still doesn't make sense unless there is a short. It would have to be the sort that hides unless it is in the powered condition.
I'd probably double-check for corrosion and such -- including around the area in pic #12. If nothing found, then it's possible to inject up to 5V at LIMIT_SIGNAL (at CN11) with a current-limited supply and see what happens. Alternatively, it's possible to desolder PR158 and PR70 to narrow things down.Comment
I'd probably double-check for corrosion and such -- including around the area in pic #12. If nothing found, then it's possible to inject up to 5V at LIMIT_SIGNAL (at CN11) with a current-limited supply and see what happens. Alternatively, it's possible to desolder PR158 and PR70 to narrow things down.Last edited by rccrasher65; 08-12-2020, 11:10 AM.Comment
You can open the RAR file with 7-Zip.
I would consider soldering work to be the last resort. And actually, there's one more thing to try. The most neat and orderly explanation I can think of would be if PR70 were shorted. It's not a common failure mode for resistors, but it can happen. It's an even nicer explanation if the board is turning on PQ8. That would create the path to ground we are looking for, and it would disappear when the board is unpowered.
Let's test this hypothesis (See attached pic #13):
- With the board unpowered, test the resistance of PR70. It's supposed to be 13k ohms.
- With power connected to the board, measure the voltage on the pins of PQ8.Comment
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
- ACN (BQACN) 19.6v
- ACP (BQACP) 19.6v
- CMSRC (BQCMSRC) 19.6v
- ACDRV... -
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 06:40 AM
This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-07-2024, 05:50 AM
- Loading...
