Cpu_core signal missing. Lenovo g50. Help?
  • Weelcup
    TopTech
    • Oct 2017
    • 302
    Re: Cpu_core signal missing. Lenovo g50. Help?
    Originally posted by bluestone
    Check Ec pin 99 and pin 30
    Pin99=3.3V
    Pin30=0V
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      Now, discovering the faulty component requires more thinking and analysis of the mainboard, because the mainboard is complicated and any unexpected fault may be there. Do not replace PCH or SIO in a hurry.
      • Weelcup
        TopTech
        • Oct 2017
        • 302
        I agree,
        interestingly, I have replace Q39,Q40 Mosfets. both seemed to be fully working though. but the board powered up normally for 1 min and I was able to enter the bios and check the info. then the board turned off. and the same problem started again. I tried to replace the mosfets again but I got nothing. I am now very confused of what might connect the mosfets with the problem and why it worked. was it the heating near the cpu or the mesfets or a cut in circuit near the mosfets??? like you said Caspian "it might be anything"
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          If so, turn it off and measure resistance on PQ39 and PQ40 and pin1 of PU908. check whether there is any short.
          • Weelcup
            TopTech
            • Oct 2017
            • 302
            I have checked it. there is no short to ground and the mosfets are ok.
            between the two mosfets and the ground = 32ohm
            while between mosfets and pin1 = 1.65K
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              #26
              Had you replaced PQ39 and PQ40 before starting this thread?
              If so, you have probably damaged PU908 or the SIO.
              If not so, which post have you replaced PQ39 and PQ40 at?
              • Weelcup
                TopTech
                • Oct 2017
                • 302
                Yes I replaced the two mosfets before starting the thread.
                What I did so far are the replacements below in sequence:
                Replaced UL1 as it was getting warm.
                Reprogram the bios and the EC
                Replaced the PQ39,PQ40
                Replace PU908
                Replace PQ39,PQ40 again
                Replaced PC989 and PC708
                Reprogrammed the Bios and the EC again.
                Only when I replaced the 2 mosets at the first time I got it worked for about a 1min.
                Can I know why would these mosfets damage the PU908 or Super IO. ?
                  • 20728
                  Is the voltage stable on 3VS, check Q24 and +20VSB .If its ok check PR617 and PC621
                  • Weelcup
                    TopTech
                    • Oct 2017
                    • 302
                    The 3.3VS is not flactuating while checking via multimeter. But I don't have osciliscope to check the pattern. So I assume it is stable.
                    At Q24:
                    Pin4 =19.8v
                    All other pins = 3.3v
                    PR617 have 0V.. and measures 5ohm
                    PC621 have 0v ... and measures 39ohm at non-grounded pin.
                    • Weelcup
                      TopTech
                      • Oct 2017
                      • 302
                      But at PU602 pin7 the multimeter flactuate between 0.696V and 0.702V does that mean it is not stable?
                      Also, the same happens at PU202 pin6.
                        • 20728
                        No,thats not fluctuating at all.
                          • 20728
                          Check PU908 pin 1, what voltage do you get when you press the power button
                          • Weelcup
                            TopTech
                            • Oct 2017
                            • 302
                            Actually whenever I connect to 20v power supply the power led gets on. And when I press the power button to turn it off it doesn't. In stead, it just restart. So I just see a one time blinking led.
                            But as you advised, I measured the voltage at pin1 exactly at the moment when I connect to power supply. Interestingly there is an increase in the volage at pin1 which come and gone in a matter of milliseconds. The same thing happens when the power led blinks when I press the power button for a while.
                            The max my multimeter reach during those milliseconds was 0.370v.
                            • caspian
                              • Oct 2015
                              • 1589
                              • Laptop
                              #34
                              now continuously monitor voltage on PL9 to see whether it has a rise or it is absolute 0. If it has a rise for a millisecond, how much is the voltage rise?
                              • Weelcup
                                TopTech
                                • Oct 2017
                                • 302
                                Doing the same procedure, No there is nothing at all on PL9.
                                  • 20728
                                  Redo PU908, do the same tests afterwards .
                                  • caspian
                                    • Oct 2015
                                    • 1589
                                    • Laptop
                                    #37
                                    first, remove PR9146 and measure voltage on both sides of PR9146 and PR9343.
                                      • 20728
                                      Ah yes, to see if voltage is on EC_VR_ON,CPU_VR_ON or both. If the voltage is on both check PC620 next ?
                                      • Weelcup
                                        TopTech
                                        • Oct 2017
                                        • 302
                                        I just did the measures.
                                        PR9343 already not installed by the manufactur.but I removed PR9146.
                                        Interestingly , there is a raise in voltage on PU908 pin1 to about 0.9V as soon as drops to zero then raise again and so on.
                                        But there is nothing on the other side of the resistor. So the CPU_VR_ON & EC_VR_ON are both 0V...
                                        I Shared a short video of the voltage with you on the following link:
                                        https://drive.google.com/file/d/1w4d...w?usp=drivesdk
                                        • caspian
                                          • Oct 2015
                                          • 1589
                                          • Laptop
                                          #40
                                          do not solder PR9146 back on the board until you fix the CPU_VR_ON signal. Since there is no CPU_VR_ON, it seems the PCH is faulty. that is not good. to make sure, reprogram the Bios and the EC using the original dump while PR9146 is removed.
                                          • questore
                                            Lenovo Legion 5 missing EC_ON_5V signal (5v_AWL)
                                            by questore
                                            Dear all.
                                            I have a Lenovo Legion 5 that come to me as faulty.
                                            The problem was that Adapter_ID pin was shorted by some liquid... killing the EC (there was a hole in the EC) (therefore 3.3v was shorted)
                                            I have removed shorted EC it and tested that if i short EC_SBM_CK1 to ground, then the BQ24780SRUYR power IC lets 20v pass the first and second mosfet.
                                            Nothing else seems shorted when checking 3V,5V, 1.1V, battery or 1.0v coils, so I have ordered the new EC chip.
                                            I have ordered a preprogrammed Chip for NM-C921 and soldered it on. (No pins shorted after checking...
                                            02-23-2025, 04:25 AM
                                          • gurj1979
                                            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                            by gurj1979
                                            Hey guys.
                                            Need help with this one.
                                            Fan not spinning due to missing PWN Fan signal.
                                            Also 5 seconds from powering up it freezes, unless in BIOS.
                                            But as soon as Windows starts to load, it will freeze.
                                            CPU is COLD / Room temp when it freezes.
                                            I've replaced the CPU, same problem.
                                            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                            Replaced fan - same problem.
                                            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                            08-19-2024, 05:22 PM
                                          • TecnicaNTT
                                            Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                                            by TecnicaNTT
                                            I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                                            My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                                            I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                                            I am now asking here for help if anyone knows how to do this in...
                                            09-20-2024, 08:10 AM
                                          • Fernon@Repair
                                            MSI mpg b560m bazooka motherboard RSMRST# signal missing
                                            by Fernon@Repair
                                            I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
                                            My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
                                            VCCRTC ok
                                            RTCRST# ok
                                            ATX_5VSB ok
                                            SIO_3VA ok
                                            3VDSW ok
                                            DPWROK ok
                                            SLP_SUS# ok
                                            VSB_ENABLE# ok
                                            5VDUAL ok
                                            3VSB showing 4.17V
                                            PCH_1P8_VSB ok
                                            PCH_VCCIN_AUX ok
                                            RSMRST# No voltage
                                            this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
                                            06-03-2025, 10:49 AM
                                          • m0jo1103
                                            Need help.... Lenovo L340-15IRH mosfet missing!
                                            by m0jo1103
                                            Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
                                            05-19-2025, 07:13 AM
