Cpu_core signal missing. Lenovo g50. Help?
  • Weelcup
    TopTech
    • Oct 2017
    • 300
    Re: Cpu_core signal missing. Lenovo g50. Help?
    Originally posted by caspian
    do not solder PR9146 back on the board until you fix the CPU_VR_ON signal. Since there is no CPU_VR_ON, it seems the PCH is faulty. that is not good. to make sure, reprogram the Bios and the EC using the original dump while PR9146 is removed.
    I will caspian. But can I know what signals power on the PCH. In order for the PCH to be able to generate the CPU_VR_ON?
    I will get back soon. And tell the result of the reprogramming.
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      #42
      that is a good idea. Before reprogramming, make sure all the power rails connected to PCH are present. Those power rails are the ones mentioned in page3-13 of the schematics except CPU_Core and VGA rails. If one of the rails is missing, the PCH will not work.
      • Weelcup
        TopTech
        • Oct 2017
        • 300
        I done reprogramming and nothing new..
        I will check the rails as soon as I get back.
          • 20299
          Where did you get the bios and ec dumps,can you post them here .
          • Weelcup
            TopTech
            • Oct 2017
            • 300
            YES SURE! Its My Pleasure>>>
            Actually I got two. each is from different websites....
            Here are they....
            both should work fine
            • aniladream
              • Jul 2018
              • India
              #46
              Hi, I also have similar issue. Do you get any solution for this.
              • Weelcup
                TopTech
                • Oct 2017
                • 300
                If you go through this post and still not have the signal then it is a cpu issue.
                I could not get it to work. And am believing the CPU was faulty.
                • questore
                  Lenovo Legion 5 missing EC_ON_5V signal (5v_AWL)
                  by questore
                  Dear all.
                  I have a Lenovo Legion 5 that come to me as faulty.
                  The problem was that Adapter_ID pin was shorted by some liquid... killing the EC (there was a hole in the EC) (therefore 3.3v was shorted)
                  I have removed shorted EC it and tested that if i short EC_SBM_CK1 to ground, then the BQ24780SRUYR power IC lets 20v pass the first and second mosfet.
                  Nothing else seems shorted when checking 3V,5V, 1.1V, battery or 1.0v coils, so I have ordered the new EC chip.
                  I have ordered a preprogrammed Chip for NM-C921 and soldered it on. (No pins shorted after checking...
                  02-23-2025, 04:25 AM
                • gurj1979
                  Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                  by gurj1979
                  Hey guys.
                  Need help with this one.
                  Fan not spinning due to missing PWN Fan signal.
                  Also 5 seconds from powering up it freezes, unless in BIOS.
                  But as soon as Windows starts to load, it will freeze.
                  CPU is COLD / Room temp when it freezes.
                  I've replaced the CPU, same problem.
                  Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                  Replaced fan - same problem.
                  Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                  Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                  08-19-2024, 05:22 PM
                • TecnicaNTT
                  Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                  by TecnicaNTT
                  I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                  My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                  I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                  I am now asking here for help if anyone knows how to do this in...
                  09-20-2024, 08:10 AM
                • Fernon@Repair
                  MSI mpg b560m bazooka motherboard RSMRST# signal missing
                  by Fernon@Repair
                  I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
                  My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
                  VCCRTC ok
                  RTCRST# ok
                  ATX_5VSB ok
                  SIO_3VA ok
                  3VDSW ok
                  DPWROK ok
                  SLP_SUS# ok
                  VSB_ENABLE# ok
                  5VDUAL ok
                  3VSB showing 4.17V
                  PCH_1P8_VSB ok
                  PCH_VCCIN_AUX ok
                  RSMRST# No voltage
                  this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
                  06-03-2025, 10:49 AM
                • m0jo1103
                  Need help.... Lenovo L340-15IRH mosfet missing!
                  by m0jo1103
                  Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
                  05-19-2025, 07:13 AM
