Lenovo Legion 5 missing EC_ON_5V signal (5v_AWL)
This topic has been answered.
  • questore
    • Dec 2015
    • 573
    • csongrád
    Dear all.
    I have a Lenovo Legion 5 that come to me as faulty.
    The problem was that Adapter_ID pin was shorted by some liquid... killing the EC (there was a hole in the EC) (therefore 3.3v was shorted)
    I have removed shorted EC it and tested that if i short EC_SBM_CK1 to ground, then the BQ24780SRUYR power IC lets 20v pass the first and second mosfet.
    Nothing else seems shorted when checking 3V,5V, 1.1V, battery or 1.0v coils, so I have ordered the new EC chip.
    I have ordered a preprogrammed Chip for NM-C921 and soldered it on. (No pins shorted after checking all)
    Plugged in the AC adapter but only 3V_AWL is coming on.
    3.3v is present on power button and goes to 0v when pressed. (also checked on EC_Pin to be sure the info is getting there)
    I have found that EC_ON_5V signal is never comes out from the EC.
    I have tried 3 different ME_Clean bios but no luck. EC does not sending 5V_ON so 5V_AWL never comes on
    Can anyone help what could be the problem? Is the new EC faulty or wrong BIOS can cause this?
    Thanks for all the help!
  • Answer selected by questore at 03-05-2025, 10:13 AM.
    questore
    • Dec 2015
    • 573
    • csongrád
    SOLUTION:
    The EC pin number sahara boards in bookpc's (3vALW_R) had a lose soldering.
    After resoldering it, the laptop turns on and everything work fine.
    Thanks for the help.
    • mon2
      • 14717
      https://www.badcaps.net/forum/troubl...vo-y530-legion
      • questore
        • Dec 2015
        • 573
        • csongrád
        I have tryed 2 different BIOS from this forum to reprogram BIOS with Clean ME.
        Both of them are not working and acting like the original symptom.
        If a wrong BIOS is present then shouldn't the 5V_ON signal come on anyway with 3.3v?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Check resistance to GND on 5VALW and 5V LDO.
          If the resistance reading is ok, very likely bad sio/bad soldering or bad EC firmware.
          • questore
            • Dec 2015
            • 573
            • csongrád
            + 5V LDO is Present after charger plugged in. (5.02 Volts)
            + 5VALW missing when plugged in (resistance 0 ohms when plugged in) and normal resistance when charger is not plugged in (Mohms)
            + EC_ON_5v is 99 Millivolts both case (when charger is plugged in or not)
            If I inject 5V on 5VALW then the 3v/5v voltage generator IC is getting hotter a bit (drawing 0.230 Amps and 39C degree)
            MY IDEA:
            I want to inject 3.3v on the EC_ON_5V line and see if the 3v/5v IC is turning on +5VALW. and SYSPWROK signal. If not then the 3v/5v IC is faulty, if it turns on then EC firmware is wrong. (Or BOTH 😂)
            ( in my region no one programs EC as I know, so maybe i have to invest 500 Dollars to a programmer )
            • questore
              • Dec 2015
              • 573
              • csongrád
              Unfortunatelly it seems that the EC programming is bad or something seriously wrong with board
              1. if I short the charging IC CLOCK signal to ground, the battery starts to charge, otherwise not.
              2. if I touch the EC_ON_5V pin with multimeter when charger is connected, then suddenly 2.6V is apearing on the pin, and 5VALW is turning on stabile.
              3. if I touch the EC_ON_5V pin after 5VALW is turned on with a multimeter, then the EC_ON_5V voltage is disappearing along with 5VALW goes to 0v and I cannot turn it on again anyway until charger is disconnected again
              Am I right to think that EC has wrong firmware?
              • questore
                • Dec 2015
                • 573
                • csongrád
                SOLUTION:
                • questore
                  • Dec 2015
                  • 573
                  • csongrád
                  I see some automatism changed my text.
                  Pin 127 was lose.
                    Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                    This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 05:00 AM
                    Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                    This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                    This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 04:10 AM
                  • pappothar
                    Lenovo legion 5-15ach6h IT8227E-192 CXA shorted, repaired but no screen / no boot
                    by pappothar
                    hi
                    i bought a defective legion, tested it had the IT8227E-192 CXA shorted.
                    I ordered on aliexpress, carefully changed it under microscope, and now when i plug the dc in, keyboard flashes in all colors in loop, on button is white, and nothing more
                    The battery led is charging, it seems is the only thing that works
                    Screen is off, nothing, not even the backlight
                    could it be a non programmed IT8227E ?
                    Awaiting for your feedback
                    Thank You
                    Stefano
                    09-15-2025, 08:37 AM
                    LENOVO Legion Y720 Legion 1800x Specification for Upgrade or Repair
                    This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                    09-12-2024, 02:30 PM
