Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
This topic has been answered.
  • TecnicaNTT
    • Feb 2015
    • 72
    • Portugal
    I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
    My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
    I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
    I am now asking here for help if anyone knows how to do this in this model. I leave attached the working BIOS and machine details:
    Brand: Lenovo
    Model: Thinkbook 16P G2 ACH
    Serial Number: PF3726L7
    MTM: 20YM001WPG
    Thanks in advance.
  • Answer selected by TecnicaNTT at 09-27-2024, 02:29 AM.
    BootLoader1
    • Aug 2020
    • 72
    • Poland
    Try and post results.
    • TecnicaNTT
      • Feb 2015
      • 72
      • Portugal
      bump, really need help for this!
      • BootLoader1
        • Aug 2020
        • 72
        • Poland
        • TecnicaNTT
          • Feb 2015
          • 72
          • Portugal
          Thank you!
          Worked flawlessly. Laptop is up and running with correct info.
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • HumanDev228
            Lenovo ThinkBook 13s Gen 3 ACN – Need Help Fixing Corrupted BIOS (W74M12JW)
            by HumanDev228
            I’m working on a Lenovo ThinkBook 13s Gen 3 ACN (AMD Ryzen 5 5600U) with a Winbond W74M12JW 16MB BIOS chip
            Symptoms:
            • No display, fan spins, white LED blinking
            • Temporary boot after flashing another BIOS
            • Dies again after reboot
            • Current BIOS dump appears corrupted (mostly FF-filled, no valid UEFI structure)
            What I already tried:
            • External flash with CH341A + proper 1.8V supply
            • Flashed GMCN33WW-031F.bin (booted once, then failed again)
            • Reflashed original dump → same issue
            • Power reset, battery disconnect
            • RAM reflow attempt (no change)
            12-08-2025, 05:25 PM
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • HotSaladMan
            Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
            by HotSaladMan
            *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
            Model : Lenovo ThinkBook 14S Yoga ITL
            S/N : MP28JT19
            MFG Date : 2022/02/09
            Factory ID PRC4
            MO : MPNXB26080FX
            MTM : 20WE001US
            MODULE FCC ID : PD9AX201NG
            IC : 1000M-AX201NG
            BOARD INFO
            FLV34 LA-KO51P
            REV : 1B 2020-08-24
            Bit of Info
            Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
            chip id, so i would always uncheck the id check, so it would bypass the error
            i did in fact make...
            11-07-2024, 07:46 AM
          • evilgenius31
            Zephyrus G14 GA401QH-211 Bios missing serial number
            by evilgenius31
            Hi All,
            I was told to post my corrupted bios dump here. My Zephyrus G14 GA401QH-211 is missing the serial number in the bios. NVME drives can't be detected by the bios either. The bios version is 410.
            Serial: M4NRKD01530915H
            Thanks in advance!...
            11-10-2025, 03:58 PM
