Dumping flash from HTC Desire 510
+ More Options
Posts
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #41
    Re: Dumping flash from HTC Desire 510
    Originally posted by stj
    so the fone is asking for a pin without the sim?
    Yes.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Spork Schivago
      • Mar 2012
      • 4734
      #42
      Originally posted by goontron
      I personally would go this route.... https://forums.hak5.org/index.php?/t...e-4-digit-pin/
      And if you can't get it to work on the device, even if it is encrypted by a pin, once you dump the eMMC it will only take 6561 digit combos to crack. My core i3 averages about 1000 passwords per second with everything running, so with that and overhead it should take around 77s to crack on my laptop.
      Wow, if I'm understanding this correctly, the phone would need to support a USB keyboard. How can I verify? I don't think I have an adapter to go from normal USB to micro-USB. Also, I have a development board that has the AT90USB162 Atmel chip on it. I used it a long time ago to run unsigned packages on the PS3, back when it was running firmware 3.21.
      It's a clone for the PSGroove I think it was called. Right now, there's no USB header soldered onto it. But I wonder if I can use this development board to do what they're doing with the Ducky. I believe this AT90USB162 is a Teensy clone or a Teensy++ clone.
      It's been a while, but I need the source code I think, so I can compile it. I don't remember how I compile it, I think I need to setup a cross-compiler on my Linux box. But I remember with this one, I need to modify the code a little and add a bit so when I press the button on my dev stick, it goes into program mode. I think there was some special modified PSGroove payload I used back then, that added the reset button stuff. Man, I wish I could remember more.
      Thanks!
      • diif
        • Feb 2014
        • 6978
        • England
        #43
        16.6 hours to enter all 4 digit pins manually with the 30 second time out.
        • Jane
          • Aug 2010
          • 188
          #44
          Well, it is really very hard to believe. PIN is linked with SIM card. You may have locked the phone but it is linked with the phone locking code, not with the SIM card.
          • Spork Schivago
            • Mar 2012
            • 4734
            #45
            Originally posted by diif
            That's providing the pin was 4 digits and Spork has a Rubber Ducky/Teensy.
            If it is 4 digits Spork would have been done by now trying them manually.
            Quicker to buy one of the boxes that plugs into the phone/PC that can unlock pins and reset patterns Z3x, Volcano etc.
            I haven't manually entered them. After 5 attempts I think (maybe 3), it makes me wait 30 seconds. I do have a Teensy clone with an Atmel AT162USB. I want to see if I can program that with the payload for the Rubber Ducky. It might be worth at least trying the 4 digit maybe even 5 digit pins, especially if I don't need to purchase a Rubber Ducky.
            I looked into the Z3x and I don't think it can help, but maybe I misunderstood. I looked into a lot of those devices (like the Jiif box or whatever it's called). In fact, the X3x software that I downloaded shows JTAG and eMMC pinouts. But the problem was it doesn't have any pictures for this model. From reading a bunch of threads, the only way people were able to extract the NAND was off-chip. So I kinda ruled out the special boxes.
            • Spork Schivago
              • Mar 2012
              • 4734
              #46
              Originally posted by gabiz_ro
              Don't try to unlock bootloader.
              After bootloader unlock HTC perform a hard reset and everything is erased.
              Yes, unfortunately, the only ways I could find to unlock the bootloader involved a hard reset of the phone. Thanks though.
              • Spork Schivago
                • Mar 2012
                • 4734
                #47
                At least you aren't this guy spork. http://rare.us/rare-politics/rare-li...t-was-cocaine/
                That's freaking insane!!!!! I wonder if he would have a lawsuit that he could win. Maybe I'll start carrying around a baggy of drywall dust on me!
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #48
                  This is why I thought the PUK could reset the phone PIN. I think the fact that the PIN is missing, I have an infinite number of tries and so long as a SIM isn't entered into the phone, I will never be asked for the PUK. Whereas, if the SIM was in the phone, after 10 attempts or so, even with the correct phone PIN, I'd need the PUK to unlock it.
                  Stj and I think maybe Diif (I can't remember) know a lot about the phone PIN and the SIM pin and the PUK and how it all works. Until I received this phone, I didn't even know there was a PUK.
                  I highly doubt it's a 4 digit PIN, but I figured at least it'd be worth a shot. Someone else said that the flash isn't encrypted by default. My wife made the call to the electrician and told him to go ahead with the panel upgrade (he's removing a panel and a subpanel and upgrading us to 200-amp service). Once that's done, I'll have my BGA rework station up and running, and then I can look at off-chip removal using that NAND to SD card adapter that Diif pointed me to. I believe I have the equipment to remove the NAND as it is, but I want to make sure I can put it back on when I'm done. I don't want to give the phone back and be like sorry, couldn't get it, by the way, I broke the phone!
                  There's some sort of glue around the NAND though. And I'll have to figure out the best way to remove that. It's shiny glue and it looks really hard. Almost like some sort of epoxy that's designed to make removing the NAND in one piece impossible. I hope it's nothing crazy like that.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #49
                    I found the code I need to add to the main() function on the Teensy 1.0 clone board (the one with the AT162USB).
                    Code:
                    /* Prototype declaration. */
                    void (*start_bootloader)(void)=(void(*)(void))0x1800;
                    /* add after main() and after the for(;;) loop to allow */
                    /* the device to go into DFU mode. */
                    if((PIND & (1<<7))==0) {
                    TIMSK1=0;//Disable timer interrupt
                    USB_ShutDown(); //Shutdown USB
                    _delay_ms(100); //Wait
                    (*start_bootloader)();
                    There isn't much memory on this device. I wonder how hard it'd be to write some code that would just make it act like a keyboard and loop through the numbers, maybe trying some more common ones first (ie, 1234, 2345, 3456, 4567, 5678, 6789, 7890, 8901, 9012, 2109, 1089, 0987, 9876, 8765, etc).
                    I could test it on the laptop. Have it enter 5 4-digit numbers, pause for 30 seconds, try continue again....
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #50
                      AT90USB162, sorry.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #51
                        The code to try all the combinations is in the link gootron posted. Although checking it looks the 510 does not support USB HID so the teensy won't work.
                        I haven't pointed you to a NAND to SD card adapter. I personally don't believe dumping the flash will reveal the PIN. I have an interest in data recovery especially flash. All the videos I've watched of data recovery of any type of flash including eMMC have required dedicated expensive software to make sense of the dump and also hardware to connect to the reader. Micro SD are soldererd by hand but eMMC go in jigs.
                        If you were to use the top heater on your BGA, every solder joint on that board will be molten.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          #52
                          It was Goontron that pointed me to the adapter. Sorry. I was just trying to find away to continue working until the BGA rework station got up and running. I don't know how long it's going to take for the electrical, but first he's gotta get permits, do some work, have NYSEG come out, get some code inspector out, and after all that, come back another day to do the stuff inside.
                          So we don't want every solder joint on that board to be molten, just the BGA chip. I can use the hot air with a special nozzle to remove it (the WHA-900), but how would I reattach it successfully? With BGA components, there's profiles that need to be followed.
                          For the 3DS I did, I just soldered directly to the eMMC flash and read it in the SD card. I can show you the cable I made. The software though, I was thinking something like binwalk. I don't remember what I did with the data, but I know I did this to downgrade the firmware version.
                          You have a valid point though, I mean, the way flash data is laid out, I don't think I can just carve the data and look for headers / footers or anything like that. Maybe it's just time to call it quits.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #53
                            My BGA station is dark IR, so if I used mine on a phone board I think bad things would happen. When reworking small stuff with hot air, I try and emulate the same kind of profile as when doing BGA rework.
                            • gabiz_ro
                              • Mar 2011
                              • 166
                              #54
                              Found one OPCV200 Desire 510
                              When I have some free time I'll set pin code as security protection and try to recover some data using Z3X Jtag.
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                #55
                                Notice most are Windows yeah? A Linux boxen would be able to understand the filesystems that Windows needs special software to read, and can even make sense of the partition table, which again, needs compatibility layers for Windows. On Linux, a partition table image "GPT.bin" would help. Otherwise the data you are looking for is on either a Jffs2, FAT (on real early devices), or EXT filesystem.
                                That specialized software is there because being a Unix/Linux/BSD engineer is hard.
                                Now: Spork. Are you just trying to unlock the phone for use? If so you can wipe data from fastboot.
                                Follow the white rabbit.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #56
                                  My BGA rework has hot air for the top and bottom, plus some IR for the preheaters. But I don't have a nozzle for the flash chip for the BGA rework station. Just semi-generic nozzles.
                                  Anyway, I actually made some progress. I tried a bunch of stuff and got it so I could go into fastboot. I disabled driver signature in Windows 10 and installed some fastboot drivers or whatever they're called. Fastboot devices showed the phone. Still nothing with ADB. So I start adb with:
                                  adb status-window
                                  and see:
                                  Code:
                                  Android Debug Bridge
                                  State: unknown
                                  Then I restart the phone, but I click on Recovery. It tries booting into the recovery thing and I hold up the volume UP and PWR button, but I don't think it registered the Volume UP. It restarts and all of a sudden, in Windows, I get access to the MTP device.
                                  I copied everything real quick and then the window disappears.
                                  Guess what I find on it? Child porn. But they're in the thumbnails folder and not real children, they're like CGId or something. Very disgusting though. Not sure what to do now. I made a copy of everything that I could. I highly doubt anything's in there that could help recover the pin.
                                  There's one image of a real girl in her underwear, taking her shirt off. It's in the DCIM\.thumbnails folder. I don't think that's an Android folder though, is it?
                                  There's only a background image in the Pictures folder.
                                  I called the family, even though it's late. I guess they lied a little to me. They said they thought this might be on there. I guess they took the phone to the police to have them search it, but the cops refused, saying too many people had touched the phone and just gave it back, they never said they couldn't get it or anything. They said they just didn't want to say anything to me about it and wanted to wait to see what I found.
                                  Now they said they want me to destroy the phone and everything on it so I don't get in trouble and they want me to delete everything I've recovered now. Even though the pictures are computer generated, I don't see why someone would want these. They're of little kids. It makes me sick to my stomach. I got a little daughter and all I can think was this guy was living in the same town with her. Maybe if she was a bit older, outside playing by herself, he would have kidnaped her? Freaking sickos!
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #57
                                    I can give you the eMMC pinouts for the OPCV200 Desire 510. This is the OPCV100. I think I even posted the pinouts on the first page, thinking the board would be the same, but it's not.
                                    How does that Z3x work? Do you need to hook up to the JTAG TAPs or can you do it all over the USB cable or something? Maybe the 0PCV200 is CDMA and the 0PCV100 is GSM? I also have the JTAG pinouts for the OPCV200, but I think you do as well, if you have the Z3x. They're in the c:\Program Files\Z3X\EasyJTAG\PinoutsJTAG\HTC_Desire_CDMA.jpg file.
                                    I think you might find problems with hooking up to the JTAG interface though. I think the issue is something with the Vcc dropping after so many seconds.
                                    Thanks and please keep me posted on your progress.
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      #58
                                      No, they told me he was missing and they thought where he might be could be in a text message, but I guess they wanted me to try and get in and see if there was child porn on there, which there was, well, kinda.
                                      Are all Android flash images mountable on Linux? Because I know not all flash images are. My Rigol DP800 power supply's decrypted firmware is hard to figure out. Granted, that's not a copy of the flash, but the flash is in there. It's weird. Strings like http aren't http. They're stuff like ht~p or something odd. Originally, we thought the decryption algorithm was flawed, but someone else smarter came along and said they believe that's just how it's stored in the flash as raw data.
                                      Essentially, I guess what I'm asking, do all flashes have a popular filesystem, like EXT3 or 4 or FAT, etc, or could it be a proprietary format?
                                        • 30934
                                        the DCIM folder is the destination for stuff taken by the camera!
                                        so you may want to check the date on the image and try and find out who she is.
                                        be carefull about your legal situation though - your not supposed to have that personal image, and showing it around could be a problem.
                                        • goontron
                                          5000!
                                          • Dec 2011
                                          • 4108
                                          • US
                                          #60
                                          Yes. To both. Besides assholes like Shitsung (RFS, proprietary) who like to mess with shit, you will find EXTfs, F2FS, EMMC fs, YAFFS2, JFFS, and FAT. All of which are Linux supported. The DATA partition on my Moto G from around the time is EXT4. My latest phone, the current generation Moto G, is also EXT4.
                                          • SluggerB
                                            Help with trying to fix phone that is not charging (Pics inside)
                                            by SluggerB
                                            I have two TCL A30 phones.
                                            Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                            New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                            My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                            08-12-2024, 08:11 AM
                                          • ekozeko333
                                            by ekozeko333
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • keeney123
                                            new OS on a Sonim XP5s phone
                                            by keeney123
                                            To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                                            I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                                            05-13-2022, 07:19 PM
                                          • abajor
                                            Canon VIXIA HF S10 A read data from inernal flash memory.
                                            by abajor
                                            Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                            Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                            The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                            I think my best shot is to figure out a way to read the internal flash memory outside...
                                            07-20-2024, 12:04 AM
