Dumping flash from HTC Desire 510
    • 31017
    Re: Dumping flash from HTC Desire 510
    simlock code generator is common.
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      #82
      Someone gave me a Sprint HTC Evo 4G, which is a CDMA phone I believe. There's no SIM Slot. Carrier unlocking that thing doesn't seem to be simple. I've unlocked the bootloader and turned the security bit off so it shows S-Off. There's a SIMLOCK function under HBOOT and I've generated the Config.dat file, but it always hangs at the Wait for AMSS Ready. If I hit the power button, then it complains about something not being a key-card.
      I'm doing some research on it, but I'd love to unlock it so I could put that on the Straight Talk network. I think it might involve putting a different firmware on it, like one that was made for a Straight Talk HTC Evo 4G.
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
        • 31017
        have you opened it?
        we have not used that technology in Europe for 20 years.
        i would be curious if it has a sim hidden deep inside.
        on the older phones the IMSI/IMEI had to be changed with custom software to one supplied by the carrier.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          #84
          ^ Havn't seen integrated SIMs in the Western US for about 5 years now. My old Huawei Ascend M865 had an integrated SIM. Wish it had the option for a SIM card, but thats the European version that has one... Man did that thing fly with a 2x overclock! Android 2.3.3 running on a 600mhz CPU clocked at 1.2Ghz! Most extreme OC i ever did.... I miss that thing...
          Follow the white rabbit.
            • 31017
            only thing i miss about the analog phones was the motorola trick where you short 2 of the pins on the battery connector with a thin wire and long-hold "*" to activate a hidden mode that turned it into an open radio where you could step through the channels and listen to everyone!!!
            • Spork Schivago
              • Mar 2012
              • 4734
              #86
              have you opened it?
              We replaced a cracked screen on it. It was his first smart phone and paid us to repair the broken LCD screen / glass. Afterwards, he tried putting it on the Straight Talk network and couldn't, so he just gave it to us. For fun, I was going to see if I could put it on the Straight Talk network. I believe it's a 4G phone. There is no SIM. I think I can just take it to StraightTalkBYOP.com and enter the info and they can put it on their network, because they use Sprint Towers, among other towers (AT&T and even Verizon I think).
              I don't think changing the IMEI would be hard. I think maybe something called the MEID might need to be changed though, I dunno. I think it involves getting a CDMA donor phone that goes on Straight Talk and copying the MEID over. Essentially, you clone the phone.
              It's been a great learning experience though and I've had fun playing with it, despite it being an older phone.
              • Spork Schivago
                • Mar 2012
                • 4734
                #87
                My friend had this cheap TracFone (I think) that broke. He could add minutes, but couldn't make any phone calls and couldn't receive them, but what was cool, he could send an unlimited number of text messages and the minutes would never go down.
                I wanted to buy it off of him to have almost free texts for life. You'd still have to put minutes on it every once in awhile to keep it active, but they had this card that costed like 20$ and it'd keep the phone active for a year, without needing to put minutes on it. He ended up calling TracFone (or whoever) and they sent him a free mailing label, he sent it in, they sent him a replacement.
                  • 31017
                  there was a gsm phone you could do that with by putting a pic chip in it to constantly re-write the remaining credit into the phones eeprom.
                  they didnt make that mistake again!!
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #89
                    So a little update with the hacking of the HTC Desire 510. We bought a MicroUSB to USB OTG cable from BestBuy. I wanted to reprogram one of these Teensy boards I had and make it into a pin generator for cells, even though I wasn't expecting it to work with the Desire 510.
                    I plug the cable into the 510 and then I plug a USB keyboard into it, just for shits and giggles, and I can type the PIN with the USB keyboard. So I'm pretty certain I can program one of these Teensy boards. When I was looking for an adapter in the basement, I found two other ones. A Teensy 2.0 and a Teensy 3.6. I think I'll try with the Teensy 2.0.
                    I'm pretty sure it won't be hard to write the program to send the 4 digit pins and then pause 30 seconds after 5 attempts....but I'm not sure how the Teensy board could tell if a valid PIN was entered. Any thoughts on that? The Teensy 3.6 has a MicroSD slot, so I could use that to write down the valid PIN, if I can somehow detect when that happened.
                    Thanks!
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #90
                      The Teensy doesn't need to know if the pin was entered correctly. One it unlocks the phone its done its job
                      Code that can be used was in the link goontron posted.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        #91
                        That code that Goontron sent I don't think is for the Teensy. I was looking at it, and I think it's more of script for a configurable key. Kinda like what I'm using, but I think you can configure it for various things. For example, the only code in that link was to generate a text file with 9,999 numbers from 0000 to 9999 or something like that, at least from what I've seen.
                        You put it on the MicroSD card and the Ducky Key will load it or something.
                        Anyway, I wrote a simple program for the Teensy 3.6 that I have. It enters the pins, then waits 35 seconds or so. I still need to fine tune it a bit (like to hit enter after 5 failed attempts to do away with the message that displays). And to hit a button every few seconds when the 30 second countdown begins so it doesn't lock the screen.
                        The problem is the phone knows I'm trying to hack into it and it starts a shutdown timer (you can see the little icon pop up in the top bar there). After it's been turned on for x amount of seconds, if a proper pin isn't entered, the phone restarts.
                        I can modify my program to stop counting when the phone restarts, but I don't know if the USB port resets during this process. It might restart my program, and if so, I need to take advantage of the MicroSD slot to keep some sort of lock file on there.
                        So, the program will wait until the phone turns on and gets to the lock screen. Then it'll act as a mouse and swipe the screen up to get to the enter pin screen. It'll enter 5 sets of pins and then wait 30 seconds or so. Every time it tries a pin, it'll write it to a file on the MicroSD card. It'll create a lock file. The first time the program runs, it'll look for the lock file. If the lock file is there, it'll always wait the amount of time that it starts for the phone to start up, and then do the finger swipe. Then, it'll read the MicroSD card to see where we left off counting and start from there.
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          #92
                          ^Huh? Oh. Yeah, no. That's Ducky Script. https://github.com/hak5darren/USB-Ru...ki/Duckyscript
                          Wouldn't be hard to port the firmware/compiler, but yeah, no.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            #93
                            Yeah. I think, for the most part, it'd probably be easier and less work to just continue the program I've written. Unfortunately, I couldn't figure out how to just use my favourite text editor and make to compile the hex. I can with the Teensy 2.0 dev board, but for the Teensy 3.6, I have to use the TeensyDuino thing, which I don't like at all, but I guess it makes it a bit easier to do the things I want to do.
                            For example, I just had to call a delay(<ms>); function in the startup code, and then in the loop code, I just call Keyboard.print(number); to print whatever I want to the screen.
                            I believe these functions might be libraries that come with the TeensyDuino. It kinda hides all the real code. I don't really like programming that way. I like having a Makefile and if I'm using a library, link it statically to my object files, etc. But I was in a bit of a rush and didn't have a lot of time to try and figure out how to compile code for the Teensy 3.6 the way I wanted to.
                            There's a sample Makefile and they tell you how inside what you need to do, but it wasn't the clearest. The chip on the 3.6 is an mk66fx1m0.
                            The avr cross-compiler doesn't support this chip. The chip is made by NXP. I think it's the Kinetis K-Series architecture. Supposedly there's some optimized C compiler by Green Hills, but I think this mk66fx1m0 is based on ARM Cortex-M4 Core, so maybe I can just download the compiler from ARM?
                              • 31017
                              yes, use Linux and download "gcc-arm-none-eabi"
                              you also need std-c and various tools, but the package-manager will handle that.
                              or use windows, and install the arduino package.
                              then select the duo board and it will download the arm compiler.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                #95
                                That's it? Just download gcc-arm-none-eabi? What's the eabi stuff about? I believe it stands for Embedded Application Binary Interface. I don't really understand it though. Wikipedia says:
                                Code:
                                In computer software, an application binary interface (ABI) is the interface
                                between two program modules, one of which is often a library and/or operating
                                system and the other one is usually an application created by a regular
                                programmer.
                                So does it have something to do with libraries? I don't get it.
                                **EDIT: It might be called cross-arm-gcc7 and cross-arm-binutils on my OpenSuSE Tumbleweed distro. But what do I pick for the processor type? I had these installed last night and -mmcu=mk66fx1m0 doesn't work.
                                These are the available packages that are compiler related:
                                Code:
                                eugene:/home/spork/src/pin_cracker # zypper search arm
                                 | cross-arm-binutils         | GNU Binutils                           | package
                                 | cross-arm-gcc6           | The GNU C Compiler and Support Files               | package
                                 | cross-arm-gcc7           | The GNU C Compiler and Support Files               | package
                                 | cross-armv6hl-gcc6         | The GNU C Compiler and Support Files               | package
                                 | cross-armv6hl-gcc6-icecream-backend | Icecream backend for the GNU C Compiler              | package
                                 | cross-armv7hl-gcc6         | The GNU C Compiler and Support Files               | package
                                 | cross-armv7hl-gcc6-icecream-backend | Icecream backend for the GNU C Compiler              | package
                                I installed cross-arm-gcc7, but that installs the gnueabi gcc, not the none-eabi one. I can't figure out how to use zypper to tell me what files each package provides yet, I'm searching google.
                                Last edited by Spork Schivago; 07-08-2017, 12:56 PM. Reason: added stuff about arm cross compiler
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #96
                                  I think I can figure this out. I can download the source and compile myself or find a precompiled binary for OpenSuSE, or I can just use the one that comes with Arduino and just manually copy it (which might be a bad idea).
                                  I noticed, after looking through the Makefile for the TeensyDuino stuff that got installed for the Arduino stuff, I see:
                                  Code:
                                  -mcpu=cortex-m4
                                  So that answers one question. Just a matter of finding a repository with a compiler version that would work. I almost want to use some of the libraries, at least for now, that comes with the TeensyDuino / Arduino stuff. Makes it a lot easier. Wonder if I can just link to them using the gcc-arm-none-eabi compiler....
                                    • 31017
                                    source
                                    https://launchpad.net/gcc-arm-embedded/
                                    arduino stuff uses arduino library's
                                    so maybe read here:
                                    http://www.stm32duino.com/
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      #98
                                      source
                                      so maybe read here:
                                      I found an OpenSuSE Tumbleweed repository that just includes the gcc-arm-none-eabi compiler, the bintools, and GDB. I downloaded and installed it. I still need to play with it.
                                      What's kind of nice is I can look at the TeensyDuino Makefile and see how they set certain things up. For example, they're using the nano.specs file that they point the compiler to. This is nice, because then I don't have to define stuff like _SBRK or whatever it is.
                                      The libraries, even though they're Arduino libraries, I don't see why I couldn't just link to the ones I needed with the compiler. I was looking at the TeensyDuino / Arduino stuff a bit more closely and noticed they use the gcc-arm-none-eabi compiler, just a bit of an older version. I think they're using version 5.x and I've downloaded and installed 6.x through the repository.
                                      I'm having some issues with the phone and program though. There's a few bugs I need to work out. For example, when the, You've entered 5 invalid attempts, you need to wait 30 seconds message appears, I program the Teensy to hit enter to do away with the message, but if I don't touch the screen every 5 seconds or so, it'll turn the screen off and needs to be unlocked again (with the finger swipe).
                                      So I programmed the Teensy to work as a keyboard, mouse, and touch sensor or whatever it is. The touch stuff looks a bit hard, but I've programmed it so the mouse pointer moves up every 5 seconds or so. This prevents it from locking. What I do is configure the screen size (854 x 480) in my code, then I position the mouse pointer to 427, 20 (x, y). I'll move the mouse up 100 pixels or so, then click, then release. Then reposition the pointer to 427, 20. but the repositioning isn't working. I think I just need a delay after moving it up. I can see the mouse move every 5 seconds or so, and that prevents the screen from locking, but once the mouse pointer gets to the very top of the screen, it locks. Worse case, I can move the mouse up 100 pixels, then after the next 5 seconds, move it down.
                                      One problem though, after 10 attempts, the program always starts back at 0000, like the USB port resets or something. I gotta find away to tell when the phone is at the login screen. I heard the JTAG VCC drops after a bit. Maybe I can use that? I still need to implement the MicroSD card stuff. When the phone restarts, the Teensy gets reset, every time.
                                        • 31017
                                        tbh the only stuff i did with arm yet is customise other peoples work.
                                        and those people dealt with all the seperation of the shit from usefull stuff first.
                                        the only library they used was LibOpenCM3
                                        which btw, looks really nice.
                                        http://libopencm3.org/
                                        • Spork Schivago
                                          • Mar 2012
                                          • 4734
                                          #100
                                          Okay, I've fixed almost all the bugs now. The only thing I'm having trouble with is during the 30 second countdown (after 5 failed attempts), after 10 seconds or so, the screen goes dark and then locks. Gotta figure out how to keep that active still so it doesn't go dark.
                                          Finally, I need to write code to store the pin on a MicroSD card, so when the phone reboots, it'll start off where it left off at, not start over at 0000.
                                          Then I can just let this run and away we go. I think I'm going to need to use my programmable power supply and take the battery out of the phone and use that to power it, so the phone battery doesn't go dead.
                                          • SluggerB
                                            Help with trying to fix phone that is not charging (Pics inside)
                                            by SluggerB
                                            I have two TCL A30 phones.
                                            Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                            New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                            My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                            08-12-2024, 08:11 AM
                                          • ekozeko333
                                            by ekozeko333
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • keeney123
                                            new OS on a Sonim XP5s phone
                                            by keeney123
                                            To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                                            I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                                            05-13-2022, 07:19 PM
                                          • abajor
                                            Canon VIXIA HF S10 A read data from inernal flash memory.
                                            by abajor
                                            Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                            Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                            The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                            I think my best shot is to figure out a way to read the internal flash memory outside...
                                            07-20-2024, 12:04 AM
