[Important] Toshiba A300-1MM Thermal pad size
  • harispap
    • Jun 2016
    • 14
    • Earth
    I have a Toshiba Satellite A300-1MM Laptop (this model has a INTEL GMA gpu and not a ATI Radeon one). My problem is that the thermal pad on the Graphics Card was removed by an unskilled techinician who have cleaned my laptop 2 yeara ago (I didnt know how to clean it back then) and replaced by paste. However, as i see, the gpu does not make solid contact with the heatsink just with paste.
    Can you please tell me the size of thermal pad i need to purchase? I have found this image which may be helpful
  • diif
    • Feb 2014
    • 6978
    • England
    Re: [Important] Toshiba A300-1MM Thermal pad size
    Probably 1m thick.
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Anything more than thick is fine . The screws pressure will handle the rest .
      • harispap
        • Jun 2016
        • 14
        • Earth
        Thank you for your replies! You replied faster than I expected
        Is this thermal pad OK for use in this laptop? http://www.e-shop.gr/ek-water-blocks...m-p-PER.816106
        If not, can you please recommend me another one from this site?
        Thank you very much for your interest!
        • piernov
          • Jan 2016
          • 4437
          • France
          You can't use a thermal pad that's too thick. Under the pressure of the heatsink it will split in two and therefore not make good thermal contact. Most of the time I use 1mm so it should be fine. Sometimes 1.5mm (or thicker) but not on the BGAs, they are found on VRAMs, coils or MOSFETs for example.
          • harispap
            • Jun 2016
            • 14
            • Earth
            Is thermal conductivity 3.5w/Mk 1MM thermal pad enough for the GMA? I see some 8.5 w/Mk thermal pads, but too expensive , and I dont think that this GMA chip needs so much thermal conductivity
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              More than enough . Anything will do fine , as Intel GMA do not heat that much , not like those equipped with ATI or the heatmonger Nvidia .
              Grab any water thermal pad if you have some junk parts . What you should care of in those A300 series is the void between the GMA chipset and the ventilation system .
              Due to a very poor design , sometimes the four screws holding the Ventilation system become loose or come already loose ..
              • m4a2t0t
                • Mar 2013
                • 276
                Am I the only one who hates thermal pads? In every system that I have replaced the thermal pads (with a BGA reball/replacement) with a copper shim they rarely need to be repaired again. Best thing about the shim is you can sand it down to a perfect fit and then use finer sandpaper to polish it back up.
                • harispap
                  • Jun 2016
                  • 14
                  • Earth
                  Thank you for your replies! I ordered a 1MM 3.5w/KMk thermal pad and it is coming on Monday-Tuesday.
                  • harispap
                    • Jun 2016
                    • 14
                    • Earth
                    I installed the pad and Artic MX-4 paste on the CPU and it has very good temperatures (max 70*C with 36*C ambient temp)
                    Thanks for your help!
                    • Veyron7887
                      Laptop overheating after replacement thermal paste
                      by Veyron7887
                      Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                      11-24-2024, 05:08 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • caspian
                      Can thermal paste cause corrosion?
                      by caspian
                      Dear members,
                      I have got an ordinary gray thermal paste that has no name/model on the box.
                      I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
                      I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
                      Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
                      Is it safe to leave the thermal paste on the pins?
                      I guess the thermal paste...
                      06-19-2020, 10:47 AM
                    • Fobo
                      What kind of Thermal Paste is this?
                      by Fobo
                      I bought a laptop in parts and was going to assemble it and looked on youtube and saw that it was some type of Thermal Paste on the vrams
                      What kind of Thermal Paste is this on the vrams insted of thermal pads?
                      the picture is taken from youtube movie
                      11-22-2023, 06:20 PM
                      09-06-2024, 05:27 AM
