What kind of Thermal Paste is this?
  • Fobo
    • Feb 2022
    • 31
    • Sweden
    I bought a laptop in parts and was going to assemble it and looked on youtube and saw that it was some type of Thermal Paste on the vrams
    What kind of Thermal Paste is this on the vrams insted of thermal pads?
    the picture is taken from youtube movie
  • diif
    • Feb 2014
    • 6978
    • England
    i worked on one of these at the weekend, there didn't seem anything special about the old paste I removed. I used MX-2
    • Fobo
      Fobo commented
      Editing a comment
      So what did you do with it? you possibly don't have any info on 3 components that are on the card that I'm missing on mine
      Do you have Boardviews for this model?
  • Dobrowol
    • Dec 2020
    • 9
    • Poland
    This is special thermal paste to cooling vrams ect. It cannot be replaced with standard thermalpaste
    • diif
      • Feb 2014
      • 6978
      • England
      What is special about it ?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3703
        • slovakia
        • hard-enduro
        it is kind of thermal putty. if cooler dont have strong grip u must use putty , because pads will not be squeezed enough to make good contact
        • Fobo
          Fobo commented
          Editing a comment
          ok niece tanks for the info!!
      • volinakis
        • Jan 2021
        • 3231
        • N/A
        or use thicker thermal pads ...
        please support this forum
        • khaahk
          • Dec 2013
          • 906
          • Estonia
          Something like that:
          https://computer-systems.gr/products/k5-pro-20g/
          • Veyron7887
            Laptop overheating after replacement thermal paste
            by Veyron7887
            Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
            11-24-2024, 05:08 AM
          • maxbers
            Asus ZenBook 14 UX425EA – Won’t Turn On After Thermal Paste Change
            by maxbers
            I’m new here and I’m trying to learn some board-level repair skills.
            I have an Asus ZenBook 14 UX425EA that won’t turn on after a thermal paste replacement. The laptop was fully working before the disassembly. I only removed the cooling system to clean the CPU and apply new thermal paste.
            Current behavior:
            • No normal power on
            • Battery only: the white power LED turns on for a few seconds, then turns off. No display, no fan activity. I must disconnect the battery or hold the power button for ~15 seconds to get the LED again.
            • AC only: the white
            12-09-2025, 12:29 PM
          • Tesla
            Thermal-Paste and Heat-Sink-Compounds - Common Questions
            by Tesla
            So, for laptops (sometimes it just has a CPU, but sometimes also a dedicated GPU as well) ...
            Is there anything wrong with using a good (non conductive) general purpose one like GC-Electronics Type-Z9 Heat Sink Compound. I've used it for AVRs and older Intel desktops (like Core-2) and it seemed fine. I like the idea of using a non-conductive one (very little chance of anything getting shorted-out because of it ending-up in the wrong place). It's Silicone based.
            If you don't care for that one (maybe not specialized enough for a hot recent UltraBook) what do you think of...
            03-28-2026, 08:36 PM
          • caspian
            Can thermal paste cause corrosion?
            by caspian
            Dear members,
            I have got an ordinary gray thermal paste that has no name/model on the box.
            I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
            I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
            Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
            Is it safe to leave the thermal paste on the pins?
            I guess the thermal paste...
            06-19-2020, 10:47 AM
          • Boardview and Schematic Bot
            General Rules - Thermal Pad Thickness for Laptop GPUs & Motherboards
            Our user Devicefixer kindly sent this advice. Feel free to append your own tips to this thread
            Thermal Pad Thickness Guide for Laptop GPUs & Motherboards
            General Rules of Thumb for Laptop GPUs:
            When specific schematics or manuals do not specify thermal pad thickness, these general rules
            apply to most modern gaming laptops (NVIDIA GTX/RTX and AMD RX series):
            VRAM (Video Memory Chips): Typically 0.5mm or 1.0mm. (Using pads that are too thick here will
            prevent the heatsink from making contact with the main GPU die, causing instant overheating)....
            02-27-2026, 05:38 AM
