What kind of Thermal Paste is this?
  • Fobo
    • Feb 2022
    • 25
    • Sweden
    I bought a laptop in parts and was going to assemble it and looked on youtube and saw that it was some type of Thermal Paste on the vrams
    What kind of Thermal Paste is this on the vrams insted of thermal pads?
    the picture is taken from youtube movie
  • diif
    • Feb 2014
    • 6978
    • England
    i worked on one of these at the weekend, there didn't seem anything special about the old paste I removed. I used MX-2
    • Fobo
      Fobo commented
      Editing a comment
      So what did you do with it? you possibly don't have any info on 3 components that are on the card that I'm missing on mine
      Do you have Boardviews for this model?
  • Dobrowol
    • Dec 2020
    • 9
    • Poland
    This is special thermal paste to cooling vrams ect. It cannot be replaced with standard thermalpaste
    • diif
      • Feb 2014
      • 6978
      • England
      What is special about it ?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3607
        • slovakia
        it is kind of thermal putty. if cooler dont have strong grip u must use putty , because pads will not be squeezed enough to make good contact
        • Fobo
          Fobo commented
          Editing a comment
          ok niece tanks for the info!!
      • volinakis
        • Jan 2021
        • 2744
        • N/A
        or use thicker thermal pads ...
        • khaahk
          • Dec 2013
          • 781
          • Estonia
          Something like that:
          https://computer-systems.gr/products/k5-pro-20g/
          • Veyron7887
            Laptop overheating after replacement thermal paste
            by Veyron7887
            Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
            11-24-2024, 05:08 AM
          • caspian
            Can thermal paste cause corrosion?
            by caspian
            Dear members,
            I have got an ordinary gray thermal paste that has no name/model on the box.
            I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
            I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
            Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
            Is it safe to leave the thermal paste on the pins?
            I guess the thermal paste...
            06-19-2020, 10:47 AM
          • dicky96
            Best solvent for removing thermal paste from LGA sockets?
            by dicky96
            So I have TUF Z390 mobo with a bit of the grey thermal paste in the LGA 1151 socket right near one edge. probably from when the clamp was fastened down without a CPU fitted, and there was a bit of paste on the clamp.
            The motherboard actually works fine (you can see there is no thermal paste on the ends of the pins themselves), but it would be nice to clean it out.
            I've done a bit of googling and found suggestions from using this stuff....
            https://www.ebay.co.uk/itm/Arctic-Si...er/27411405412...
            02-09-2021, 11:46 AM
          • corrize
            Asus Zenbook DUO UX481F – small water damage and thermal paste
            by corrize
            Hello, the laptop has a resistor cdamaged by water and dead (open line) close the charging chip. I will replace it soon.
            I found a lot of thermal paste on coils and componets close CPU.
            With meter, I saw 2,6 Ohms between ground and shunt resistor close power jack. So I guess it's too low.
            I don't find true short (0 Ohms) on the board, no coil shorted.
            I don't found bad mosfet (shorted drain-source). I found 2,6 Ohms to the « output » of the second mosfet close power jack.
            I found a coil (close CPU) at 2,6 Ohms.
            I measured between the output of 2sd mosfet...
            04-11-2022, 03:02 PM
          • eccerr0r
            cheap but good thermal paste?
            by eccerr0r
            What's the cheapest thermal paste people get that's consistently "decent" ... I'm wondering if I should switch from zinc oxide to something else, but don't want to be disappointed.
            Again needs to be cheap... ideally something as cheap as zinc oxide but I figure if it's claimed "better" then it means "more expensive"... which would add to the disappointment.
            07-10-2021, 05:02 PM
