Lenovo NM-D562 v2.0 main EC programming help needed
  • questore
    • Dec 2015
    • 486
    • csongrád
    Hello Everyone,
    I have this board that has an autostart as soon as i connect the charger (no POST) and restarts after 20 seconds. cannot be turned off.
    I'm suspecting main EC firmware problem (IT8227E-192)
    Since this board has only EC_KSI6 and EC_KSI7 pin on keyboard connector to the EC this cannot be programmed trought it.
    I would like to know if anyone can give me instruction how to program the EC.
    In the Vertyanov tutorial instructions I have seen that alternative is using 8pin direct cable soldered to board.
    Anyone knows hows if that is working with ITE chips or just with ENE?
    What software options i need to use?
  • khaahk
    • Dec 2013
    • 756
    • Estonia
    Are you sure it is 192 not 256?
    You can use ite via i2c method, what's the JIG version?
    • questore
      • Dec 2015
      • 486
      • csongrád
      I have not disassembled it yet so dont know it its a 192 or 256 I have only took a look at the 1.0 schematic and boardview
      JIG is rev 4.2
      • khaahk
        • Dec 2013
        • 756
        • Estonia
        JIG3 and successor both support the i2c method. Connection via battery smb clk and data lines. 2 wires+gnd.
        • questore
          • Dec 2015
          • 486
          • csongrád
          OK but from where should I connect the wires and what software should i use
          • khaahk
            • Dec 2013
            • 756
            • Estonia
            Not sure what is JIG4.2, are you sure it is vertyanov?
            • questore
              • Dec 2015
              • 486
              • csongrád
              Now I dont know, I did not have any problem with it until this i2c.
              I have ordered it from this:
              ioprogrammer.com
              • khaahk
                • Dec 2013
                • 756
                • Estonia
                Then you have to contact the seller for software, as i understand Vertyanov has built into new version of his software a lock which might brick non-original programmer.
