Lenovo ideapad 5 windows 11 update disable charging circuit?
  • bogart219
    • May 2009
    • 200
    • usa
    #81
    Originally posted by mon2
    Which side?
    The bottom side
    • m1ch43lzm
      • Mar 2019
      • 1094
      • Peru
      #82
      Edit: please post a picture of the area around both inductors
      One side of the inductors should have continuity to the fuses, the other side won't
      Measure resistance to GND at the fuses
      • bogart219
        • May 2009
        • 200
        • usa
        #83
        Here you go!
        Click image for larger version  Name:	2020_0303_074334_002.jpg Views:	0 Size:	2.79 MB ID:	3648257
        Top side of both inductor pads have continuity to the two fuses, the other side don't, like you indicated.
        Question, in my resaerch, a guy on UT said that coils (inductors) are always connected to the positive rail only, is this an accurate statement?
        • m1ch43lzm
          • Mar 2019
          • 1094
          • Peru
          #84
          The short could be in the cap marked in red PC8309, or any other cap near the BQ on the other side of the board
          To double check, measure resistance across PC8309 if you still have 43ohm
          In yellow i marked what appears to be some stray solder? Inspect the board for stray solder blobs
          You haven't posted the resistance measurements, you may edit the picture with the measurements written on it
          If you're confortable with voltage injection, set your bench PSU to 1v (don't go higher, double check with multimeter) and solder a wire to the bottom of PL8301-PL8302, connect that to the + of the bench PSU
          The GND you can connect to a screw hole
          Take note of the current draw, check with the thermal camera which component gets hot, may be a cap near the BQ, PC8309 or PC8307 near the audio IC (unlikely)
          • bogart219
            • May 2009
            • 200
            • usa
            #85
            Yes still have 46 ohms across PC8309. Took care of the solder gob. Could you please tel me again what resistance measurements you want?
            Due to space constraints, I'm doing this smd work, not on my work bench but on a table next to my computer. My bench PSU is on my bench, I will have to make room and move my camera over there. I'll get back to you, Thanks!
            • m1ch43lzm
              • Mar 2019
              • 1094
              • Peru
              #86
              So the short is on the input of the BQ charger, could be anything from a cap, to the BQ itself
              Normal resistance should be several Kohms or higher (maybe unstable value as there are caps in parallel, thats ok)
              OK, please post resistance measurements:
              - Across CU206 (+5VALW), should be very high on Kohms - Mohms
              - From PF8302 to GND (TBT_VSYS), now it should be very high in Kohms or more
              • bogart219
                • May 2009
                • 200
                • usa
                #87
                Hello, I just did those test with soldering wires to the bottom of PC8301 & PC8302. was pulling between 200 & 300 at .9 volts. this cap in the picture was glowing. and looks discolored. I believe its PC5302 going by board view.
                NO Glowing on the BQ chip, PC8309 or PC8307 The cap in the pic Glowing like a bitch.
                CU206 to ground = .2 ohms across the cap = 14.2 ohms !
                PF802 to ground = O/L
                • m1ch43lzm
                  • Mar 2019
                  • 1094
                  • Peru
                  #88
                  I can't see the picture (maybe the forum ate it?), but you can remove PC5302 and the short should be gone
                  Is this one?
                  Click image for larger version  Name:	cappc5302.png Views:	0 Size:	93.1 KB ID:	3648422
                  Unless its one of the caps on the other side of the board
                  But the low resistance on +5VALW worries me (14ohm), could be anything on the board, a cap, the TPS65994 or anything
                  • bogart219
                    • May 2009
                    • 200
                    • usa
                    #89
                    Is this one?
                    Sorry about that, that png must of been to big, here is a jpeg:
                    Is that a different boardview you use, its colorful not black and white?
                    • bogart219
                      • May 2009
                      • 200
                      • usa
                      #90
                      Brother, I got to leave the house and go and baby sit my grand kids.Thanks for all your help and knowledge. We can take this up tomorrow if you don't mind. Have a good evening
                      • m1ch43lzm
                        • Mar 2019
                        • 1094
                        • Peru
                        #91
                        The software i used is FlexBV free edition by inflex aka Paul Daniels (@pldaniels on YT), he repairs mostly Apple laptops, sometimes other brands on his livestreams
                        https://www.badcaps.net/forum/troubl...acos-and-linux
                        Take care, have a good day too
                        • bogart219
                          • May 2009
                          • 200
                          • usa
                          #92
                          Good morning. I'm going to remove PC5302 and see what happens. The two mosfets and two inductors are still out of the board.
                          Just a quick recap, this lappy would not turn on or charge the battery. I replaced the power adapter and the battery., still nothing. The lappy did work with the battery hooked up but not just the adapter. The adapter would not charge the battery. I was able to charge the battery from my bench top PS.
                          The usb test meter showed 5 volts and no amps. Was getting 5 volts to two mosfets but the resistance readings of the those two looked screwy. Replaced the two mosfets with new ones, which I had a hard time doing. (new to this smd rework).
                          After replacing the fets, retested. Usb tester shows 5 volts but now at 6 to 700milliamps. removed the two fets I replaced and it still showed 6 to 7 hundred ma. Removed two inductors, the same.
                          Appears the TPS chips + terminals read to ground. It must be something I did when removing those fets, I'm assuming I mucked something up, or did I. I put Kaption tape all around those fets and used flux but something changed. I'm lost at this point.
                          I did a voltage injection of 1 volt pulling 2-300 ma. Found a cap near the BQ chip on the other side of the board glowing. (thermal camera). Will remove and see what happens.
                          • bogart219
                            • May 2009
                            • 200
                            • usa
                            #93
                            Removed PC5302. The short is still there, 5 volts 650 milliamps, F**K.
                            Removed PC8309 no difference.
                            After removal of the top two caps, voltage injection no longer produces any current at 1 volt.
                            TPS charge controller still red hot
                            • m1ch43lzm
                              • Mar 2019
                              • 1094
                              • Peru
                              #94
                              There's no way for the 5V from the charger to go to the system and draw 650mA, as the inductors and MOSFETs are removed from the board
                              VBUS_TBTA/VBUS_TBTB go straight from the USB-C ports to the TPS65994, and some other components, and that's the only IC with connections both to +5VALW and the USB-C ports
                              Suspect a dead TPS65994 as you still have a short on +5VALW of 14ohm, I told you that's not normal, that line should read from tens of Kohm upwards
                              Do not apply power to the board until that is fixed (5VALW showing a healthy resistance) and the TPS65994 is replaced along with the MOSFETs and inductors, I should have told you that, sorry
                              The shorted cap near the BQ was another issue, probably related to the original fault, as that's on the input of the BQ, in your laptop the BQ generates the main power rail, and charges the battery
                              • bogart219
                                • May 2009
                                • 200
                                • usa
                                #95
                                Wow,some of what you said I don't quite understand. I bought that TPS65994 chip when I got the mosfets. Does this chip need reprogramed? If not I will hopefully replace the TPS65994 and put back the two mosfets and two inductors and then see if my short went away. I'll address those two caps after that.Thanks.
                                • bogart219
                                  • May 2009
                                  • 200
                                  • usa
                                  #96
                                  Man, my confidence is getting low using this hot air gun taking off some of these components. I'm feeling like I bit off more than i can chew. Those last two caps I removed, I used 420 degree heat at 50% and it seemed like it took for ever. I used flux and put aluminum tape (seen a guy on YT suggest using that, I have a couple rolls from my HVAC days), around them instead of Kaption tape. Maybe that aluminum is sucking all the heat?, I don't know. I will proceed with caution. Very disappointed in my smd skills
                                  • m1ch43lzm
                                    • Mar 2019
                                    • 1094
                                    • Peru
                                    #97
                                    I'm not 100% sure if the TPS65994 needs to be programmed, or if it can be programmed by the motherboard when it powers on
                                    Practice first on a dead board, this chip has a large GND pad on the underside, may require more heat, about 430-450 C I think, you don't want to rip the pads on the board
                                    Afterwards tin the pads with 63/37 solder+flux
                                    TI forums suggest that the chip has an internal ROM and they "spin" a new revision when the USB spec gets updated, and datasheet suggests that it communicates with the EC and the thunderbolt controller
                                    I think it can program itself, if anybody has experience replacing TPS65994 please come in here
                                    I have to go out, I won't be able to reply until late afternoon
                                    • bogart219
                                      • May 2009
                                      • 200
                                      • usa
                                      #98
                                      Yeah ok friend, have a good afternoon!
                                        • 22216
                                        The firmware is stored on an external 1MB chip.
                                        https://www.badcaps.net/forum/troubl...65994ae-eeprom
                                        https://www.badcaps.net/forum/troubl...are-request​
                                        • bogart219
                                          • May 2009
                                          • 200
                                          • usa
                                          #100
                                          Originally posted by SMDFlea
                                          Hello, a few questions if you please. 1) Is this external chip something I can get? 2) How do I write it to my new TPS chip? 3) This is not a bios file correct, totally different correct? 4) where do I go to get this eeprom or chip? thank you very much1
                                            Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:20 AM
                                            Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
