Lenovo ideapad 5 windows 11 update disable charging circuit?
  • m1ch43lzm
    • Mar 2019
    • 1094
    • Peru
    #41
    Sorry, I made a typo, it's SM3313NSQG, those are available at AliExpress or eBay from China, but I'm trying to find an equivalent replacement from another manufacturer that's available at mouser/digikey
    I suggest ordering several
    Maybe mon2 could you suggest an alternate part that's suitable? Thanks in advance
    EDIT: you beat me again 😁
    • bogart219
      • May 2009
      • 200
      • usa
      #42
      Thank you m1ch, you and mom2 have been a lifesaver.
      • bogart219
        • May 2009
        • 200
        • usa
        #43
        Good morning. Is this the correct chip to get? From AliExpress. These are NPN , YES?
        I believe they come in a pack of five (circle), is that correct? Thanks
        • mon2
          • 14781
          NPN? Do you mean DFN = dual flat no-lead package? Yes, you have selected the correct part # and yes 5 pcs to a purchase. The fast delivery option is ~2 weeks to Canada and your case may be similar. If in a rush, you can select the replacement from Digikey (USA). If you are shopping on Aliexpress, very likely the same store will offer the other mosfets that surround this area of the board. Does not hurt to purchase them as spares as well.
          • m1ch43lzm
            • Mar 2019
            • 1094
            • Peru
            #45
            With the current tariffs in the US for goods coming from china, even for small packages, I suggest buying the alternate parts from digikey or mouser
            mon2 what do you think about this one? The schematics you posted mention AONR32314 but they're out of stock, there's AONR32318 but the package is bigger (DFN 3x3 for the 32314 vs DFN3.3x3.3 for 32318)
            AON7522E
            https://www.digikey.com/en/products/...n7522e/3603566
            Order 10 and it's 5.2 usd +shipping
            Or this one?
            AONR36366
            https://www.digikey.com/en/products/...36366/10071205
            • bogart219
              • May 2009
              • 200
              • usa
              #46
              Hey moms, I mentioned npn because after watching a bunch of Sorin videos where he deals with mosfets, and he has said that this one is a npn while this one is a pnp. Maybe I misunderstood him.
              Also in another video where he was tracking down where the 19.7 volts where on a dead lappy, he said that he found 19 volts on what he called the input of the mosfet (drain) and nothing on the source (source). He said the mosfet was nothing but a switch. what he ended up doing was removing the mosfet completely and soldering a bridge between the drain and the source, then the lappy worked. Do you think this is a good way to think of this mosfets?
              I will place the order at aliexpress. Thanks!
              I looking for a decent budget digital microscope now, the selection is mind boggling.
              • m1ch43lzm
                • Mar 2019
                • 1094
                • Peru
                #47
                bogart219
                You missed my post about replacement MOSFETs (we posted almost at the same time)
                Sorin probably meant channel N or channel P MOSFET, maybe his accent made you think he said npn or pnp
                To "turn on" a channel N MOSFET, the voltage on its gate should be higher than the voltage at its source
                From Google AI
                Here's a more detailed explanation: Gate-Source Voltage (VGS):
                The voltage applied between the gate and source determines the MOSFET's state.
                Threshold Voltage (VGS(th)):
                Each MOSFET has a specific threshold voltage. The gate-source voltage must exceed this threshold for the MOSFET to turn on.
                Replacing MOSFETs with wires, is the "dodgy way" as he calls it, in your laptop would be:
                1. Remove both PQ8304 and PQ8301
                2. Bridge S (pins 1-3) from PQ8304 to S of PQ8301, the drains are connected on the board (leave the gates unconnected)
                That would make the usb-c port near the HDMI port your "charge only" port, if you also do the same to PQ8302 and PQ8303, when the charger is plugged in you'll get 20v on the other port, possibly damaging a device connected to it
                So his "dodgy" repair would only work for leaving 1 port to be dedicated for "charging only", as you could infer from the second video i linked on post #28
                • bogart219
                  • May 2009
                  • 200
                  • usa
                  #48
                  AON7522E
                  Or this one?
                  AONR36366
                  I think I'm sticking with digikey or mouser. which one should I get?
                  • bogart219
                    • May 2009
                    • 200
                    • usa
                    #49
                    bogart219
                    Ha, I just seen this post for some reason. Yes it was N channel not npn. I would like to replace with the right part, I don't want to be "dodgy " if I can help it.
                    • mon2
                      • 14781
                      post # 40.
                      • bogart219
                        • May 2009
                        • 200
                        • usa
                        #51
                        post # 40.
                        Thanks mom, ordered
                        • bogart219
                          • May 2009
                          • 200
                          • usa
                          #52
                          good morning. In looking at the data sheet for that mosfit, I think I was taking measurements wrong. The dot on the chip was pin 1 but I assumed pin 1 was the gate where looking at the data sheet pin 1 is part of the source. I will retake the measurements and repost them. They should be more accurate this time also as I received my Andonstar 246S-M digital microscope yesterday Later!
                          • bogart219
                            • May 2009
                            • 200
                            • usa
                            #53
                            Guys, so sorry for giving you bad info. I should of look up that data sheet on those mosfits and know for sure what the hell I was testing. Here is the new results I just did. (it was a hell of lot easier with that microscope!).
                            This readings were taken with just the power adapter hooked up with the USB-C meter showing about 5.6 volts, NO BATTERY hooked up. It seems something screwing is going on with those mosfits. See what you guys think, thanks again for your time!!
                            • m1ch43lzm
                              • Mar 2019
                              • 1094
                              • Peru
                              #54
                              Still PQ8301 and PQ8303 are suspect according to the resistance measurements, hope you ordered at least 4
                              • bogart219
                                • May 2009
                                • 200
                                • usa
                                #55
                                Yes, I ORDERED FIVE plus the TPS65994 charge controller chip.
                                You know there is one thing I still don't understand. After watching a bunch of Sorin's video's on dead laptops, it seems when he pulls the motherboard out of the laptop and test it on his bench, that when he plugs in the the power supply with the battery disconnected, he is always able to find 19 volts somewhere on that board and then trace it down from there. On my board, It seems to me I can't find 19 volts anywhere even with the battery plugged in, just five volts. I can't sort this out in my head yet. Crazy.
                                • mon2
                                  • 14781
                                  TPS65994 is a power delivery controller which requires its own firmware (code) to operate. Once loaded, this controller will communicate with the external power adapter (USB-C) to extract and select the best PD contract (voltage & current) to power the logic board. By default, all PD adapters will wake up and offer 5volts which is what you are observing now. Once this PD controller is working, the communication over the CCx pins will select the 20v PD contract to power and also to charge the battery pack.
                                  • bogart219
                                    • May 2009
                                    • 200
                                    • usa
                                    #57
                                    I see, so in otherwords, its not going to do me any good. Could you use it, I'll send it to you if you want? thanks for the info. The parts are supposed to be here today. I'm going to do some practice removing and putting back those tiny chips on some boards I have laying around using my digital scope and heat gun. I got some chipquick and flux. I'd be lying if I said I wasn't a little nervous doing this repair but screw it, you got to get your feet wet sooner or later I suppose. As always,thanks!
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 1094
                                      • Peru
                                      #58
                                      Not sure about the heat gun, as long as it has proper temperature and air control, and you have a small nozzle, you don't want to burn the board or the surrounding components (or blow the small resistors/caps if the air pressure is too high)
                                      Otherwise I suggest you get a proper hot air station, maybe you can find an used one for a good price, avoid those cheap units that have a blower fan inside the handle itself, that attach to the main unit with a cable (858 and derivatives like 878/8586/898 etc.), instead get one with an air hose to the handle where the heating element is located
                                      • bogart219
                                        • May 2009
                                        • 200
                                        • usa
                                        #59
                                        [QUOTE=m1ch43lzm;n3638561]Not sure about the heat gun, as long as it has proper temperature and air control, and you have a small nozzle, you don't want to burn the board or the surrounding components (or blow the small resistors/caps if the air pressure is too high)
                                        Otherwise I suggest you get a proper hot air station, maybe you can find an used one for a good price, avoid those cheap units that have a blower fan inside the handle itself, that attach to the main unit with a cable (858 and derivatives like 878/8586/898 etc.), instead get one with an air hose to the handle where the heating element is located[/QUOt
                                        Hello. I bought this heat gun a couple weeks ago to try out. My work bench is pretty crowded. I thought I could try this to get the hang of it and then if I needed to, I could buy a better one. It only cost about $25. It has small nozzles. I didn't want to spend a lot of money on one because the reality is I probably won't be using it that much after I'm done with this repair (hopefully). Later
ID:	3638591 Click image for larger version
                                        • m1ch43lzm
                                          • Mar 2019
                                          • 1094
                                          • Peru
                                          #60
                                          That one may work with the 8mm nozzle, the temp you would set to around 400 deg C, depending on the board
                                          You may still have an use for it if you also do hobby electronics
                                          I thought you had a heat gun like the one below, that one is not suitable
                                            Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:20 AM
                                            Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook 1 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 1 14IJL7 boardview and IdeaPad 1 14IJL7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
