Lenovo ideapad 5 windows 11 update disable charging circuit?
The short could be in the cap marked in red PC8309, or any other cap near the BQ on the other side of the board
To double check, measure resistance across PC8309 if you still have 43ohm
In yellow i marked what appears to be some stray solder? Inspect the board for stray solder blobs
You haven't posted the resistance measurements, you may edit the picture with the measurements written on it
If you're confortable with voltage injection, set your bench PSU to 1v (don't go higher, double check with multimeter) and solder a wire to the bottom of PL8301-PL8302, connect that to the + of the bench PSU
The GND you can connect to a screw hole
Take note of the current draw, check with the thermal camera which component gets hot, may be a cap near the BQ, PC8309 or PC8307 near the audio IC (unlikely)
Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes still have 46 ohms across PC8309. Took care of the solder gob. Could you please tel me again what resistance measurements you want?
Due to space constraints, I'm doing this smd work, not on my work bench but on a table next to my computer. My bench PSU is on my bench, I will have to make room and move my camera over there. I'll get back to you, Thanks!
So the short is on the input of the BQ charger, could be anything from a cap, to the BQ itselfYes still have 46 ohms across PC8309
Normal resistance should be several Kohms or higher (maybe unstable value as there are caps in parallel, thats ok)
OK, please post resistance measurements:
- Across CU206 (+5VALW), should be very high on Kohms - Mohms
- From PF8302 to GND (TBT_VSYS), now it should be very high in Kohms or more
Hello, I just did those test with soldering wires to the bottom of PC8301 & PC8302. was pulling between 200 & 300 at .9 volts. this cap in the picture was glowing. and looks discolored. I believe its PC5302 going by board view.
NO Glowing on the BQ chip, PC8309 or PC8307 The cap in the pic Glowing like a bitch.
CU206 to ground = .2 ohms across the cap = 14.2 ohms !
PF802 to ground = O/LComment
The software i used is FlexBV free edition by inflex aka Paul Daniels (@pldaniels on YT), he repairs mostly Apple laptops, sometimes other brands on his livestreams
https://www.badcaps.net/forum/troubl...acos-and-linux
Take care, have a good day tooOriginally posted by bogart219Brother, I got to leave the house and go and baby sit my grand kids.Thanks for all your help and knowledge. We can take this up tomorrow if you don't mind. Have a good evening
Good morning. I'm going to remove PC5302 and see what happens. The two mosfets and two inductors are still out of the board.
Just a quick recap, this lappy would not turn on or charge the battery. I replaced the power adapter and the battery., still nothing. The lappy did work with the battery hooked up but not just the adapter. The adapter would not charge the battery. I was able to charge the battery from my bench top PS.
The usb test meter showed 5 volts and no amps. Was getting 5 volts to two mosfets but the resistance readings of the those two looked screwy. Replaced the two mosfets with new ones, which I had a hard time doing. (new to this smd rework).
After replacing the fets, retested. Usb tester shows 5 volts but now at 6 to 700milliamps. removed the two fets I replaced and it still showed 6 to 7 hundred ma. Removed two inductors, the same.
Appears the TPS chips + terminals read to ground. It must be something I did when removing those fets, I'm assuming I mucked something up, or did I. I put Kaption tape all around those fets and used flux but something changed. I'm lost at this point.
I did a voltage injection of 1 volt pulling 2-300 ma. Found a cap near the BQ chip on the other side of the board glowing. (thermal camera). Will remove and see what happens.Comment
There's no way for the 5V from the charger to go to the system and draw 650mA, as the inductors and MOSFETs are removed from the board
VBUS_TBTA/VBUS_TBTB go straight from the USB-C ports to the TPS65994, and some other components, and that's the only IC with connections both to +5VALW and the USB-C ports
Suspect a dead TPS65994 as you still have a short on +5VALW of 14ohm, I told you that's not normal, that line should read from tens of Kohm upwards
Do not apply power to the board until that is fixed (5VALW showing a healthy resistance) and the TPS65994 is replaced along with the MOSFETs and inductors, I should have told you that, sorry
The shorted cap near the BQ was another issue, probably related to the original fault, as that's on the input of the BQ, in your laptop the BQ generates the main power rail, and charges the batteryLast edited by m1ch43lzm; 05-30-2025, 07:22 AM.Comment
Wow,some of what you said I don't quite understand. I bought that TPS65994 chip when I got the mosfets. Does this chip need reprogramed? If not I will hopefully replace the TPS65994 and put back the two mosfets and two inductors and then see if my short went away. I'll address those two caps after that.Thanks.
Man, my confidence is getting low using this hot air gun taking off some of these components. I'm feeling like I bit off more than i can chew. Those last two caps I removed, I used 420 degree heat at 50% and it seemed like it took for ever. I used flux and put aluminum tape (seen a guy on YT suggest using that, I have a couple rolls from my HVAC days), around them instead of Kaption tape. Maybe that aluminum is sucking all the heat?, I don't know. I will proceed with caution. Very disappointed in my smd skills
I'm not 100% sure if the TPS65994 needs to be programmed, or if it can be programmed by the motherboard when it powers on
Practice first on a dead board, this chip has a large GND pad on the underside, may require more heat, about 430-450 C I think, you don't want to rip the pads on the board
Afterwards tin the pads with 63/37 solder+flux
TI forums suggest that the chip has an internal ROM and they "spin" a new revision when the USB spec gets updated, and datasheet suggests that it communicates with the EC and the thunderbolt controller
I think it can program itself, if anybody has experience replacing TPS65994 please come in here
I have to go out, I won't be able to reply until late afternoonAttached Filesif you find these attachements useful please consider making a small donation to the site
Yeah ok friend, have a good afternoon!I'm not 100% sure if the TPS65994 needs to be programmed, or if it can be programmed by the motherboard when it powers on
I have to go out, I won't be able to reply until late afternoonComment
The firmware is stored on an external 1MB chip.
https://www.badcaps.net/forum/troubl...65994ae-eeprom
https://www.badcaps.net/forum/troubl...are-requestComment
Hello, a few questions if you please. 1) Is this external chip something I can get? 2) How do I write it to my new TPS chip? 3) This is not a bios file correct, totally different correct? 4) where do I go to get this eeprom or chip? thank you very much1
This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:00 AM
- Loading...
