Shorted diode, help to identify it
  • Ilyushin
    • Jun 2014
    • 11
    • Spain
    Hi, I have this laptop and I need help to find with what to replace it
    Packard Bell mit-drag-gt2
    Motherboard Hannstar J MV-4 94V-0 0648
    It was in short-circuit and I found that the cause was a shorted diode. I removed it and it has no resistance no matter what direction (anode to cathode or reverse)
    With that diode removed, the board has no short-circuit.
    I haven't found any schematic for this board, and in the PCB under the diode is printed its symbol, so it's not a zener (attached pic)
    The diode only has a yellow stripe on it. I found on other laptops what seems the same diode but with black stripe instead.
    Any help to identify it? Thanks
    Re: Shorted diode, help to identify it
    "It was in short-circuit and I found that the cause was a shorted diode. I removed it and it has no resistance no matter what direction (anode to cathode or reverse)" OK, it is alittle confused here, you found diode that tested shorted when is still soldered to the board, then you removed that diode and tested again and it shows NO RESISTANCE NO MATTER WHAT DIRECTION, do you mean it shows < 1 Ohm in both direction or it shows infinite resistance?
    • selldoor
      Slow Learner
      • 7870
      Well looks like it may not be shorted - when you have worked that out this may help with ID
      http://www.marsport.org.uk/smd/sod80.htm
        That is a good link, selldoor.
        • Ilyushin
          • Jun 2014
          • 11
          • Spain
          Sorry if it wasn't well explained
          The diode removed, shows 0 resistance no matter what direction. This is the same values measured when it was soldered, and what caused the short in the mainboard between the +19v input and gnd
          Looking in the link provided by selldoor seems that it should be a zener? but the symbol in the pcb where it was soldered is the symbol of a simple diode, not a zener
          Or could it be a switching one as that link says?
            So the anode is connected directly to ground and the Cathode is connected directly to the +19VDC input? Is that correct?
            • Ilyushin
              • Jun 2014
              • 11
              • Spain
              Yes, Anode goes to GND and Cathode goes to the +19v input through 2 "PL" that are inductors if i'm right.
              Attached photo, where the red wire was soldered (for finding the short) is the +19 input
              • atsio
                • Oct 2013
                • 819
                • Greece
                Usually Mitac designs (like yours) are using this http://my.mouser.com/ProductDetail/T...3NuWCW%252bQ==
                • Ilyushin
                  • Jun 2014
                  • 11
                  • Spain
                  thanks for your reply, but that link shows a Zener diode, and mine is not a Zener, based on the drawing of the pcb
                  • selldoor
                    Slow Learner
                    • 7870
                    You cant always trust the markings on the boards - may have originally been going to have an ordinary diode then decided to switch to a zener and didnt alter the silkscreening.
                    • cdicky
                      • Jul 2014
                      • 27
                      • England
                      You have to ask yourself for why would a diode be connected to ground ??
                      Any chance you can follow and trace a circuit around it. It might help identify what its purpose was and figure out what it should be, rather than guessing what it was.
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        Do not take note of the drawing on the board. All the markings usually on boards are for diodes although there is a zener on that position
                        • Ilyushin
                          • Jun 2014
                          • 11
                          • Spain
                          thanks everyone for helping. So, can we conclude it's the zener atsio posted in #8?
                          #11 I'm afraid that's far above from my understanding...
                          • selldoor
                            Slow Learner
                            • 7870
                            looks to me like it goes to r103 not to ground? there is a trace under your arrow?
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3615
                              • slovakia
                              its just diode on ground, replace with any of diode to 30v and u r good to go
                                It looks to me from the pictures, the Anode is connected to two resistors (connected in parallel) PR51, PR66, the other two ends of the resistors are connected to the B+ large pad on the left side of the PQ10 (MOSFET?).
                                I doubt that this diode is used as a crowbar protection device in case the polarity of the power supply is reverse, which in that case, the Diode will be bias on and will cause the fuse to blow, the diode will be much bigger size to handle the crowbar current.
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Me too - I put the value instead of the board designator
                                  • Ilyushin
                                    • Jun 2014
                                    • 11
                                    • Spain
                                    Hi everyone
                                    So... I found in some monitor scrap-power board a diode that looked exactly the same, and that tested good when I removed it. (flow in one direction, not in reverse)
                                    I put in the laptop board and there wasn't any short-circuit. Then I ensemble everything, connect to DC adapter and there was a slight "click" sound.
                                    No power-up at all, and now the laptop board is again in short-circuit. I have done again the "method" to locate the cause of the short (bench power supply and where it got hot), and again is the diode's fault. Diode removed and no short
                                    So, any suggestions? what can be causing the diode to die "open"?
                                      Since the Anode is not directly connected to Ground pad, with diode removed, what resistance do you get between the chassis ground and the Anode, Chassis Ground and Cathode? It seems to me that too much current was flowing through the diode and caused the damage to the Diode.
                                      • Askic
                                        TVS diode shorted on HP motherboard
                                        by Askic
                                        Hello guys,
                                        I have seen a few videos on youtube about repiring HP 15 pavilion laptops that has TVS (Transient Voltage Suppressor) diode shorted to the ground.
                                        Please have a look at the attached picture.
                                        The diode is P4SMAJ20A and according to the datasheet its breakdown voltage (at 1 mA is 22.2V or 24.6V at10 mA).
                                        THis means that if voltage goes higher that 23V this diode will start conducting and short to ground thus protecting rest of the circuits from overvoltage.
                                        What I don't understand if is this diode reversible, for example if voltage goes below 20...
                                        12-30-2020, 11:56 AM
                                      • hobostove
                                        Corsair RM1000e - Help identify 5VSB Zener diode
                                        by hobostove
                                        Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                        Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                        There's a 22ohm resistor that's melted and open, but it still has the bands.
                                        The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                        It looks like the diode connects the source and drain of a TNY284...
                                        03-27-2025, 02:25 PM
                                      • Donny2derby
                                        Help identifying shorted diode.
                                        by Donny2derby
                                        Hi there all.
                                        Troubleshooting an SMPS and I’ve found a SMD diode shorted in both directions. The trouble is it has no identification on it. So what do I replace it with and how do I tell where the anode and cathode is and how to mount the replacement?
                                        It is diode D1 on the image.
                                        Regards.
                                        Gareth....
                                        03-07-2024, 08:10 PM
                                      • jjne
                                        AUO M270QAN01 - identify diode?
                                        by jjne
                                        I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
                                        Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
                                        ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
                                        01-24-2024, 08:39 PM
                                      • jezzaaaa
                                        Identify replacement diode
                                        by jezzaaaa
                                        I'm trying to find a replacement diode for one that has gone short.
                                        I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
                                        I can't find the exact part number for sale. Similar...
                                        05-09-2023, 11:26 PM
