TVS diode shorted on HP motherboard
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    I have seen a few videos on youtube about repiring HP 15 pavilion laptops that has TVS (Transient Voltage Suppressor) diode shorted to the ground.
    Please have a look at the attached picture.
    The diode is P4SMAJ20A and according to the datasheet its breakdown voltage (at 1 mA is 22.2V or 24.6V at10 mA).
    THis means that if voltage goes higher that 23V this diode will start conducting and short to ground thus protecting rest of the circuits from overvoltage.
    What I don't understand if is this diode reversible, for example if voltage goes below 20 V, will it return to its non conducting state, or this diode is some kind of a "one-shot" device which means once voltage is over threshold, the diode is permanently shorted to the ground?
    How this protection is supposed to work. I know in case of zener diode, when voltage is above some threshold, it starts conduction and when voltage falls below certain threshold it block again.
    I have read in Wikipedia "it automatically resets when the overvoltage goes away", but if this is a common issue on some laptops, I wonder how big overvoltage was in order this diode to stay permanently shorted.
    Thank you.
  • mon2
    • Dec 2019
    • 14470
    Re: TVS diode shorted on HP motherboard
    Hi.
    If the threshold of this transient suppression diode (zener) is reached, the diode will conduct to suppress the excessive voltage. If under this threshold value, the diode is "invisible" to the circuit.
    Think of it as a relay that is open unless a dangerous peak voltage is reached, then the relay is closed to shunt the higher voltage to ground.
    https://cdn.badcaps-static.com/pdfs/...760b8110c1.pdf
    Unless the diode has had to deal with heavy current, it should be ok after such an event.
    If in doubt, remove this 2 legged part from the PCB and just be sure to use a safe voltage value for this circuit board.
    Once the diode is out of the board, you can test it using the diode mode of your multimeter.
    The diode should conduct if the RED (+) of your meter is on the ANODE (back side of the arrow head); BLACK (-) of your meter on the CATHODE (the bar / top of the arrow head).
    Respectively, the meter should NOT conduct if the meter leads are reversed from the above condition.
    • abajor
      A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
      by abajor
      Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
      PPBUS_3GH diode: measures good .45V
      PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
      The weird so far is
      PP3v3_G3H_RTC_X diode: .104V (WTF?)
      PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
      Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
      Not sure what any of this means...
      03-18-2025, 10:27 PM
    • Donny2derby
      Help identifying shorted diode.
      by Donny2derby
      Hi there all.
      Troubleshooting an SMPS and I’ve found a SMD diode shorted in both directions. The trouble is it has no identification on it. So what do I replace it with and how do I tell where the anode and cathode is and how to mount the replacement?
      It is diode D1 on the image.
      Regards.
      Gareth....
      03-07-2024, 08:10 PM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • vieuxchoub
      Psu repair: UC3845 not starting up because of NE555 defect
      by vieuxchoub
      Dear friends from Badcaps
      I have been searching for a long time to repair sucessfully a battery charger taking in 230V AC and outputting normally 14V DC. Its power mosfet has been shorted ( Infineon 06N80C3), probably because the bulk storage rectifier capacitor had swollen and had no capacitance anymore and a very high resistance.. The mosfet short has naturaly blown its 0.15 ohms resistor then its driver, the UC3845 IC which was shorted between pins 5 (ground) and 7 (vcc) plus 8 (Vref). Another small resistor surrounding was also dead. So, I have replaced the bulk storage capacitor, the...
      12-02-2023, 12:56 PM
    • netgearnetgear
      D747m_1v3 logic board for remote gate
      by netgearnetgear
      Good day,
      My remote gate stopped working. The company said the main logic board needs replacement. After examining and running a couple of tests, I discovered what looks like a shorted zener diode. Tracing the path on the board it appears to be across a voltage regulator chip (78m05). After reviewing the datasheet for the voltage regulator I thought that it was being used with a zener diode as a voltage boost regulator. However, looking at the layout of the board the "shorted diode" is not connected as in the datasheet. The diode does not have a markings so I am not sure what...
      06-22-2024, 03:28 PM
