MacBook Pro A2442, board 820-0298-A, no backlight
  • survivalbloke
    • Aug 2021
    • 309
    I'm working on a MacBook Pro A2442, board 820-0298-A. This device was liquid damaged and had no power. After I repaired the liquid damage, I find the device powers on and works with external video, but backlight is not working.
    Anyway, I really want to improve my fault tracing skills, instead of having to rely on others to always tell me where to look and what to check. In this case, I have a question about navigating schematics. If I wanted to trace the backlight power circuit, how do I find where that circuit begins? If I search for "lcd" in the schamtic, it is listed on many pages.
  • mon2
    • Dec 2019
    • 14683
    I think you mean 820-02098?
    Check the voltage of PPVOUT_LUXE to ground.
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      i will pin myself as i have same macbook with same issue. I've 0V on PPVOUT_LUXE
      • obelix24
        • Jun 2023
        • 291
        • Slovakia
        survivalbloke have you fixed this ? i'm having same issue,.
        • obelix24
          • Jun 2023
          • 291
          • Slovakia
          Ok so i found the problem 🤣 i was missing one resistor in backlight near UP800 (it was i think RP832). After adding this resistor backlight start working again.
          • mymacdz
            • Dec 2024
            • algerie
            I SUGGEST THAT YOU CHECK THE CAPACITOR
            • PITERPENY
              • Jul 2023
              • 461
              • Ukraine
              on new devices all have a problem with the display tilt sensor. check first
              • guruji
                • Oct 2012
                • 122
                • India
                hi i have the same issue with A2442, the resistor RP805 5V_s2_main the volateg was dropping and the impedance of ic was 15ohms which sure shot ic bad after replacing the 5V_s2 across the resistor RP805 was okay.The LUXE_ppvout now is 14V but still i dont see the backlight i see the apple logo for 2 sec and all blank while the laptop is still on.is 14V_okay for luxe_out.
                thanks
                • mon2
                  • Dec 2019
                  • 14683
                  LUXE_ppvout
                  • guruji
                    • Oct 2012
                    • 122
                    • India
                    Ppout_luxe for backlight I get 14.5v and still no backlight on.
                    • mon2
                      • Dec 2019
                      • 14683
                      PPVOUT_LUXE - suggest to cut & paste the exact netname from the schematic. Otherwise the label cannot be found.
                      Is this backlight rail stable?
                      Do you see the graphics on the display when the lid is opened?
                      Consider to review the lid sensor where the angle read by the sensor can consider the lid to be open or closed. This lid sensor does require calibration if the display assembly was replaced.
                      Watch this:
                      https://www.youtube.com/watch?v=M6TeqUQ26iE
                      and
                      https://boards.rossmanngroup.com/thr...-sensor.64047/
                      There are some techs on this board that own this tool and they can comment more on this topic.
                      • guruji
                        • Oct 2012
                        • 122
                        • India
                        The backlight supply remains stable and when I open the lid I hear the chime and see graphics but no backlight .the display assembly was not changed
                        • guruji
                          • Oct 2012
                          • 122
                          • India
                          ok finally i confirmed with another panel the problem is with the backlight inside the screen.
                          • lord
                            • May 2011
                            • 319
                            • Croatia
                            Also water damage induced backlight problem. I have checked with a known good board - and backlight works - so it's not the lid angle sensor or the lcd.
                            I have transfered all the components damaged from a known good board and checked all damaged traces and fixed them. Clearly am missing something. Can't find a short anywhere on the board so i'm thinking logic. Last thing i did was bought a new RAA209100B from LRF (it does not look the same as original but it is the same part number) - and still no luck. I then checked the feedback traces and current sense resistors traces which are all fine.
                            Clearly i am missing something... Any advices?
                            Did anybody order replacement RAA209100B​and replaced successfully?
                            • mon2
                              • Dec 2019
                              • 14683
                              Measure the voltage to ground of IPD_LID_OPEN_1V8 @ UR330 / RR331. The lid sensor is a combination of the LCD display and the trackpad. Only if the lid is deemed to be open will the backlight enable.
                              • guruji
                                • Oct 2012
                                • 122
                                • India
                                Hi all
                                okay this is very a complex backlight problem they have a very thin led backlight circuit booster inside . I have finally opened the screen carefully and now will change the backlight board inside. Attaching photos so most of us know how deep we are going with this .
                                cheers Click image for larger version
ID:	3646263 Click image for larger version
ID:	3646259 Click image for larger version
ID:	3646260 Click image for larger version
ID:	3646261 Click image for larger version
                                • lord
                                  • May 2011
                                  • 319
                                  • Croatia
                                  Thank you for your answer and helping out.
                                  As you requested I soldered a wire on pin 14 of the trackpad connector JT400: the voltage IPD_LID_OPEN_1V8 signal is 1.8V when the lid is open, and 0V when lid is closed. I mentioned that i tested the computer with a known working board and the backlight was working so i figured it must be a problem in the logic board, not the peripheral components. Do you agree?
                                  • lord
                                    • May 2011
                                    • 319
                                    • Croatia
                                    Could it be the CPU? Anybody have datasheet for RAA209100B​?
                                    • guruji
                                      • Oct 2012
                                      • 122
                                      • India
                                      Finally this led backlight they have made controls every cell of the led on the board like when we switch on the apple logo you have only the center led come on and the. The entire backlight lights up .also the colour of the led is blue.now the only thing is a need the right tape to seal can anyone tell me which tape and the size
                                      thanks all
                                      • guruji
                                        • Oct 2012
                                        • 122
                                        • India
                                        Also if the lid sensor is disconnected the backlight will come
                                        • rounin
                                          MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                                          by rounin
                                          Device Information
                                          • Model: MacBook Pro 14” M1 Pro (A2442)
                                          • Logic board number: 820-02443-05
                                          Original Issue
                                          The device suffered liquid damage, causing a short circuit on the logic board.
                                          Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                                          Work Performed
                                          Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                                          Current Status
                                          • When powered on, the screen shows support.apple.com/mac/restore....
                                          10-20-2025, 11:15 PM
                                        • slimmy182
                                          MacBook M1 Pro 14" 2021 A2442 (820-02098) — U2020 getting hot, board not powering on
                                          by slimmy182
                                          I have a MacBook Pro M1 14” (board 820-02098) with a broken LCD panel (matrix damaged).
                                          The board does not power on — when connected to power it draws about 5.1 V / 0.474 A (~2.45 W) and stays at that level, with no fan spin or display activity.
                                          Using a thermal camera, I noticed that U2020 heats up to over 70 °C shortly after connecting power.
                                          According to the schematic, U2020 is a SN74AVC2T45RSWR (Texas Instruments) 2-bit bidirectional level shifter.
                                          There are no visible signs of liquid damage anywhere on the board.
                                          Given the broken LCD,...
                                          08-15-2025, 02:57 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • dbuergi
                                          Macbook A2442 no display board 820-02098
                                          by dbuergi
                                          i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                                          So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                                          05-25-2025, 10:58 AM
