ThinkPad P50 no power on
  • wzamoyski
    • Mar 2022
    • 28
    • Poland
    I'm looking for pointers/ideas:
    - Lenovo Thinkpad P50.
    - motherboard: BP500, NM-A451, VER 1.0
    - schematics & Boardview: https://www.badcaps.net/forum/troubl...ic#post3242496
    - CPU: SR2FU (i7-6820HQ)
    - GPU: N16P-Q1-A2 (Quadro M1000M)
    - MEC1653-BA1
    When I switch on power supply motherboard take maximum 0.070A (without battery), LED1 is on after few second drop to 0.032A (LED1 is off). Pressing power button - case is the same.
    Voltage/resistance:
    • PL1 - 0.506V / 38kΩ
    • PL3 - 0.00V / 86.7kΩ
    • PL4 - 5.131V / 6kΩ
    • PL5 - 3.369V / 6kΩ and higher
    • PL6 - 0.00V / 2.3 Ω
    • PL7 - 0.00V / 2.3 Ω
    • PL8 - 0,00V / 2.3 Ω
    • PL9 - 0.00V / 4.0 Ω
    • PL10 - 0.00V / 4.0 Ω
    • PL11 - 0.00V / 12Ω
    • PL14 - 0.00V / 64kΩ
    • PL16 - 0.00V / 29.4Ω
    • PL17 - 1.020V / 70Ω
    • PL19 - 0.00V / 7.07 kΩ
    • PL103 - 0.00V / 9.0 Ω
    • PL107 - 0.00V / 8,5 Ω
    • PL108 - 0.00V / 171 Ω
    • PL109 - 0.00V / 388 Ω
    • L6 - 0.005V / 0.685kΩ
    • 8 l.on SPI - 2.578MΩ
    I didn't find any corrosion's, mechanical damages, etc. I tried new BIOS, but not working. I think VCCCPUCORE, VCCGFXCORE_I and VCCSA​ (according to schematic).
    Thank you for any advice.
  • mon2
    • 14659
    Review the charger IC @ PU1.
    Measure the voltage to ground for the following pins of interest:
    VCC ; pin 28
    ACDET ; pin 6
    ACOK ; pin 5
    ACP ; pin 2
    ACN ; pin 1
    REGN ; pin 24
    • nivminkov
      • Dec 2020
      • 15
      • Israel
      Probably not the issue but what about the main power rail? Does is shows in every input for the regulators? (on the input capacitors)
      • wzamoyski
        • Mar 2022
        • 28
        • Poland
        Measurement (power supply/ original adapter):
        • VCC ; pin 28 - 19,80V / 19.93V
        • ACDET ; pin 6 - 2.67V / 2.69V
        • ACOK ; pin 5 - 3.272V / 3.272V
        • ACP ; pin 2 - 20.39V / 20.52V
        • ACN ; pin 1 - 20.39V / 20.52V
        • REGN ; pin 24 - 6.002V / 6.002V
        When I try measure voltage on pin 6 (ACDET) current strength dropped to 0.009A.​
        Main power rail is good. After PR2 I have 20.39V.
        • nivminkov
          • Dec 2020
          • 15
          • Israel
          I think you should verify that there is input voltage for every buck input. Most likely it will 😭
          I also think your EC chip is gone. This is also the problem in a laptop I'm trying to repair. Main voltage present and also 3.3V and 5V. No shorts anywhere. I saw sorin from YouTube trying to fix a problem like this and he couldn't do it. He Replaced the EC chip and reprogrammiled it but still no luck. I hope you'll fix yours. Maybe flashing the bios memory chip with external programmer may help, but I'm not sure.
          Try to look for your EC chip in Google and check if someone really succeed to replaced it.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            What about PL13? Does it have 1.2V?
            • wzamoyski
              • Mar 2022
              • 28
              • Poland
              Resistance: PL13 - 92Ω, no voltage.
              I flashed BIOS memory without any effects. Hmm... I think my job is done here - I don't have programmer to EC.
              • mon2
                • 14659
                There are vendors who sell the EC pre-flashed for this target laptop brand. Check eBay and AliExpress.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  You've not even reached S4 stage as ram coil voltage is missing. So the failure is in initial stage only. PM_SLP_SX rails status?
                  • wzamoyski
                    • Mar 2022
                    • 28
                    • Poland
                    I can't find PM_SLP_SX. But if You need:
                    TP987 - 3.369V
                    TP988 - 3.369V
                    TP989 - 3.359V
                    TP990 - 3.369V
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      I mean PM_SLP_S5/S4 etc.
                      • wzamoyski
                        • Mar 2022
                        • 28
                        • Poland
                        According to schematic available are -PCH_SLP_S0, -PCH_SLP_S3, -PCH_SLP_S5 etc.
                        Laptop return to owner.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • Paffo
                          Thinkpad Tablet 2 (2679) No Power
                          by Paffo
                          I recently got my hands on a batch of Thinkpad Tablet 2 that a local business was throwing away. They all have the same issue, no Power.
                          I do have a working one that i also took and the first thing i did was trying to power it without the battery being inserted.
                          It seems that these tablets do not work unless the battery is in (my PSU is 5V5A so i doubt it's a current thing, probably design).
                          I thought i'd be lucky so i took the battery from the working one and i tried it in 2-3 of the broken ones, but no luck, still no power.
                          The current draw is 18mA...
                          07-05-2024, 03:30 PM
                        • Mita99
                          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                          by Mita99
                          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                          04-27-2025, 07:20 PM
