A665 3DV6 (la-6062p)
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    hello
    the customer brought this lap with charge ok but cannot switch it on.
    i found the switch connector on board not good , so i tried with the 2 pins of switch, the laptop goes ok , i decided to change this connector, after that the laptop powers on for 2-3 sec with no screen and shuts off. i found U11 hot and found the pins 1-2-3 of the bios 1.1v
  • dj_ricoh
    • 2073
    Re: A665 3DV6 (la-6062p)
    do you know how to power without the power button?
    the media button(touch)
    • mazloum
      • Sep 2012
      • 499
      • Lebanon
      onow it is powering on but only for 2-3 seconds
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        what do you get before and after you press the power button:
        1. at pin 8 and 17 of PU6?
        2. at pins 3,7,8 of U22?
        3. PL4, PL5?
        4. ON/OFFBTN#?
        • mazloum
          • Sep 2012
          • 499
          • Lebanon
          pu6: at pin 8= 3.3v before and after the same at pin 17= 5. v before and after
          u22 bios: pin3=1.11 pin7=0.27v and pin 8=1.1v also the same before and after.
          pl4=3.34 and pl5=5.1 v also the same before and after pressing power
          the only thing that i get when i press the power button is a lighting led for 2or 3 seconds then goes off again, no fans no display at all
          • corrize
            Where to find a very small fpc connector 0.3mm between 2 pins ?
            by corrize
            Hello, I search this connector (oxydated).
            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
            Do you know how to find this connector please ? What is the exact name for find it ?
            08-06-2024, 05:25 PM
          • CG2
            Meaco Arete One / Deye Dehumidifier not working
            by CG2
            I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
            Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
            08-17-2024, 07:47 AM
          • trepachka
            Nintendo Switch HAC-001 LCD connector
            by trepachka
            If I removed the LCD connector while the battery is still plugged in, did this damage the logic board like it would a laptop? This is my first time working on one and not only did I forget to unplug the battery when removing the logic board but after I replaced the USB-C port, I broke the clip that keeps the LCD connector snug to the logic board.
            I can replace the LCD connector if I knew the logic board was ok. I secured the LCD connector with a piece of Kapton tape. The console is charging but when power button is pressed, I only get backlight. So, I don't know where the logic...
            10-15-2023, 12:14 AM
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
