Nintendo Switch HAC-001 LCD connector
  • trepachka
    • Oct 2022
    • 461
    If I removed the LCD connector while the battery is still plugged in, did this damage the logic board like it would a laptop? This is my first time working on one and not only did I forget to unplug the battery when removing the logic board but after I replaced the USB-C port, I broke the clip that keeps the LCD connector snug to the logic board.
    I can replace the LCD connector if I knew the logic board was ok. I secured the LCD connector with a piece of Kapton tape. The console is charging but when power button is pressed, I only get backlight. So, I don't know where the logic board is toast or simply the piece of Kaptop tape is not doing its job and replacing the LCD connector should do it? Thanks.
  • chickenhawk88
    • May 2024
    • 86
    • US
    Here are values for a good working board in this guide. You have hot air machine to do the job? you will need to heat up the board from the opposite side so you don't damage the LCD connector.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • joliver82
      Sony XR-65A95L no power due to logic board issue
      by joliver82
      Hi guys!
      I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
      First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
      When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
      11-26-2025, 04:57 PM
    • ohren
      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
      by ohren
      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
      The models launched in 2018 and 2019 respectively....
      09-08-2023, 05:24 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
