Hp G6 intel R 13 dead no power issue
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Hi I have a Hp g6 intel board Da0r13mb6e0 rev e board thats dead . Im getting 3.3vs5 and 5vs5 voltages, the KBC pin 95 (rsmrst) is going from 0v to 3.3v also pin 101 s5_on is going from 0v to 3.3v.Pin 112 (sus_pwr_ack) goes from 0v to 3.3v.
    There are no leds and the board seems dead as in no fan or leds lighting.Any pointers would be great. I have attached the schematic i am also using a bench supply as the dc jackl lead seems to be damaged too.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Hp G6 intel R 13 dead no power issue
    If you say you have 3.3v and 5v and voltage on the power button, try flashing the BIOS.
    A working TV? How boring!
    • Bisketti
      • Oct 2013
      • 252
      • Ireland
      Yeah I will try that but would I get signal from the Kbc if the bios was corrupt?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        If it's got a separate EC BIOS, then yes.
        • Bisketti
          • Oct 2013
          • 252
          • Ireland
          Thanks for the info, I downloaded and extracted the bios and there are 4 different bin file in it Im also having trouble locating the bios chip. I found it I think its u22
          • Bisketti
            • Oct 2013
            • 252
            • Ireland
            It seems the bios pins 3 and pin 8 do not have 3v pin 8 has .57v. pq19 gate is not being switched by PU2. I accidentally shorted pin 12 and 13 together this switched on the laptop the backlight was not on but I could make out no operating system on the screen.
            • Bisketti
              • Oct 2013
              • 252
              • Ireland
              Pq19 supplys the +3v by the looks of it and Pu2 switches the gate on but its not doing that, what I also found was when I shorted pins 12 and 13 and the laptop booted up the PCH gets hot. Im not sure how hot these chips normally get.I presume on4 pin12 pu2 is what switches pq19 gate on. Is there still any point in flashing the bios??? Any input is appreciated
              • alihomee
                • Dec 2012
                • 1594
                • malaysia
                it you got the post on screen with no back light then no need to flash bios only locate the cause of no back light
                • Bisketti
                  • Oct 2013
                  • 252
                  • Ireland
                  The situation is still the same Im not getting the mainon signal into pu2 which I presume switches on the gate to pq19 this only worked as I shorted the pins but after powering down the set is dead again until pq19 is switched on by pu2. What causes the kbc to release this voltage? (mainon).The backlight is a different issue if I can get the unit to power on as it should then I will try fix Back light issue.
                  • tomodachi
                    • Apr 2012
                    • 610
                    • Turkey
                    Same motherboard here on my bench at the moment. First 3.3V rail was completely shorted because of corrupt HM65 chip. I replaced that chip and now I can't get 3.3 or any other voltage anywhere on board. God damn Quanta motherboards are full of surprises and nearly impossible to repair.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      Great can you get a part number for the op its on the screen panel board
                      Hi this is a 15.6" LED laptop screen LP156WH$ (TL) (CL1).
                      Pno: 6870s-1128a
                      lp156wh4-tla1
                      Ic: US2.
                      • whaldsz
                        • Apr 2013
                        • 395
                        • Philippines
                        What do you get at pin 4 of PU2 before or after you pressed power button?
                        Could be PU2 or SIO chip may need replacement.
                        • Bisketti
                          • Oct 2013
                          • 252
                          • Ireland
                          Pu2 pin2 and pin 4 0V before and after, I think these should both be 0v before and then go high after pressing power button. This mainon signal is not being sent by Sio Im curious of what needs to happen to release mainon from Sio?.
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            RSMRST#, check it for 3.3v after power button is pressed.
                            • Bisketti
                              • Oct 2013
                              • 252
                              • Ireland
                              Yes check my original post. Its going from 0v to 3.3v
                              • khaahk
                                • Dec 2013
                                • 812
                                • Estonia
                                Resistance from PU2 pin2 to ground? Maybe sio output or PU2 input shorted to ground?
                                • alifoural
                                  • Jun 2012
                                  • 5
                                  • Egypt
                                  can i ask what is the job of pu2 on the motherboard , its seems its make alot of problems
                                  i have laptop repair shop ,,, i got more than 7 laptop hp g6 has the same problem when i change this ic its work ok
                                  when i plug the charge , its light ok , and 5v ,3v ok , but when i press power its gone ,,, the maual says its for dis-charge ic , what that mean ?
                                  • Laptop_repair_hut
                                    • Dec 2014
                                    • 5
                                    Did anyone ever get a result with this ? ive currently got 2 boards with this issue and the problem seems to come from pu2, what is this component and does anyone know where i can get one
                                    Stephen
                                    • nazrul145
                                      • Jan 2014
                                      • 337
                                      • BD
                                      You can reflow PCH.
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • KYBOSH
                                        Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                                        by KYBOSH
                                        I have a floodlight-security camera that recently died on me.
                                        its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                                        Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                                        07-01-2024, 06:54 AM
                                      • justice171
                                        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                        by justice171
                                        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                        1. Verified that all critical voltages are present:
                                          • 3.3V and 5V are always present if DC is plugged.
                                          • 1.8V on the BIOS chip is present.
                                        2. Checked the power button functionality:
                                          • When pressed, the voltage drops to 0V, indicating the button is functional.
                                        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                          • Confirmed connectivity is intact, ruling out issues
                                        11-26-2024, 12:39 AM
                                      • corrize
                                        Nikon D5 – dead, power board issue ?
                                        by corrize
                                        Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                        When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                        I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                        Now, I try to understand how it works.
                                        There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                        04-03-2023, 09:13 AM
                                      • claws77
                                        lenovo flex 5 14itl05 power sequence issue
                                        by claws77
                                        hi guys, my motherboard will not start no matter what
                                        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                        but rest nothing happens no sign of life.
                                        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                        i have no knowledge of motherboards ....
                                        10-20-2024, 02:48 PM
