HP DV4 no power, burnt component maybe get lucky
  • high-tech
    • Sep 2010
    • 197
    I would like to find out what part number this is and replace it! I'm almost sure its a set of fets in that little 8 pin package...
    Anybody out there got one of these boards in the scrap pile and could verify part numbers maybe?
  • dj_ricoh
    • 2073
    Re: HP DV4 no power, burnt component maybe get lucky
    and the mobo code?
    how can you read a schematic if you don`t know the motherboard code ?
    and when its PQ usually (for me was always a 30v N-channel mosfet)
    • selldoor
      Slow Learner
      • 7870
      These tend to come in pairs so possibly the same as the one below in your picture
      • khaahk
        • Dec 2013
        • 763
        • Estonia
        If the mainboard is LA-4101P then it is P-channel mosfet.
        http://html.alldatasheet.net/html-pd.../AM4835EP.html
        • high-tech
          • Sep 2010
          • 197
          Originally posted by dj_ricoh
          and the mobo code?
          How can you read a schematic if you don`t know the motherboard code ?
          and when its pq usually (for me was always a 30v n-channel mosfet)
          la-4111p
          • dj_ricoh
            • 2073
            that code its for HP compaq CQ40 :|
            • dj_ricoh
              • 2073
              AM4835EP Analog Power P-Channel 30-V (D-S) MOSFET
              • chad720
                • Jan 2011
                • 16
                Hi, did you managed to fix that laptop? If no, could you please check if it powers up with the bios recovery routine? (no USB present just to prevent unwanted updates).
                The routine is 1) unplug the power cord and battery 2) hold down WIN + B keys 3) plug in ac adapter 4) hit power button
                If it powers up please commento so I can trace my issue that is no power at all unless I make this procedure but didn´t seems to work to restore bios nor charging the battery.
                Thanks and good luck
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3586
                  • slovakia
                  its main power switch mosfets.
                  • chad720
                    • Jan 2011
                    • 16
                    Hi Ktmmotocross, thanks for answering. Are you possitive on that? because I was almost discarding a power switch faillure since the system power up (aparently as it should) whenever I made the INSIDE bios recovery routine. No power at all in other cases, and no battery charge in both cases.
                    Thanks and sory for being repetitive!
                    Chad
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3586
                      • slovakia
                      on the other side o board is power conector, so yes im sure its main power mosfets
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        09-06-2024, 05:59 AM
