Source for missing laptop feet... ideas?
  • y_not
    Same 'ol Song
    • Aug 2009
    • 147
    I have been wondering this for ages, what is a good 3rd party product/raw material, that can be used to replace those pesky rubber feet, that invariably become dislodged from their glued moorings on laptops?
    Sure, you can buy them on eBay, if you want to pay upwards of, or over: $5/pad, averaging about $15-20 or more for all of them. YIKES!!!!
    What do you do for replacements, any ideas?
    Is there maybe a place you have found a suitably thick and malleable raw sheet of natural rubber that you buy, where you can cut your own from it??
    As for glue, I used to wonder on this too, as std. rubber cement doesn't work so well. But then I found 3M's spray adhesive products... AMAZING!!!! So I think this should be good. Thoughts?
    Thanks!!!!
    How to properly apply thermal grease - Y_not's way.
  • dj_ricoh
    • 2073
    Re: Source for missing laptop feet... ideas?
    If the pipeline doesn't have cover on memory, like chip set and memory with pads, I use cooper pads.
    The ideea of cooper pads for me its that it makes a good transfer because its cooper and in the same time it make a pressure on the chip so it won't lift and make a bad joint.
    My opinion.
    • domas
      News Hater
      • May 2013
      • 323
      • Denmark
      i am afraid you two are talking about different kind of pads there.
      • dj_ricoh
        • 2073
        uff it was before coffe
        • dj_ricoh
          • 2073
          aaa now i get it
          rubber feet? who has them?
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            i'm not so sure but, furniture accesories stores may have them.
            • tomodachi
              • Apr 2012
              • 602
              • Turkey
              I never bothered missing rubber feets but I guess coin size gaskets will do the trick, if owner do not have aesthetic concerns
              • domas
                News Hater
                • May 2013
                • 323
                • Denmark
                i used some feet from furniture stores like spidey suggested, but the originals were rubber ones, while those are some cheap plastic-foam like.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  You can get a rubber sheet and cut out the shape of the pad, and then glue it on :P
                  Muh-soggy-knee
                  • scobie_21
                    • Jul 2011
                    • 144
                    Try here I have bought a few thing off him before
                    http://www.vath.co/
                    • fddizon
                      • Sep 2011
                      • 555
                      • Philippines
                      Sometimes only one rubber is missing. What i do is cut half the remaining rubber and use silicon sealant to glue and fill the empty space on the slot. You need to shape it though. Silicon sealant can survive from excessive heat.
                      • y_not
                        Same 'ol Song
                        • Aug 2009
                        • 147
                        My opinion.
                        TOOO FUUUNNNYYY!!!
                        That's what I was thinking, but where to get a rubber sheet locally? It seems whenever I go looking for such basic materials... no one has it, forcing me to order it on the interwebs and spend hours looking for it.
                        I really do try to buy local, when I can find it, or don't get ripped off when I do find it.
                        Thought about Amazon... talk about a dizzying number of options.
                        http://www.vath.co/
                        Cool website!! Thanks!!
                        Only problem is, they're overseas and I'm in the USA.
                        Anyone know where to find these state side, Amazon seller??
                        Do you have any photos of what you're talking about? I'm just having trouble fully envisioning this, but I have a bit of an idea.
                        What sort of silicon sealant, many many sub types and brands, do you use that works well for this?
                        • Pastboy
                          • Feb 2008
                          I wonder if you could a hot glue gun and shape the result?
                          The plastic from the hot glue is quite soft....
                          • domas
                            News Hater
                            • May 2013
                            • 323
                            • Denmark
                            Pastboy, I actually had the same idea. The material would very rubber-like. Don't have glue gun though and and it would not be easy to shape a nice pad with my clumsy fingers.
                              master hoarder
                              • May 2008
                              • 12170
                              • Bulgaria
                              It would work for a little bit, but eventually it would fall off - all depends on how much use the laptop sees and how it's treated. Also depends on the plastic of the laptop too. Hot glue doesn't adhere that well to the older "rough-looking" ABS plastic. Haven't tried it on the newer smoother ones. Works great on acrylic/plexiglass, though.
                              I've used hot glue in a tremendous number of repairs (I know, that sounds horrible, doesn't it?). While hot glue is soft, it doesn't like being flexed too much. And if the bottom of the laptop runs warm, that wouldn't work so well with the hot glue either as hot glue hates warm/cold thermal cycles.
                              One thing you can try for rubber feet is shower pan liner. It's PVC, but it's very soft and almost like rubber.
                              Bike inner tube is another option.
                              • DynaxSC
                                MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                                by DynaxSC
                                Hi Folks
                                I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                                Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                                09-29-2024, 04:27 PM
                              • Lvsitano
                                Asus X532FL 3.2V at source and gate
                                by Lvsitano
                                I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                First...
                                06-26-2024, 02:13 PM
                              • ugamazing
                                820-02020 PPBUS_AON missing
                                by ugamazing
                                Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                02-05-2025, 04:21 PM
                              • jpreza
                                Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                by jpreza
                                I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                Looking at the card, it appears to be missing the following:
                                1x 1.0uH inductor - orange square
                                2x...
                                11-01-2024, 10:54 PM
                              • gurj1979
                                Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                by gurj1979
                                Hey guys.
                                Need help with this one.
                                Fan not spinning due to missing PWN Fan signal.
                                Also 5 seconds from powering up it freezes, unless in BIOS.
                                But as soon as Windows starts to load, it will freeze.
                                CPU is COLD / Room temp when it freezes.
                                I've replaced the CPU, same problem.
                                Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                Replaced fan - same problem.
                                Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                08-19-2024, 05:22 PM
