Asus X532FL 3.2V at source and gate
  • Lvsitano
    • Aug 2019
    • 8
    • Portugal
    I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
    First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
    I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
    First question: why am I getting 3.2V at the drain, with only 3.2v at the gate?
    And then, if I understand correctly the board view, the gate voltage is generated by the BQ24780S IC ? (Board shows SN2867 IC, but they used a BQ24780S)
  • reformatt
    • Feb 2020
    • 1706
    The BQ IC's have short circuit detection so will disable the first MOSFET in that event. 2nd MOSFET being shorted can cause this as well, but most common issue on Asus laptops that I see is a shorted cap on the main power rail. So check at the current sense resistor after the 2nd MOSFET for a short to ground.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Besides @ reformatt's suggestion, do check voltage on REGN and VCC of BQ24780S
      • Lvsitano
        • Aug 2019
        • 8
        • Portugal
        There is no short at the main power rail, I have checked that in the first place. I am going to check the 2nd MOSFET as well, did not check that one.
        • Lvsitano
          • Aug 2019
          • 8
          • Portugal
          The 2nd MOSFET QM0930M3 was shorted, replaced with another one. Now I am getting 19V at the 1st MOSFET's source, but the 2nd MOSFET is now fluctuating voltage at drain, between 3.2V and 4.4V
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • tofik
            MOSFET equivalent K8A60DA
            by tofik
            Hello guys,
            I have a shorted MOSFET K8A60DA with the following characteristics:
            Type Designator: TK8A60DA
            Marking Code: K8A60DA
            Type of Transistor: MOSFET
            Type of Control Channel: N -Channel
            Maximum Power Dissipation (Pd): 45 W
            Maximum Drain-Source Voltage |Vds|: 600 V
            Maximum Gate-Source Voltage |Vgs|: 30 V
            Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
            Maximum Drain Current |Id|: 7.5 A
            Maximum Junction Temperature (Tj): 150 °C
            Total Gate Charge (Qg): 20 nC
            Rise Time (tr): 25 nS
            Drain-Source
            07-19-2023, 05:18 AM
          • reset1986
            Asus X580GD won't turn on, BQ24780S won't open MOSFET
            by reset1986
            Yesterday, 06:19 PM
            Hi everyone, I have this problem that I can't figure out. The Asus X580GD motherboard, with the charger connected, gets 19V to the first MOSFET, but it doesn't go beyond that. Analyzing the schematic, it's powered by the BQ24780S power IC. There are no shorts, the input MOSFETs are working. I even tested them after desoldering and replacing them. I've performed various measurements on the power IC, but ACDRV doesn't go to 25V.
            Pin 5 ACOK 6V
            Pin 6 ACDET 2.59V
            Pin 28 18.8V
            ACDRV resistor 4K I removed the R8934 resistor to see if it would return...
            03-19-2026, 01:45 AM
          • Scotchmist
            Asus GA502D keeps blowing mosfet
            by Scotchmist
            I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
            I have removed the mosfet and can run the laptop no problem
            The MOSFET is FDPC5018SG
            Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
            08-24-2024, 02:23 PM
          • AppleLover123
            Asus X712EA 3 volts after the first mosfet
            by AppleLover123
            Hey guys,
            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
            Now i thought something...
            12-15-2024, 07:49 AM
