Soldering tabs onto CR2032
  • JJR
    • Mar 2013
    • 171
    Hi all, I'm pretty new to soldering but have had no problems so far, everything I've tried has worked a treat.
    BUT this morning I have to fit a new CR2032 cell to an old laptop, the old dead cell has wires attached so I take them off and solder them onto the new cell. the tabs on the wire take the solder well but not the cell. Any clues Guys?
    Dave
  • JJR
    • Mar 2013
    • 171
    Re: Soldering tabs onto CR2032
    OK, just learned a lesson that will stay with me for a while, DON'T put a soldering iron onto a lithium battery cell 'cos they EXPLODE in your face and burn your eyelid 0.001mm from your eyeball. YIKES!!
    Dave
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Not what you want to hear but you can buy tabbed CR2032s.
      Try roughening the surface with emery paper might help
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        In view of post 2
        • JJR
          • Mar 2013
          • 171
          Yeah, I've used tabbed CR2032's many times, just had none in stock, so to get this old guys laptop back to him quickly....
          • JJR
            • Mar 2013
            • 171
            Now where are those old safety goggles?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i have done it but the surface must be perfectly clean and ready for solder.and you gotta be fast!
              i noticed some 2032's are aluminum?
              good luck soldering to those.
              • JJR
                • Mar 2013
                • 171
                I had cleaned it with isopropyl alcohol first then dabbed a little flux but it wouldn't take, so I thought MORE HEAT!
                Maybe, as Selldoor suggested, a light sanding would have helped provide a key, but too late now. Tabbed cr2032s on order.
                • digge
                  • Apr 2006
                  • 296
                  Ive done some quickfixes using electrical tape and just wrapping it hard with a wire on each side. Put something small and non conductive on each side to get it to hold the wires in place easier. If you have heat shrink tube that would work even better. This is not the best option ofc but if you dont have supplies you take what you have at hand
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I always wear them when soldering.
                    --- begin sig file ---
                    --- end sig file ---
                    • smason
                      • 1652
                      I didn't have a tabbed 2032 available for a 2M transciever I was working on, so I stole a battery holder from a dead motherboard.
                      Problem solved for now, and in the future.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        I have done the same and just used it 15 minutes ago. I also desoldered a 100 ohm resistor to fix a cheap 830 style multimeter.
                        • smason
                          • 1652
                          P.S. it's a Kenwood TR-7950. Built like a tank, it'll probably out-live me.
                          • tmhobadcap
                            Lithium ion cell voltage not going up after 3.8V
                            by tmhobadcap
                            I got a chromebook with battery problem. It was charging when plugged in. But the indicator just showed that the battery was below 10% no matter how long it was plugged in. I took the battery pack out. There are two cells in series. Each cell had a voltage of about 3.7V. I charged one of them with a lithium cell charger. I can see current going into the cell at about 500mA. After several hours, the voltage was just about 3.8V. I charged it again manually by connecting 4.2V to it from a power supply and set the maximum current to 500mA. I can see about 100mA going into the cell. But the voltage...
                            02-03-2025, 01:30 PM
                          • Azurain
                            Elitebook 840 G5 Bios Chip Soldering Question
                            by Azurain
                            I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                            Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                            04-14-2023, 06:58 PM
                          • rblack711
                            Vizio D55un-E1 COF Lifting Tabs - Not!
                            by rblack711
                            Relatively new to TV repair - as you will see. Rescued this TV from the curb. No backlights, but I could see an image on LCD with flashlight, so suspected bad LED strips. When I got to the part of lifting the LCD off the frame, it was stuck a little bit from some tape used to hold down a thin layer of foam around the frame. I saw 8 tabs on each side of the LCD that I haven't seen on any of the 3 TVs that I have taken apart before. I immediately thought, wow the engineers that designed this were thinking about the serviceman when they put these lift tabs on here - good for them. So I started yanking...
                            08-24-2022, 12:52 PM
                          • Peter_1402
                            Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                            by Peter_1402
                            Hi Everyone,
                            I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                            1. Soldering iron works great
                            2. There is a burnt mark on the hot air gun handle.
                            I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                            Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                            Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                            Reed switch tested ok with a magnet.
                            From the above test, I can conclude...
                            07-12-2025, 11:50 AM
                          • chth96
                            What soldering station should I purchase for 900M-TJ-I tip?
                            by chth96
                            hello.
                            A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                            https://ko.aliexpress.com/item/4001275635593.html
                            Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                            Any reply would be appreciated.
                            11-24-2023, 05:08 PM
