HP Envy 15 cannot charge battery!
 Re: HP Envy 15 cannot charge battery!
 Check connector pins which contact to battery.
 Check voltages on all PINS and use metal part as ground.
 PIN1 is directly connected to battery so if it touch battery + there is 12V.
 Remove PQ3 and measure again.Comment
 Yea, the pin are in contact, i even bent them slightly so they definitely were, but like I said there is 0V.. tried lots of metal parts for ground, USB casing etc..
 Like I said, the voltage is 0V, every 15 seconds there is 1.5V spike, no voltage on any pinsComment
 Anyway, I tried to switch PU11 again just in case and I have removed pin 13 pad.. oops! I think it is time I gave up now..Comment
 Stange, try measure groud to all pins. There is short but where.
 Can you measure battery directly pin 1 and pin 5 ?
 And one more time put battery other motherboard.
 After that have to remove possible trouble parts.
 PR88, PR89, PR90, PR91, PQ3
 Verify resistances PQ3 etc. with other motherboard.
 Touch if any chip getting hot or warming up.Last edited by Tuomo; 02-12-2013, 01:40 PM.Comment
 Like I said I have just destroyed a pad on PU11 now, I can never fix this.. I think its time to accept it is not going to to work againStange, try measure groud to all pins. There is short but where.
 Touch if any chip getting hot or warming up.  Comment
 Thank you for all your help with this, I really appreciate it and I think you were close to a solution before I short circuited it and then pulled a pad off
 I don't think there is any reviving it now so I a putting an end to it.
 Thanks again..Comment
 okComment
 Hello again,
 sorry to bring this topic back, but I bought another new motherboard for the laptop, and unbelievable I have some similar problems BUT not the same..
 I believe this time the motherboard is not at fault.
 So what happens now is this;
 Laptop works fine just on charger
 laptop will charge battery when turned off, or in BIOS or just before windows loads.
 THE PROBLEM: Just instantly before the welcome screen of Windows shows, the laptop powers off without warning when either ONLY the battery or battery and charger are connected.
 I can charge the battery no problem in bios, and the laptop will not turn off. I am currently running HP System Extensive Test which is an available option during BIOS. The charger is plugged in with battery, and happily charging the battery at the same time.
 I have had a similar problem a long time ago with a very old laptop of mine, I think it was a HP I am not sure. The laptop would not charge the battery and just turn off instantly when the charger and battery were in together just before windows loaded. I believe it was a common problem with dual core processors, and running the laptop in safe mode or disabling 1 core would fix the problem.
 I have not tried either running in safe mode or disabling any cores as of yet, as the laptop is busy doing its testing, but I will try as soon as it has finished.
 has anyone got any ideas please??
 Thanks!Comment
 Okay just managed to have a little play,
 Windows booted fine in safe mode with charger and battery, I went into device manager and disabled 7 cores and left 1 running. I restarted the laptop and windows booted fine, and amazing for the first time in months I saw "86% plugged in, charging"!
 So I went into device manager and enabled the cores 1 by 1, as I got to the 8th core as soon as I clicked enable I got a blue screen saying "driver IRQL not less or equal"
 I removed the battery and tried again and got the same error. So now I went back into safe mode and enabled all the cores and restarted, now the laptop just turns off when trying to load windows regardless of the battery being in or not!Comment
 So far I have tried to remove graphics drivers as I read this on another website.. All this does it instead of showing "driver irql not less or equal" error, it just turns off instantly when 8th core is enabled.
 I updated the bios and reinstalled chipset drivers - still same problem.
 Currently I am running the laptop fine on 7 cores, but obviously there is a problem I would like to fix.
 ThanksComment
 Hi, very good information in this thread. Before starting a new one, I'd like to ask what do you think about this. I own an Envy 15 1100cto refurb which stopped charging after ~1 year of use. It originally came with a 65w ac adapter, but after reading the users guide, i learned that the i7 ver needs a 120w ac adapter, so i bought a LiteOn generic adapter which worked perfectly out of the box. A year later, my battery was about to end so I went and plugged the laptop, but it didn't start charging (no amber nor white light, just nothing). Took the laptop and the adapter to some pc service and they said the adapter's low voltage wire was cut and fixed it. The lappy went back to life for a week or so. Again, the same problem. No light. Took the adapter back and the guy said the adapter was fine, and that they couldnt check anything else. Bought a new OEM adapter which worked like 4 o 5 minutes and then the same. So I disassembled the envy and found that the smart pin voltage drops to 0 when I plug it. Is this normal? What else can I check?
 Any clues?
 Thanks in advanceComment
 Why dont you try using this modded bios that deactivates the Hyperthreading feature (when enabled, this gets the CPU warmer and kills battery faster). You won't notice any performance impact, and your Envy will run cooler.So far I have tried to remove graphics drivers as I read this on another website.. All this does it instead of showing "driver irql not less or equal" error, it just turns off instantly when 8th core is enabled.
 http://dl.dropbox.com/u/45117524/bio...ByCamiloml.exe
 Reset to defaults before and after flashing.Comment
			I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
			by razenxdHello,
 it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
 At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
 Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
 Now, I have noticed a few things.
 The "dead" battery, while connected to charger and NOT Charging will...-
			by ruleteroHi
 Acer A515-43
 LA-H801P
 Fail: Does not charge battery, has low voltaje on connector.
 Laptop didn't want to turn on, only charge led blinked.
 I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
 I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
 Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
			by KlevjetackIs there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...-
			by dclass-proHi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
 I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
 I noticed 2 things:
 1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
 2) if I try to turn it on without the battery...
- Loading...
