HP Envy 15 cannot charge battery!
Re: HP Envy 15 cannot charge battery!
Okay pin 4 is as follows:
ac ON bat OFF : 19.23V
ac ON bat ON : 2V
ac OFF bat ON : 19.23V
are you sure that both PQ10 and PQ3 are the same? I recall swapping them once and it didn't work at all.. they may be swapped at the moment.
thanksComment
thanks to the measurement results. Those are very important.
I think you mixed ac ON bat ON : 2V and ac OFF bat ON : 19.23V ?
PQ10 and PQ3 appear to be identical FDS6679AZ by schematic.
Now we know for sure that the PQ10 control does not work.
We can begin to explore the control signals of PQ10.
Let's start with PQ49 PIN2 BATDIS_G should always be high when the AC adapter is in place.
Can you do same test as earlier?Last edited by Tuomo; 02-06-2013, 12:42 PM.Comment
If the case bottom readings are crossed as I presume those results are fully as they should.
PQ44 PIN2, PQ42 PIN2 and PQ45 PIN2 should be 0V when AC plug is ON.Comment
The voltage should be 19V when the AC adapter is in place.
Your measure AC ON BAT ON = 2V ?
I think they are
AC OFF BAT ON = 2V.
AC ON BAT ON = 19V.
AC ON BAT OFF = 19V.
If board charge they have to be like this.Comment
hmm, well like I said I was able to charge the battery fine using that motherboard. But I do not know what the state of the motherboard is now after playing around with it so much, and I am not sure if U33 was getting really hot before as well.
I dare not plug that motherboard in for more than a few seconds since U33 gets really hot, what do you think, should I see if it will charge the battery still? I don't want U33 to blow up on me though!
I checked the pins anyway when the battery is in and supposidely charging. pin 1 of the battery connector is 12.5V.Comment
Ok. Can you recheck PQ10 PIN4 and remove AC plug? Charging board.hmm, well like I said I was able to charge the battery fine using that motherboard. But I do not know what the state of the motherboard is now after playing around with it so much, and I am not sure if U33 was getting really hot before as well.
"are you sure that both PQ10 and PQ3 are the same? "
This have to check again to be sure.
Remove PQ10 and test pad PIN4. This for not charging board.Comment
Sorry, you are completely correct, the values on pin 4 are;
AC OFF BAT ON = 2V.
AC ON BAT ON = 19V.
I will remove PQ10 from good board later today (4 hours)
thanksComment
This looks much better, now we know what it should be.
When you remove the PQ10 and check PQ10 PIN4 pad.
If the voltage has the same function as before we can be sure that PQ10 not cause of the problem even if swap PQ3.Last edited by Tuomo; 02-07-2013, 08:38 AM.Comment
Interesting, when AC ON PQ10 PIN4 should be 19V.
Next measure PQ49 PIN2, PQ45 PIN2.
PQ49 PIN 2 should be High when AC ON and Low AC OFF.
PQ45 PIN 2 should be Low when AC ON and High AC OFF.
You can leave PQ10 OFF not need put it pack yet.
If signals look OK you can remove PQ45 and check PQ10 PIN4.Last edited by Tuomo; 02-07-2013, 01:14 PM.Comment
Okay will check tomorrow, I feel we are getting closer to the answer! lolInteresting, when AC ON PQ10 PIN4 should be 19V.
If signals look OK you can remove PQ45 and check PQ10 PIN4.Comment
This is what I get:
PQ45 same whether charging or not charging:
0V----0V
|______|
--3.4V
PQ49 same whether charging or not charging:
0V----8.3V
|______|
---0V
Sorry for the terrible drawings..Comment
No problems. Drawing is fine but i have to find which PIN is 2.
Is it AC OFF and AC ON or Battery ON and Battery OFF?Comment
by razenxdHello,
it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
Now, I have noticed a few things.
The "dead" battery, while connected to charger and NOT Charging will...-
by ruleteroHi
Acer A515-43
LA-H801P
Fail: Does not charge battery, has low voltaje on connector.
Laptop didn't want to turn on, only charge led blinked.
I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know... -
by KlevjetackIs there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
by dclass-proHi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
I noticed 2 things:
1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
2) if I try to turn it on without the battery... - Loading...
