HP Envy 15 cannot charge battery!
Re: HP Envy 15 cannot charge battery!
Ok. PIN 8 is ground.
Good Charge Board.
I'm afraid U33 has broken.
You can check S5_ON signal should be PQ30 PIN 2 = High.
If U33 is broken this voltage should not come.
This works like this.
1. Power Button pressed NBSWON go 3.3V -> 0V -> 3.3V. U33 chip.
2. DNBSWON go 0V -> 3.3V. U33 chip.
3. SUSB# and SUSC# go 0 -> 3.3V. Come from South Bridge
4. S5_ON go 0 -> High this will turn S5 power ON. U33 chip.
If 1, 2, 3, some state fail no S5_ON signal.Last edited by Tuomo; 02-09-2013, 10:21 AM.Comment
According of datasheet I = PIN 2, G = PIN 1, O = PIN 3.
So there is no S5_ON signal.Comment
You are right, It may be possible. I have to investigate schematics.
There is voltage inputs, but have to find way to measure them.
Thanks, tip is very good.Comment
Excelent idea, there is even good places to measure those voltages.
There is capasitors like C736 they are connected together.
So it is enough to measure C736 and C657.Comment
I think there is different area on U33 and part of them will works.
Is this Good charge not works board?
remember i said before with the old board, when the battery is inserted with the power cable and the power button is pressed, the chipset gets very hot very quick, this means before I played around with it U33 worked yes? because it is responding to the power button.
I just tried that again, battery and power cable plugged in and pressed the power button, and the chipset did not get hot at all, only U33Comment
by razenxdHello,
it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
Now, I have noticed a few things.
The "dead" battery, while connected to charger and NOT Charging will...-
by ruleteroHi
Acer A515-43
LA-H801P
Fail: Does not charge battery, has low voltaje on connector.
Laptop didn't want to turn on, only charge led blinked.
I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know... -
by KlevjetackIs there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
by dclass-proHi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
I noticed 2 things:
1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
2) if I try to turn it on without the battery... - Loading...
