HP Envy 15 cannot charge battery!
  • grahamw01
    • 256
    Re: HP Envy 15 cannot charge battery!
    the chip I mean is U6, the main one
    • opamp
      • Dec 2012
      • 160
      • united states
      #182
      Can you make a list of what you changed? or what you moved around? that would help a lot when trying to diagnose what you messed up.
      • grahamw01
        • 256
        yes, PQ13, PQ15, PU11, PQ10, PQ3.. I think!
        • opamp
          • Dec 2012
          • 160
          • united states
          #184
          This is the old board, right?
          • Tuomo
            • 163
            • Finland
            #185
            Originally posted by grahamw01
            remember i said before with the old board, when the battery is inserted with the power cable and the power button is pressed, the chipset gets very hot very quick, this means before I played around with it U33 worked yes? because it is responding to the power button.
            I just tried that again, battery and power cable plugged in and pressed the power button, and the chipset did not get hot at all, only U33
            You are correct again.
            • Tuomo
              • 163
              • Finland
              #186
              VIN "19V" = 6V after PQ22 so something happen there.
              Can you check resistance PC43, I mean same way as PL5 etc. If it is low there is short circuit after PQ22.
              If PC43 resistance is correct PQ22 not OPEN corretly.
              • Tuomo
                • 163
                • Finland
                #187
                This is for New board not for Good Charge board.
                Sorry if I caused confusion.
                • grahamw01
                  • 256
                  This is both boards actually as I swapped from one to the other.
                  • grahamw01
                    • 256
                    Hmm, I can't think of what I have done to U33 on this board though!
                    • grahamw01
                      • 256
                      Resistance is the same on PC43 on both boards, in the Mohms
                      • grahamw01
                        • 256
                        with ICs like PU11 how can I ensure I have put it back correctly? there is no pins, and the pads on the motherboard are so small and close together, i think this is where my problem is..
                        • Tuomo
                          • 163
                          • Finland
                          #192
                          If it is wrong way, it is not work at all. This case no charge etc.
                          Chip has usually small mark which show PIN 1 and motherboard too.
                          If there is no PIN it is very hard put correct into place.
                          We can try check few signals to test PU11 works or not.
                          Charge not work until there is VIN 19V, which missing at the moment?
                          ACOK# signal detect if AC ON or AC OFF. If AC ON = LOW and AC OFF = HIGH.
                          You can check PQ14 PIN2. AC ON = LOW and AC OFF = HIGH.
                          Then you can remove AC try if it boot with Battery.
                          • Tuomo
                            • 163
                            • Finland
                            #193
                            Only thing which may stress U33 is Battery ON/OFF while power is ON.
                            I think U33 was broken allready and just dead.
                            • grahamw01
                              • 256
                              PQ14 pin 2 is 4.8V
                              • grahamw01
                                • 256
                                tried to turn it on with only battery and then AC and battery, still nothing (((((((((
                                • Tuomo
                                  • 163
                                  • Finland
                                  #196
                                  PQ14 pin 2 is 4.8V
                                  Try AC ON and AC OFF. Maybe PU11 not detect AC.
                                  Check PC169 DCIN.
                                  You can check PIN1, PIN3 too. Try boot with battery.
                                  I think if it boot with Battery then problem is PU11.
                                  • grahamw01
                                    • 256
                                    It doesn't boot with anything
                                    • grahamw01
                                      • 256
                                      Check PC169 DCIN.
                                      PC169 is 17.5V
                                      • Tuomo
                                        • 163
                                        • Finland
                                        #199
                                        PC169 is 17.5V
                                        ok. PU11 not works correctly.
                                        • grahamw01
                                          • 256
                                          I will have a play around with it today, and make sure things I have played with are soldered in place properly, thanks
                                          • techfreak9356
                                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                            by techfreak9356
                                            09-14-2023, 11:10 PM
                                          • razenxd
                                            How can I charge that battery pack?
                                            by razenxd
                                            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                            Now, I have noticed a few things.
                                            The "dead" battery, while connected to charger and NOT Charging will...
                                            12-05-2024, 06:11 AM
                                          • ruletero
                                            Acer a515-43 low battery charge voltage
                                            by ruletero
                                            Hi
                                            Acer A515-43
                                            LA-H801P
                                            Fail: Does not charge battery, has low voltaje on connector.
                                            Laptop didn't want to turn on, only charge led blinked.
                                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                            10-24-2022, 02:31 PM
                                          • Klevjetack
                                            Charge a L19D3PDA battery externally from the laptop
                                            by Klevjetack
                                            Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                            03-05-2024, 07:26 AM
                                          • dclass-pro
                                            Latitude 3301 not charge battery
                                            by dclass-pro
                                            Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                                            I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                                            I noticed 2 things:
                                            1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                                            2) if I try to turn it on without the battery...
                                            05-06-2025, 06:19 AM
