Need help finding LED backlight fuse [PICS]
  • xredhawk
    • Jul 2011
    • 103
    #61
    Re: Need help finding LED backlight fuse [PICS]
    might want to try and hook it up to a monitor ,,
    • plumbbob
      • Jan 2014
      • 4
      #62
      Originally posted by gridl0ck
      Sorry just been dicharged from hospital (great start to new year). Anyone was anyone able to look at the pictures and identify the jumpers it.vendor is on about? Looks like I will have to fork out for a replacement laptop
      Hi gridlock I hav exactly the same problem as you and have proven the mother board it at fault did you ever find the root of the problem and the fix I have followed your threads saying that is exactly my boards problem a pic. and location of the lcd power fuse would be grateful thanks.
      • plumbbob
        • Jan 2014
        • 4
        #63
        Originally posted by it.vendor
        place a jumper over the FET S to D (LCD power) under pin No 1 of lcd jack on main board.
        Hi can you show me a pic.or diagram of FET S to d as I am having trouble locating it could you circle the componant thanks.
        • skorpionct
          • Feb 2014
          • italia
          #64
          Hello. i'am italian, in this image the component in the circle white is a fuse?
          Because not continuity in the component.
          • skorpionct
            • Feb 2014
            • italia
            #65
            The motherboard is K53SD REV:2.3
            • wishmasteruk
              • Feb 2014
              • 6
              • East Yorkshire
              #66
              Hi, have attached some photos to this. There was a 0 component there which I tried to jump to see if it makes a difference, but no luck.
              hi just fixed mine today (x53e) after testing just about every part on the board replace the jumper or bridge it like i did good luck
              • memalt01
                • Feb 2014
                • 10
                I am having the same issue with no backlight on my asus K54L_HDMI Rev 3.0 motherboard. So far I changed the LCD cable and the 40pin LED screen with no joy. I checked all the fuses and 0 ohm resistors which all were good. A little component looks like a diode has over 19V on one hand and no voltage on the other. I assume the diode should behave that way but other components looks the same has very little voltage variations on both joints. Can anybody please advice me what to look for in this board? I will try to add some pics now.
                • sorinac
                  • Jul 2013
                  • 123
                  • Romania
                  #68
                  NO . That is a capacitor and it is a protection for network chip.
                  • memalt01
                    • Feb 2014
                    • 10
                    I called asus regarding on backlight issue on K54L Rev 3.0 motherboard. Apparantly this is not a common issue which I suspected as the problem caused by not taken the battery out when changing the black spots LCD panel. Asus would not assist the self repairs so, I am on my own with this. I wonder if I short the component in above picture where one leg has 19V and other 0V? Would the motherboard fry?
                    • cyberhack
                      • Feb 2013
                      • 466
                      • Uk
                      #70
                      Very poor soldering dc socket in the picture get a hotter iron
                      • wishmasteruk
                        • Feb 2014
                        • 6
                        • East Yorkshire
                        #71
                        depends what component your shorting/bridging , if its any of the 0 jumpers it wont make a difference if you connect them with solider, they are used as a connection between 2 points (easier for the machine to solider?) and also can be used as cheap fuses, the fuse/jumper you are looking for are normally close to the lcd ribbon, with no power to board check for resistance on 0 jumpers if you get nothing you have found it gd luck.
                        • wishmasteruk
                          • Feb 2014
                          • 6
                          • East Yorkshire
                          #72
                          i may be wrong but that dont look like a diode to me, looks to me like you may have found your problem.
                          • dj_ricoh
                            • 2073
                            #73
                            that`s a coil !!
                            who wanna bet?
                            PL or L marking
                            post the voltage from the connector!
                            • dj_ricoh
                              • 2073
                              #74
                              the soldering job? on the socket!
                              don`t listen to them they did not do a better job in the beginning
                              find some flux next time it will crystallize the solder
                              • memalt01
                                • Feb 2014
                                • 10
                                Tanks for the reply wishmark and dj, The components on this asus x54H has no labels, completely blank. Amost all the similar components as the suspected one have very small voltage variations on their both legs. And when I measured the resistance all the components have ohm value but this one is open circuit and side of the point has over 19V while the other point has 0V. This is not a fuse or a 0 value resitor as the other fuses has P or pl symbol on it and the jumpers has 0 in the middle. It is not a inductor as there is no coil that you can see plus there is an inductor close to the LED socket in the motherboard. What to do? Shorted or take and pick similar component from another motherboard and try it but without knowing the value and the identity of this component is very hard to choose.
                                  @memalt: The component in white circle, is one of its leg connected to ground?
                                  • memalt01
                                    • Feb 2014
                                    • 10
                                    Hi budm, yes one of the leg is connected to the ground and the other leg measured 19V when the power was on last time. Is it good or is it bad? :-) I suspect you will go against shortening the component as the ground and the 19V may give some strong spark. That's why I was confused and didn't go head to short this but would you see any other reason for this dim display? What is that component in the picture (resistor or a diode?)
                                      Then do not jump it, you will just short out the 19V to ground. At least it is not shorted.
                                      If you can get the LCD panel number then look up the spec sheet, it will give you the pin out of the connector and will tell you which pin is for the LEDs.
                                      Pictures of the connector on the LCD panel?
                                      • memalt01
                                        • Feb 2014
                                        • 10
                                        Yes budm, that would be a good way of finding the voltage levels on 40 pin motherboard connector. I have the specs for this LCD pannel
                                        I will check it out the voltage levels but it is going to be extremely hard when I can't find the schematic or components id's for this motherboard. I was looking for open fuse or open 0 ohm resistor to fix this issue but everything seems to be ok but still no good display on the screen. I have a pic of the connector for this lcd pannel.
                                        • sorinac
                                          • Jul 2013
                                          • 123
                                          • Romania
                                          #80
                                          maybe this schematics will help you
                                          it is not the same but the display connector is the same
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                          • drykid
                                            Matsui 175S microwave fuse replacement
                                            by drykid
                                            I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                                            Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                                            12-21-2020, 01:15 PM
