High-voltage ntb PSU
  • Behemot
    • 4845
    • CZ
    I have the older NX5000 laptop which uses 18,5 V input power, however the new power supplies are for 19 V. On the other hand since battery fluctuates between some 14,5 and 16,5 V, I would say all the internal VRMs are quite flexible.
    So, do you think it will work with half a volt higher input voltage?
  • mariushm
    • May 2011
    • 3799
    Re: High-voltage ntb PSU
    I say it will work. But the brick will probably output around 19.2v at low loads.
    Alternatively, I think you could just wire a diode on the cable - these generally have voltage drop of 0.6-0.8 volts. Just pick one that can handle the amps.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Hi - do you have access to Amazon.com in Czech republic?
      Can you get a Universal adapter
      http://www.amazon.com/Universal-Adap...5521193&sr=1-2
      or perhaps less postage from Germany
      http://www.amazon.de/Universal-Noteb...522168&sr=1-23
      • mariushm
        • May 2011
        • 3799
        I don't really recommend those with variable voltage output, at least those cheap ones.
        They overheat a lot and can probably barely handle 50 watts...
        If it's Compaq NX5000, the specs say it's a 65w adapter so you should get at least one that does that much.
        Amazon lists a lot just by searching for nx5000 but they're all noname or oem compatible, not sure about their quality:
        http://www.amazon.com/s/ref=nb_sb_no...nx5000&x=0&y=0
        Since you're Czech, you may have better luck using amazon.co.uk or amazon.de instead of the .com version
        • Behemot
          • 4845
          • CZ
          The laptop itself consumes some 40 watts top (I have undervolted CPU, but this is even when charging), actuall measured value before PSU. Consider even the effectivity.
          I don't need it so much to buy a new, it was more like a question of interest. Jsut thought it shoudl handle that, as I said, VRMs have to be flexible down, so there may be also flexible up. But this 0,5 V is less than 3 % difference so I wil try it and see. I took one 19V unit home as a spare so I will do it when I come home next time. Have to also buy cinch connector since I modified the cables
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            The MOSFETs are 30v anyway - it'll work with up to 24 volts just fine. Tested myself.
            A working TV? How boring!
            • Behemot
              • 4845
              • CZ
              uN1Qu3 saves the day again. Thanks bro
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Well that wasn't too hard, i'm sure you could have figured it out by yourself. You have to consider that the chargers can be half a volt (or even more) off from the factory, AND that regulation can't possibly be perfect (it's actually worse than in desktop PC power supplies), and it quickly becomes apparent that there has to be several volts of headroom in the electronics.
                I suspect that the reason for those funny ratings is that they tested and picked the input voltage which gives highest efficiency - so they can skimp on the power bricks as much as they can. Using a lower than needed voltage will usually make the charging circuit drop out but the laptop will still run if it's not too far off. Using a higher voltage won't do any harm unless you exceed the rating of the MOSFETs - and this is always 30 volts, unless the thing is spec'd to run off 12v, in which case they might be 25v.
                • Behemot
                  • 4845
                  • CZ
                  Well sure I know there is much headroom down, for the batteries. But I needed to confirm there is also headroom up
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    You can confirm this by looking at the schematic:
                    There's a MAX1772 that charges the battery and that can handle up to 28V, and the caps are 25V, but the MAX1999 main PSU controller is rated for 24V.
                    So don't go beyond that. I personally would stay with 20V for a safe limit.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      19V 3.42A (65W) or 4.74A (90W) laptop PSUs are available like sand on the beach.
                      Get a delta one (for example SADP-65KB) and you won't have problems (if it's an original and not a chinese knockoff)
                      • Behemot
                        • 4845
                        • CZ
                        Yeah I know I have a few of these 19V PSUs. That is the all reason why I asked, because original 18,5V units are difficult to find :-)
                        • pb1911nt
                          MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
                          by pb1911nt
                          Hello forum,
                          I'm still relatively new to the world of electrical repairs.
                          I have a Macbook here that I can't figure out
                          When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
                          I removed the logic board and took a few measurements.
                          But I can't really figure it out.
                          At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
                          09-07-2025, 11:35 AM
                        • mkdj
                          MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                          by mkdj
                          About me, my goal and the equipment I (don't) have:
                          I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                          About my issue and my goal:
                          A friend of mine has a MacBook Air M1 A2337 that does not...
                          04-03-2025, 08:28 AM
                        • 90Ninety
                          Dell XPS 8100 Motherboard VRMS keep blowing
                          by 90Ninety
                          I wanted to save this thing from E-waste ... I helped a neighbour with their Dell PC , it had a blown visably blown VRM causing a short on the 12V EPS ..
                          I replaced this VRM which fixed the short but, the high side VRM's keep blowing , seemingly the same two phases .. I replaced the low side mosfets on the respective blown phases . Though still the High side VRMS are blowing ..
                          After a few minutes one of the four phases will get extremely hot , then blow ..
                          I purchased replacement VRMS both High Side (72T02GH) and Low side (86T02GH). Pictured below , I just...
                          10-05-2024, 08:36 AM
                        • gervaisc
                          Macbook Air 2020 (A2179 / 820-01958) PPBUS_G3H fluctuates from 0 to 12V
                          by gervaisc
                          Hello, I am troubleshooting my daugther's MacBook Air 2020 (A2159), no liquid spills, not dropped. It was working well for the last 3 1/2 years and now refuse to power on.
                          Took of the board (nothing connected). Visual inspection with microscope looks ok. The USB-C voltage is 5.17V, current fluctuates from 0.05A to 0.120A. No sign of 20V.
                          I followed the (excellent) guide here: https://repair.wiki/w/MacBook_Air_A2...w_at_5V_repair
                          1- No shortsbetween PPBUS_G3H and ground. It shows more than 1Mohm
                          2- The PPDCIN_G3H...
                          08-02-2024, 06:06 PM
                        • ACS-Repair
                          MacBook Pro A1398 820-3662 CPU VRMs
                          by ACS-Repair
                          Hello All,
                          I'm having trouble replacing the CPU VRMs on my 820-3662A. This board was crashing randomly and I know the VRMs are the usual suspect.
                          I removed all three of the VRMs but after I replaced them, only the Phase-1 VRM was working (it gets very hot, the others are cold). I get 1.29v on the VRM coil outputs, which appears to confirm that only one phase is operating.
                          To prove this I removed the VRMs for Phase 2 and Phase 3, then powered the board up. The VRM output is a 1.29 with only U7310 connected. I decided to replace the controller U7200 but it did not change the...
                          09-23-2021, 02:53 PM
