Dell XPS 8100 Motherboard VRMS keep blowing
  • 90Ninety
    • Aug 2011
    • 102
    • UK Mains Voltage 240V 50 Hz
    I wanted to save this thing from E-waste ... I helped a neighbour with their Dell PC , it had a blown visably blown VRM causing a short on the 12V EPS ..
    I replaced this VRM which fixed the short but, the high side VRM's keep blowing , seemingly the same two phases .. I replaced the low side mosfets on the respective blown phases . Though still the High side VRMS are blowing ..
    After a few minutes one of the four phases will get extremely hot , then blow ..
    I purchased replacement VRMS both High Side (72T02GH) and Low side (86T02GH). Pictured below , I just removed the last blown high side VRM and temporarily removed the nearby capcitor to check
    Click image for larger version  Name:	dell .jpg Views:	0 Size:	298.4 KB ID:	3477166
    I have stabbed around the board , there is no shorted caps . All nearby resistors seem fine too ..
    I think the picture below is the VRM controller (NCP5395T), this chip is available on AliExpress. Would it be worth buying and swapping it out
Name:	vrm controller.jpg
  • 90Ninety
    • Aug 2011
    • 102
    I fixed this
    I wound up replacing all the phase mosfets .. No issue now
      HP Compaq Elite 8100 SFF Compaq Elite 8100 i3-550 Specification for Upgrade or Repair
      This specification for the HP Compaq Elite 8100 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8100 SFF boardview and Compaq Elite 8100 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-12-2024, 03:44 PM
      HP Compaq Elite 8100 Compaq Elite 8100 i5-660 Specification for Upgrade or Repair
      This specification for the HP Compaq Elite 8100 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8100 boardview and Compaq Elite 8100 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-12-2024, 03:28 PM
    • flibidy
      Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
      by flibidy
      I have here a Magnum IA.100 which belongs to my parents.
      The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
      Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
      What Ive done........
      01-01-2025, 01:26 PM
    • c_corr
      Asus P4C800-E VRM issues
      by c_corr
      This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
      This board uses mext ICs and Mosfets in VRM:
      - ADP3180 PWM controller - in 3 phase mode
      - ADP3418 as Modfet drivers
      - High side Mosfets STD38NH02L (from ST)
      - Low side Mosfets STD90NH02L
      Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
      I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
      02-08-2025, 11:59 PM
