Macbook Air 2020 (A2179 / 820-01958) PPBUS_G3H fluctuates from 0 to 12V
  • gervaisc
    Claude
    • Feb 2023
    • 9
    Hello, I am troubleshooting my daugther's MacBook Air 2020 (A2159), no liquid spills, not dropped. It was working well for the last 3 1/2 years and now refuse to power on.
    Took of the board (nothing connected). Visual inspection with microscope looks ok. The USB-C voltage is 5.17V, current fluctuates from 0.05A to 0.120A. No sign of 20V.
    I followed the (excellent) guide here: https://repair.wiki/w/MacBook_Air_A2...w_at_5V_repair
    1- No shortsbetween PPBUS_G3H and ground. It shows more than 1Mohm
    2- The PPDCIN_G3H shows a nice and steady 5.17V
    3- PPBUS_G3H fluctuates a lot in a steady manner (I do not have a scope), multimeter shows from 4.5V to 12V when putting it in AC+DC mode. I confirmed with an analog multimeter, the needle goes from 4.5V to 12V, then drop to 4.5V then 12V.... It looks like "trying hard" to reach to 12V however not successful and returns to almost zero.
    4- R7021 and R7022 show 23 and 47 ohms. I swear that they were reading around 1ohm yesterday...
    5- R7061 and R7062 both show around 1 ohm.
    6- The PP3V3_G3H_RTC and PPVIN_G3H_P3V3G3HRTC are also fluctuating - I think they are down the cascade line so I do not pay attention to this.
    7- Other quick measurements I took around the U7000 ISL9240:
    PPCHGR_VDDA = 5V
    PPCHGR_VDDP = 5V
    PPDCIN_G3H_CHGR_AMON = 5V
    CHGR_CSI_N = 5V
    CHGR_CSIR_N = 5V
    CHGR_CSIR_P = 5V
    After looking at many forums, I suspect the ISL9240 (U7000) is damaged. But before replacing it (I have never done this with such a small component...), could it be something else since it is "trying" hard to reach 12V?
    Any other things to check?
    many thanks!
  • mon2
    • 14679
    Welcome. Before my Netflix binge...
    1) Do not attempt the ISL9240 replacement till we can all agree that it is required. This is a very small WLCSP package and not an easy one to replace without damaging the pcb pads and/or nearby parts. This on top of soldering back a fresh one without shorts. Suggest some practice on a donor board only if this is even required. Another suggestion is to lean on a good neighborhood cell phone repair shop tech to perform the replacement. If they can replace tristar chips inside of iphones, they can handle this repair.
    2)
    Stop. This is of concern. If you feel comfortable, consider to flux and carefully remove each off the board and measure their resistance again after the parts are cool and on your work table. They are tiny and very easy to lose. If you do lose them, they are available on Digikey / Mouser / Arrow but there are shipping fees associated with each. The parts are pennies but DK will charge +$8 for shipping (next business day) to Canada. Each resistor must match the resistance shown in the schematics.
    3) You may wish to pickup a digital multimeter off Amazon. Most are inexpensive and can serve the purpose to confirm the resistance / voltage measurements. Be sure the meters are with fine needle like tips. Then short the probes to know the lowest (baseline) resistance of your meter. Then measure away.
    4) Remove all power. Meter in resistance mode. Measure the resistance to ground of each and every inductor on the board. Each inductor is linked to a low switching buck regulator. If there is a lower than normal resistance, then that rail may be shorted. Start with the CPU voltage inductors.
    5) Also, measure the resistance (without any power / no battery to the board) from the PPBUS_G3H junction (fuse is ok) AND then each inductor on the board. If you see a low resistance then this is of concern and means that the high side mosfet that mates with that inductor has leaked. With such a leak, the high voltage from PPBUS_G3H has travelled onto the low voltage rails.
    Post the details from your hunting expedition.
    • gervaisc
      Claude
      • Feb 2023
      • 9
      Wow. thanks for the info! I'll have a look at #4 and #5 tomorrow morning with a fresh mind... For the multimeter, I am using two to make sure the reading are good, one is a Fluke 187 and the other one is an LCR meter. You have a good point, I used "clip on" needle adapter on my probes and I had way too much resistance on them when shorted. I used another set of probes with a bit bigger tip and measured 11 Ohm (R7021) and 91 Ohm (R7022). Why are you saying it is a concern? I know they are used to sense current, in my mind a resistor should not go up in resistance, shorting to zero but opposite is puzzling me. Stay tuned for the testing tomorrow. Thanks again.
      • gervaisc
        Claude
        • Feb 2023
        • 9
        Hello mon2 , I have completed the step #4. Nothing very conclusive except L7806 ? BTW I fixed my probe leads, shorting them together is now 0.31ohm. I (re)measured the problematic resistors, still high.
        R7021 = 11ohm
        R7022 = 111ohm
        Note that I did not solder them off the board yet.
        I also noticed that plugging USB-C before doing step #5 to measure PPBUS_G3H it is now gone!... 0V. The USB-C input current is now stable at 0.025A, I guess this is a bit worrisome...
        Results from GND to inductor:
        L1350 = n/a
        L2800 = not tested, did not remove U2800/U2900 cover
        L2900 = not tested, did not remove U2800/U2900 cover
        L3100 = 1.7Mohm (4 pins)
        L3200 = 1.7Mohm (4 pins)
        L4460 = 2.2Kohm
        L4590 = 2.2Kohm
        L6400 = 2.2MOhm
        L6401 = 2.2MOhm
        L6520 = 1Mohm
        L6700 = 2Mohm
        L6701 = 1Mohm
        L6702 = 1Mohm
        L6703 = 4Mohm
        L6960 = 1.5MOhm
        L7030 = 2MOhm
        L7210 = 107ohm
        L7220 = 107ohm
        L7230 = 107ohm
        L7400 = 142ohm
        L7670 = 700Kohm
        L7690 = 700KOhm
        L7700 = 300ohm
        L7701 = 300ohm
        L7806 = 6.8ohm (too low??)
        L7807 = 1 side not accessible, other side same as L7806 = 6.8ohm
        L7808 = 1 side not accessible, other side same as L7806 = 6.8ohm
        L7809 = 1 side not accessible, other side same as L7806 = 6.8ohm
        L7810 = 78ohm
        L7811 = 20ohm
        L7812 = 20ohm
        L7813 = 2.5Mohm
        L7814 = 2.3Kohm
        L7815 = 2Kohm
        L7816 = 30ohm
        L7817 = 31ohm
        L7819 = 30Kohm
        L7820 = 30Kohm
        L7821 = 860ohm
        L7822 = 860ohm
        L7823 = 220ohm
        L7824= 1Mohm
        L8100 = 270ohm
        L8150 = 300ohm
        L8410 = 1,5MOhm
        L8420 = 160ohm
        L8507 = more than 10Mohm (open, confirmed with C8584/C8585)
        L8509 = more than 10Mohm (open, confirmed with C8580/C8581)
        L8570 = 1Mohm
        L8580 = more than 10Mohm (open, confirmed with C8580)
        L8581 = more than 10Mohm (open, confirmed with C8581)
        L8584 = more than 10Mohm (open, confirmed with C8584)
        L8585 = more than 10Mohm (open, confirmed with C8585)
        L9060 = 14KOhm
        • mon2
          • 14679
          Remove all power. Measure the resistance to ground of PPBUS_G3H at the fuse.
          (Friggen Canada just lost at the penalty kick)
          • gervaisc
            Claude
            • Feb 2023
            • 9
            From F7000 I assume - it is 2.55Mohm
            • mon2
              • 14679
              Review this case study:
              • gervaisc
                Claude
                • Feb 2023
                • 9
                yes this is what I used before writing this post. Rechecked again:
                - Between GND and PPBUS_G3H = open
                - Voltage PPDCIN_G3H = 5.17V
                - I get now 0V on PPBUS_G3H , leading to the ISL9240 bad chip according to the case study. However I do have those "bad" R7021 and R7022. What do you think?
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  No point in checking random stuff until the charging circuit is fixed and PPBUS_G3H comes back to normal. Replace the resistors for the charger current sensing path and if they burn again you know you have to replace the charger IC.
                  • gervaisc
                    Claude
                    • Feb 2023
                    • 9
                    Hello mon2 piernov i changed R7021, R7022 and U7000 (ISL9240) from a donor board I got on eBay. I was quite excited (that was my first experience to change such a tiny component) because I got 20.07v on USBc - reassembled without connecting battery and saw twice the apple logo and heard the chime. But not booted completely, the progress bar was stuck and fan spinning to the maximum. Connected battery and saw amp went from .4 to 1.4 amp, always cycling every 5 secs or so. So after tried some random things such as trying to go DFU or SMC reset … and got after about30 mins 5v on USBc. Dissembled the board and my PPBUS_G3H is back to fluctuations from 0V to something. I am afraid that ISL9420 will die again… any thoughts???
                    • mon2
                      • 14679
                      Measure the resistance to ground of PPBUS_G3H.
                      What is the resistance in ohms?
                      • gervaisc
                        Claude
                        • Feb 2023
                        • 9
                        Thanks mon2 for your help. I had a bit more time to spend on my "project" today. Early in the morning I got a steady 20V at USB-C, and PPBUS_G3H was 12V, looks stable. Put the board back in the laptop (I had hopes), then USB-C input was back at... 5V. Back to square 1 and PPBUS_G3H is cycling (fluctuates again). Decided to remove R6961 (to open the circuit at U6960) then the PPBUS_G3H stable 12V. So the problem is no longer ISL9240. I am continuing my investigation. Feel free to chip in !
                        • gervaisc
                          Claude
                          • Feb 2023
                          • 9
                          I noticed something weird - if I connect left rear USB-C port (Let's say), I get 12V on PPBUS_G3H. If I disconnect it (or change to left front), then reconnect after the PPBUS_G3H is gone. If I wait let's say 10 mins, it is back again. The R6961 is still open.
                          • mon2
                            • 14679
                            Inspect the quality of the USB Type C connectors that are on this logic board. Apple made these paddle boards modular (and hope they keep it this way). The replacement boards should be available through Mobile Sentrix (Toronto). We use them often and most of the time, they are more competitive than Aliexpress stores with next day delivery to us in Ontario.
                            • Darren Hibbert
                              MacBook A2179 Audio board+Power button boardview & schematic needed
                              by Darren Hibbert
                              Hi.
                              Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
                              There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
                              Many thanks. ...
                              08-21-2025, 02:38 PM
                            • pb1911nt
                              MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
                              by pb1911nt
                              Hello forum,
                              I'm still relatively new to the world of electrical repairs.
                              I have a Macbook here that I can't figure out
                              When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
                              I removed the logic board and took a few measurements.
                              But I can't really figure it out.
                              At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
                              09-07-2025, 11:35 AM
                            • cheebster
                              Macbook Air 2020 A2179 Internet Recovery and Battery Issues
                              by cheebster
                              Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
                              The 10 of them show the exact same behavior;
                              They auto power on, to internet recovery spinning globe, fans to 100%.
                              Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
                              Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
                              All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
                              10-09-2024, 06:23 AM
                            • CAPTGENE
                              A2179 Macbook Air turns ON and works normally with a battery but it is not charging
                              by CAPTGENE
                              I have similar a similar issue. My A2179 Macbook Air turns ON and works normally with a battery but it is not charging. With the USC-C alone it takes 20V but only 100mA, PPBUS is 12.3Volts, and wont turn ON.
                              I replaced U7000 twice with the same result. not charging!
                              Whats should I check or replace?
                              02-20-2025, 02:58 AM
                            • envym
                              by envym
                              Hi everyone!
                              06-27-2025, 08:54 AM
