MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
  • mkdj
    • Mar 2025
    • 56
    • France
    About me, my goal and the equipment I (don't) have:
    I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
    About my issue and my goal:
    A friend of mine has a MacBook Air M1 A2337 that does not power on. He went to an Apple Store which told him to change the motherboard. He bought another laptop, and gave me this faulty MacBook so I can have fun trying to repair it. As I want to learn, this is a perfect exercise for me. I am here to share what I have done until now on this MacBook, and ask for help to continue my diagnosis. Once the diagnosis is completed, I want to ask someone to replace the faulty part for me. My goal is to understand what to do to continue the diagnosis.
    This being said, now the fun part!
    Troubleshooting process:
    Hardware: MacBook Air A 2337 (M1, 2020). Board number 820-02016.
    History: No liquid damage, no drop, nothing particular. It just stopped powering on one day, after a complete discharge. It had only 3 years of use. My friend kept it in a closet until I ask him to give it to me 3 weeks ago.
    In these 3 weeks I have run the following tests:
    - Measured power in the 2 USB-C ports, in both directions. It gave me 5.1V, and random A, some bursts at 0.430A, then around 0.05A, then another burst at 0.430A.
    - Opened the laptop, removed the motherboard, and did my first voltage measurements on motherboard ever:
    Signal name Measuring spot Values
    PPVBUS_USBC0 CF401 Not measured
    PPHV_INT0_AONSW FF200 Fluctuates between 4.86 and 5.18V
    PPHV_INT1_AONSW FF201 Fluctuates between 4.86 and 5.18V
    PPDCIN_AONSW FF200 (aussi) Fluctuates between 4.86 and 5.18V
    PPBUS_AON F5200 Fluctuates between 11.9 and 12.3V
    PP1V8_S2 CF403 Fluctuates between 0 and 0.135V
    PP5V_S2 CP941 0V stable
    PP1V25_S2 C5320 Fluctuates between 0.09 and 0.13V
    PP1V2_S2 C830A Fluctuates between 0 and 0.70V
    PP3V3_S2_UPC RF283 Fluctuates between 0 and 0.134V
    PP1V8_AON_MPMU R8324 1.8V stable
    MPMU_VREF_ADC C8321 0V stable
    USBC0_3V3LDO_EN TPG087 Fluctuates between 0 and 0.02V
    USBC0_3V3LDO_EN_R RF012 Fluctuates between 0 and 0.002V
    USBC1_3V3LDO_EN_R RF112 or TPG063 0V stable
    PPBUS_5VS2_VIN CC325 Before removing the board, with AC adapted and battery plugged in: fluctuates between 10 and 12V and I hear a "clic" in the battery every second
    After removing the board : fluctuates between 12 and 12.3V, and I don't hear any "clic"
    PP1V5_UPC0_LDO_CORE CF405 Fluctuates between 0.05 and 0.16V
    PP3V3_UPC0_LDO CF408 Fluctuates between 0.65 and 0.82V
    PP1V5_UPC1_LDO_CORE CF505 1.586V stable
    PP3V3_UPC1_LDO CF508 3.44V stable
    PP3V8_AON_VDDMAIN CF110 3.79V stable
    Then, I looked in the schematics to look for what the PPBUS_5VS2_VIN is feeding. I found that UC300 is supposed to create PP5V_S2 from PPBUS_5VS2_VIN. As PP5V_S2 is missing, I want to see if P5VS2_EN is different from 0V.
    Also, I search the Internet, and found this resource: https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
    This resource says to check PP3v3_S2 voltage at LC710, which is at the output of UC710.
    So, I did another round of measurements:
    Signal Measuring spot Values
    PP5V_S2 LC320 0V
    P5VS2_EN PPC210 0V
    PP3V3_S2 LC710 0V
    PPBUS_3V3S2_VIN CC721 12,3V stable
    P3V3S2_EN PPC200 1,57V stable
    PPBUS_5VS2_VIN (extra measurement) CC325 12,3V stable
    PP3V3_S2 (diode) LC710 0.257
    P3V3S2_PGOOD PPC201 0V
    I notice that I have no PP3V3_S2 signal, although UC710 is enabled and that I have a PPBUS_3V3S2_VIN signal.
    This is where I am stuck.
    I think the next step is to look for short-circuits. But I am not sure where, and how to do that. I have measured continuity between GND and LC710 (both sides), and my multi-meter does not beep. Resistance is very high between these two spots. Also, I have measured PP3V3_S2 in diode mode (red probe on GND, black probe at LC710), and it gave me 0.257. I don't know how to interpret this value.
    I interpret this situation as follows: there is no short-circuit. If there were a short, I would have had less than 1 Ohm between LC710 and ground. Is that right?
    If I had found a short, I would have tried voltage injection and alcohol/freeze spray/thermal camera to find the shorted component. But now I do not know what to do. My guess is that it is the UC710 that is faulty and need to be replaced. But I am not sure at all of my diagnosis.
    Also, I don't understand why one of the CD3217 has created its LDOs, and the other has not. If UC710 were faulty, I would have expected all LDOs not to be created. How do I know that the faulty component is not one of the two CD3217?
    What do you think of my analysis so far, and what would you do now if you were me?
    Any help or link to useful resources to help me understand would be really appreciated!
    Cheers,
    mkdj
  • mon2
    • 15889
    Hi. Welcome. A lot to read but suggest the following. Remove all power. Disconnect the battery. Meter in resistance mode. Measure the resistance to ground on each and every inductor that is on the board. Each inductor is linked to a power rail. We are checking the resistance to ground to understand if there is a shorted part onboard. Post any suspects.
    Also, later on, for power injection to hunt for shorted parts, never use a voltage higher than the lowest voltage. We use typically 0v6 - 0v8 while some are ok with 1v0. This is using an external adjustable power supply that will dialed to this injection voltage & say 3A-5A which should be ample to locate the shorted part (if one is found).
    Recently fixed an 'unfixable' A1932 with a shorted ceramic cap that was present on the audio board. This single cap was tanking the PPBUS_G3H main power rail. Multiple shops reported to replace the motherboard. This replacement of the board would NOT have fixed this case since the fault was on a remote audio board (headphone board). The wholesale price for this board alone was $90 from Asia. After removing 5 caps (in order), the bad boy was found and unit is working as it should be.
    • mkdj
      • Mar 2025
      • 56
      • France
      Thank you mon2 for your message and your pieces of advice.
      I've done the following measurements as suggested:
      Inductor Resistance
      L5230 2.2 MOhm
      LC320 1.8 MOhm
      LP800 1.1 MOhm
      L5840 0.49 MOhm
      L5820 0.36 MOhm
      L5800 0.37 MOhm
      Nothing suspicious according to me. If we had a short we would have measured less than a few Ohm, no?
      What now?
      • mkdj
        • Mar 2025
        • 56
        • France
        Dear all,
        It's me again. This is an old topic but I still have the laptop.
        I remembered I messed up something a few months ago while measuring voltages. I saw sparkles around a capacitor (but I don't remember which one). I then stopped to work on this laptop.
        Today, I started to work on it again. When I plugged the USB-C charger, I now have 5V and around 300mA with no pattern.
        I extracted the mother board, and I have no short on the main inductors. I plugged the board, and observed that there was heat in a zone with many components. I tested these components, and I found a short on one capacitor (C830C). I removed the capacitor, but the short is still here. And I still have heat in this area when I plug the USB-C charger.
        Looking at the boardview, I know it is the PP1V8_AON_MPMU that is shorted to ground. I think what I should do now is to inject 0.8V on this rail, and maybe find other shorted components with my thermal camera. But the components are very tiny, so I am waiting for my new needles probes to inject voltage.
        Do you believe this board can be saved? What would you try if you were me?
        I have two working spare board, so I have plenty of spare parts.
        Regards,
        mkdj
        • BrandonJL
          • 20
          • South Africa
          Hope this helps you.
          I had the exact same issue down to every fluctuation on the voltage with no liquid damage.
          I found out that C7801 had damaged U7700 so after replacing U7700, all the voltages stopped fluctuating but were all quite low. PPBUS_AON was only 6v so after replacing U7700 I was able to narrow it down to C7801 being shorted on the PP5V_BSTLQ_VOUT_SPMU line and now everything is working perfectly.
          No further issue found. Hope this will help someone.
          • mon2
            • 15889
            BrandonJL Thanks for the update of your case. mkdj - Missed the follow up post.
            Remove all power. Meter in resistance mode. What is the resistance to ground of PP1V8_AON_MPMU?
            In post #1, the PP1V8_AON_MPMU is listed to be stable with 1v8 output. Is this no longer valid? In any part that is heating up, remove all power and measure their resistance to ground. Post all suspects.
