MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
  • mkdj
    • Mar 2025
    • 15
    • France
    About me, my goal and the equipment I (don't) have:
    I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
    About my issue and my goal:
    A friend of mine has a MacBook Air M1 A2337 that does not power on. He went to an Apple Store which told him to change the motherboard. He bought another laptop, and gave me this faulty MacBook so I can have fun trying to repair it. As I want to learn, this is a perfect exercise for me. I am here to share what I have done until now on this MacBook, and ask for help to continue my diagnosis. Once the diagnosis is completed, I want to ask someone to replace the faulty part for me. My goal is to understand what to do to continue the diagnosis.
    This being said, now the fun part!
    Troubleshooting process:
    Hardware: MacBook Air A 2337 (M1, 2020). Board number 820-02016.
    History: No liquid damage, no drop, nothing particular. It just stopped powering on one day, after a complete discharge. It had only 3 years of use. My friend kept it in a closet until I ask him to give it to me 3 weeks ago.
    In these 3 weeks I have run the following tests:
    - Measured power in the 2 USB-C ports, in both directions. It gave me 5.1V, and random A, some bursts at 0.430A, then around 0.05A, then another burst at 0.430A.
    - Opened the laptop, removed the motherboard, and did my first voltage measurements on motherboard ever:
    Signal name Measuring spot Values
    PPVBUS_USBC0 CF401 Not measured
    PPHV_INT0_AONSW FF200 Fluctuates between 4.86 and 5.18V
    PPHV_INT1_AONSW FF201 Fluctuates between 4.86 and 5.18V
    PPDCIN_AONSW FF200 (aussi) Fluctuates between 4.86 and 5.18V
    PPBUS_AON F5200 Fluctuates between 11.9 and 12.3V
    PP1V8_S2 CF403 Fluctuates between 0 and 0.135V
    PP5V_S2 CP941 0V stable
    PP1V25_S2 C5320 Fluctuates between 0.09 and 0.13V
    PP1V2_S2 C830A Fluctuates between 0 and 0.70V
    PP3V3_S2_UPC RF283 Fluctuates between 0 and 0.134V
    PP1V8_AON_MPMU R8324 1.8V stable
    MPMU_VREF_ADC C8321 0V stable
    USBC0_3V3LDO_EN TPG087 Fluctuates between 0 and 0.02V
    USBC0_3V3LDO_EN_R RF012 Fluctuates between 0 and 0.002V
    USBC1_3V3LDO_EN_R RF112 or TPG063 0V stable
    PPBUS_5VS2_VIN CC325 Before removing the board, with AC adapted and battery plugged in: fluctuates between 10 and 12V and I hear a "clic" in the battery every second
    After removing the board : fluctuates between 12 and 12.3V, and I don't hear any "clic"
    PP1V5_UPC0_LDO_CORE CF405 Fluctuates between 0.05 and 0.16V
    PP3V3_UPC0_LDO CF408 Fluctuates between 0.65 and 0.82V
    PP1V5_UPC1_LDO_CORE CF505 1.586V stable
    PP3V3_UPC1_LDO CF508 3.44V stable
    PP3V8_AON_VDDMAIN CF110 3.79V stable
    Then, I looked in the schematics to look for what the PPBUS_5VS2_VIN is feeding. I found that UC300 is supposed to create PP5V_S2 from PPBUS_5VS2_VIN. As PP5V_S2 is missing, I want to see if P5VS2_EN is different from 0V.
    Also, I search the Internet, and found this resource: https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
    This resource says to check PP3v3_S2 voltage at LC710, which is at the output of UC710.
    So, I did another round of measurements:
    Signal Measuring spot Values
    PP5V_S2 LC320 0V
    P5VS2_EN PPC210 0V
    PP3V3_S2 LC710 0V
    PPBUS_3V3S2_VIN CC721 12,3V stable
    P3V3S2_EN PPC200 1,57V stable
    PPBUS_5VS2_VIN (extra measurement) CC325 12,3V stable
    PP3V3_S2 (diode) LC710 0.257
    P3V3S2_PGOOD PPC201 0V
    I notice that I have no PP3V3_S2 signal, although UC710 is enabled and that I have a PPBUS_3V3S2_VIN signal.
    This is where I am stuck.
    I think the next step is to look for short-circuits. But I am not sure where, and how to do that. I have measured continuity between GND and LC710 (both sides), and my multi-meter does not beep. Resistance is very high between these two spots. Also, I have measured PP3V3_S2 in diode mode (red probe on GND, black probe at LC710), and it gave me 0.257. I don't know how to interpret this value.
    I interpret this situation as follows: there is no short-circuit. If there were a short, I would have had less than 1 Ohm between LC710 and ground. Is that right?
    If I had found a short, I would have tried voltage injection and alcohol/freeze spray/thermal camera to find the shorted component. But now I do not know what to do. My guess is that it is the UC710 that is faulty and need to be replaced. But I am not sure at all of my diagnosis.
    Also, I don't understand why one of the CD3217 has created its LDOs, and the other has not. If UC710 were faulty, I would have expected all LDOs not to be created. How do I know that the faulty component is not one of the two CD3217?
    What do you think of my analysis so far, and what would you do now if you were me?
    Any help or link to useful resources to help me understand would be really appreciated!
    Cheers,
    mkdj
  • mon2
    • Dec 2019
    • 14191
    Hi. Welcome. A lot to read but suggest the following. Remove all power. Disconnect the battery. Meter in resistance mode. Measure the resistance to ground on each and every inductor that is on the board. Each inductor is linked to a power rail. We are checking the resistance to ground to understand if there is a shorted part onboard. Post any suspects.
    Also, later on, for power injection to hunt for shorted parts, never use a voltage higher than the lowest voltage. We use typically 0v6 - 0v8 while some are ok with 1v0. This is using an external adjustable power supply that will dialed to this injection voltage & say 3A-5A which should be ample to locate the shorted part (if one is found).
    Recently fixed an 'unfixable' A1932 with a shorted ceramic cap that was present on the audio board. This single cap was tanking the PPBUS_G3H main power rail. Multiple shops reported to replace the motherboard. This replacement of the board would NOT have fixed this case since the fault was on a remote audio board (headphone board). The wholesale price for this board alone was $90 from Asia. After removing 5 caps (in order), the bad boy was found and unit is working as it should be.
    • mkdj
      • Mar 2025
      • 15
      • France
      Thank you mon2 for your message and your pieces of advice.
      I've done the following measurements as suggested:
      Inductor Resistance
      L5230 2.2 MOhm
      LC320 1.8 MOhm
      LP800 1.1 MOhm
      L5840 0.49 MOhm
      L5820 0.36 MOhm
      L5800 0.37 MOhm
      Nothing suspicious according to me. If we had a short we would have measured less than a few Ohm, no?
      What now?
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        🛠 Original Issue
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • Adogabriel100
        where to get trusted CD3217. Problem with A2337 Macbook Air
        by Adogabriel100
        Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
        The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
        09-06-2024, 12:06 PM
      • soeren
        A2337 - Camara doesn't work
        by soeren
        I have replaced the display on my A2337 and I believe that during the change the battery connector was re-connected to the logic board and therefore I now have a non-working camera in my A2337 laptop.
        After the problem occurred, the camera was no longer detected and True Tone didn't work. I replaced the eDP flex cable (display connector) and now the camera is detected and True Tone works again.
        The problem is that when I open Facetime, for example, the green camera LED does not light up and the camera image remains black. In the end I get an error message. Does anyone...
        08-23-2024, 09:02 AM
      • gervaisc
        Macbook Air 2020 (A2179 / 820-01958) PPBUS_G3H fluctuates from 0 to 12V
        by gervaisc
        Hello, I am troubleshooting my daugther's MacBook Air 2020 (A2159), no liquid spills, not dropped. It was working well for the last 3 1/2 years and now refuse to power on.
        Took of the board (nothing connected). Visual inspection with microscope looks ok. The USB-C voltage is 5.17V, current fluctuates from 0.05A to 0.120A. No sign of 20V.
        I followed the (excellent) guide here: https://repair.wiki/w/MacBook_Air_A2...w_at_5V_repair
        1- No shortsbetween PPBUS_G3H and ground. It shows more than 1Mohm
        2- The PPDCIN_G3H...
        08-02-2024, 06:06 PM
      • slimmy182
        MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
        by slimmy182
        Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
        Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
        Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
        C81DC PP3V8_AON_VDDMAIN
        And
        Q5800
        What should I test as next step?
        Thank you very much!
        02-01-2024, 01:08 PM
