Macbook A1706. 820-00239-A doesn't see SSD questionmark folder
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    #41
    Re: Macbook A1706. 820-00239-A doesn't see SSD questionmark folder
    I have no power
    SSD_CLKREQ_L=0
    TBT_T_CLKREQ_L=0
    but as I understand it there should be 3.3v
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      #42
      SSD_CLKREQ_L=3.3V until you connect SSD_PCIE_CLKREQ_LB_L then the voltage drops to 0.090V. but there is no short circuit. resistance SSD_PCIE_CLKREQ_LB_L=3.75 megohm.
      • mon2
        • 14662
        No. If with the _L suffix then if the signal is 0V = logic low then it is active. This is good for these 2 signals.
        • PITERPENY
          • Jul 2023
          • 461
          • Ukraine
          #44
          SSD_CLKREQ_L=0v but it should be 3.3v? maybe the problem is in UB000?
          • mon2
            • 14662
            No, this signal is ok.
            Reference:
            https://boards.rossmanngroup.com/thr...ing-ssd.39782/
            • PITERPENY
              • Jul 2023
              • 461
              • Ukraine
              #46
              how can it be that all the readings are normal but the ssd is not working?
              • PITERPENY
                • Jul 2023
                • 461
                • Ukraine
                #47
                what else to check?
                • mon2
                  • 14662
                  PCIE_CLK100M_SSD_LB_P=0V
                  PCIE_CLK100M_SSD_LB_N=0V
                  These lines should not be 0V when the ssd is working. This clock is generated by the pch. This clock is required by all pcie devices to function. This is a 100mhz clock.
                  • PITERPENY
                    • Jul 2023
                    • 461
                    • Ukraine
                    #49
                    the voltage on these lines exists and fluctuates
                    PCIE_CLK100M_SSD_LB_P=0.725V
                    PCIE_CLK100M_SSD_LB_N=0.716V
                    • PITERPENY
                      • Jul 2023
                      • 461
                      • Ukraine
                      #50
                      I also noticed that when connecting an external monitor via type-C there is no image (maybe there is a connection).
                      • PITERPENY
                        • Jul 2023
                        • 461
                        • Ukraine
                        #51
                        any more advice? recommendations?
                        • PITERPENY
                          • Jul 2023
                          • 461
                          • Ukraine
                          #52
                          • mon2
                            • 14662
                            Remove all power. Meter in DIODE mode.
                            Red meter lead, yes RED to ground.
                            Black meter lead to the point to test.
                            Measure each signal of the SSD interface in DIODE mode at the lifeboat jumper block area.
                            Post each measurement.
                            • PITERPENY
                              • Jul 2023
                              • 461
                              • Ukraine
                              #54
                              OKAY CHEF.
                              PPVIN_2V7NAND_LB=0.422
                              PP5V_S4_P2V7NAND_LB=0.396
                              SSD_BOOT_LB_L=0.394
                              SSD_PWR_EN_LB_L=0.535
                              STORAGE_LB_EN=0.515
                              SSD_RESET_LB_L=0.509
                              SSD_PCIE_CLKREQ_LB_L=0.510
                              PCIE_SSD_D2R_LB_P<0>=0.387
                              PCIE_SSD_D2R_LB_N<0>=0.387
                              PCIE_SSD_R2D_LB_C_P<0>=0.358
                              PCIE_SSD_R2D_LB_C_N<0>=0.357
                              PCIE_CLK100M_SSD_LB_P=0.337
                              PCIE_CLK100M_SSD_LB_N=0.336
                              LPSR_EN_LB_L=0.490
                              PP3V3_S5_SSD_LB=0.351
                              • PITERPENY
                                • Jul 2023
                                • 461
                                • Ukraine
                                #55
                                I have TBT_T_CLKREQ_L=0v. and in a working MacBook TBT_T_CLKREQ_L =3.3v.
                                • PITERPENY
                                  • Jul 2023
                                  • 461
                                  • Ukraine
                                  #56
                                  how to check if the ssd is working properly? Maybe they have a problem or in the processor?
                                  • reformatt
                                    • Feb 2020
                                    • 1497
                                    I already mentioned that the SSD controller has a RAM layer above the processor and these are often underfilled. You didn't mention whether you had reballed that layer or not, and what the source of the replacement was.
                                    As far as the NAND's go, you can use the JC P13 programmer to test.
                                    • PITERPENY
                                      • Jul 2023
                                      • 461
                                      • Ukraine
                                      #58
                                      Yes, both layers were soldered 2 times but the result was zero. the second donor controller was also soldered from another board, but the result was also zero. I will look for another donor fee.
                                      • PITERPENY
                                        • Jul 2023
                                        • 461
                                        • Ukraine
                                        #59
                                        Originally posted by PITERPENY
                                        OKAY CHEF.
                                        SSD_BOOT_LB_L=0.394
                                        STORAGE_LB_EN=0.515
                                        LPSR_EN_LB_L=0.490
                                        What can you say about these indicators?
                                        • Udemzy
                                          • May 2017
                                          • 164
                                          • Guatemala
                                          #60
                                          Note that reprogramming the bios can also solve no SSD/hdd issue.
                                          • Danielreinaa
                                            HELP need password bios Macbook A1706
                                            by Danielreinaa
                                            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                            09-07-2024, 03:47 PM
                                          • capon5153
                                            Macbook A1706 works perfectly but no data on USB C
                                            by capon5153
                                            hello,
                                            so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                            i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                            06-22-2025, 09:42 AM
                                          • B2L_Repairs
                                            Macbook A1706 touchpad and keyboard not working. Please help
                                            by B2L_Repairs
                                            Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                            10-09-2023, 04:56 AM
                                          • obelix24
                                            A1706 - Macbook pro - one USB-C port only 20V 0A
                                            by obelix24
                                            I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                                            I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                                            There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                                            There were some broken pads under CD3215 but i've recreated them.
                                            What should be...
                                            05-22-2024, 08:04 AM
                                          • johnbeton
                                            Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
                                            by johnbeton
                                            I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
                                            Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
                                            This is what I measure so far:
                                            Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
                                            PPBUS_G3H = 0,79v
                                            PPBUS_HS_CPU = 0,79v
                                            PPBUS_HS_OTH5V = 0,79v
                                            PPBUS_HS_OTH3V3...
                                            05-21-2024, 02:06 PM
